Looking for LCA preventive maintenance...
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Imageoguy, May 28, 2015.
  1. May 28, 2015 at 6:07 PM
    Imageoguy
    Imageoguy [OP] Well-Known Member
    Gatineau, Qc, Canada
    2012 DCLB SR5
    Full OME suspension (885 front springs, Dakar leaf pack + OME shocks) + D29XL extra leaf + 3 deg. shim + RideRite airbags
    I did a bunch of searching but could not find a thread explaining how to do preventive maintenance on LCA's (seizing of cam bolts). Would appreciate if somebody could point me in the right direction.
  2. May 28, 2015 at 6:48 PM
    Imageoguy
    2012 DCLB SR5
    Thanks! Your post should be made into a sticky, looks like a very common problem.
    Just got my 30K mile maintenance on my Taco (as well as other stuff under warranty) and when the mechanic started doing the alignment, they noticed one of the bolts was seized. They are ordering another LCA under warranty but I wont have that option next year so I'll definitely start lubing the cr@p out of em!
  3. May 28, 2015 at 9:23 PM
    Rosscopeeko
    Rosscopeeko Well-Known Member
    BC
    08 DC LB 4x4 sport
    I just found out mine are seized as well.
  4. May 28, 2015 at 9:31 PM
    bluewaters182
    bluewaters182 Well-Known Member
    Greg
    Ohio
    2019 4runner TRD premium
    Weathertech Mats, Leer 180 Cap, Icon 2.5 coilovers w/700lb springs, Icon UCA, fox 2.0 remote resi 10" travel rear shocks, nitro 4.56 gears, carrier bearing drop, Level 8 guardian rims 16 x 8.5, 315/75/16 Cooper ST Maxx, satoshi grill, shorty antenna, BHLM, color matched eyelids, rear diff breather relocated, exhaust chop, mudflap delete, debadged, All Pro front bumper powder coated white, smittybilt x2o 8 comp winch, SOS sliders, illumination supply 30" single row led bar, uniden 880 CB w/2' firestick on relentless fab hood mount, full AllPro skids, AllPro expo leaf springs, AllPro U bolt flip, Ultraguage, interior LEDs , trimmed fenders and flares 2", AP ext brake lines, CMC, fire wall massage, pelfreybilt battery box, diehard group 31 battery, Kragen 7" HID, homemade HiLift mount, Yaesu ft-8900, Ellis precision AT shifter, EBC yellowstuff & sport rotors, PIAA 510 fogs, Safari snorkel
    What is the remedy once they are seized?
  5. May 28, 2015 at 10:11 PM
    Rosscopeeko
    BC
    08 DC LB 4x4 sport
    Alignment shop said once they are seized it's replacement time. I asked about applying penetrating fluid and he said it wouldn't work.
  6. May 28, 2015 at 10:30 PM
    bluewaters182
    Greg
    Ohio
  7. May 29, 2015 at 11:28 AM
    high voltage taco
    high voltage taco Well-Known Member
    Monticello, Ky
    05 TRD 6 speed 4x4
    so far, URD throwout bearing kit(sleeve), weathertechs, 285/70/17's on Ion 17x9 and OME 885s and Dakars and nitro sports. BHLM
    Just did my lower bushings and Moog cam bolts last week. Complete pain in the butt and took several evenings after work to do it. Get some good hack saw blades, have a good vise and a big hammer. I replaced ball joints while I was at it. I've also got 2 more sets of Moog cam bolts I'd sell someone. When I ordered them I was under the impression the kit was 1 bolt and 2 washers so I got 4 kits. The kit from Rock Auto comes with both bolts.
  8. Jun 6, 2015 at 8:36 AM
    Pigpen
    Dan
    Northwest Montana
    @DoorDing , @high voltage taco , How much "persuasion" is required if they aren't seized and does the LCA need to be supported while removing the bolt? Trying to do driver side, but don't want to be too forceful. They may need to be cut... Might have to order a kit or two.
  9. Jun 6, 2015 at 8:49 AM
    Pigpen
    Dan
    Northwest Montana
    Cam action works. I just want to remove them and put anti seize on them. BFH is ready for action - tapping gently isn't making the first one move.
    The driver side makes a pretty gnarly noise when the suspension moves abruptly and I figured this would be a good place to start from for chasing the noise.
  10. Jun 6, 2015 at 8:56 AM
    Pigpen
    Dan
    Northwest Montana
    It's only moved about 1/16 inch so far. I'll just beat it like it's my :censored: and see if it moves. I'll post results.
  11. Jun 6, 2015 at 9:47 AM
    Pigpen
    Dan
    Northwest Montana
    I was wrong. What I had mistaken for cam action seemed to be some flexing in the bushing. I think they're seized.
    @high voltage taco , still have those bolts?
  12. Jun 6, 2015 at 9:50 AM
    scocar
    scocar hypotenoper
    #boydprobs
  13. Jun 6, 2015 at 10:10 AM
    Pigpen
    Dan
    Northwest Montana
    I was going for prevention, but... Oh well. I'll just go play with the truck instead. Thanks for the help guys!
