Louder Horn ?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Kevinztaco, Apr 29, 2016.
  1. Apr 29, 2016 at 11:14 AM
    Kevinztaco
    Kevinztaco [OP] Well-Known Member
    none yet
    I wonder how loud is this set of horns compare to the ones that come with my Tacoma?
    All I want is a little louder set of horns. I'm clueless when it comes down to electrical work so what should I expect if I replace these with my stock horns? Thanks in advance for any suggestions. If it's not worth it than I'm not gona waste my time on it. Thanks again!
  2. Apr 29, 2016 at 11:17 AM
    llibrm
    llibrm OH NOOOOOO!
    Bill
    Winthrop, WA &Convection Oven, AZ
    06 DCSB, 06 LC120 (sold)
    Pelfreybilt Aluminum Bumper, KING 2.5 on all four corners, 4x4 illuminated switch, Cobra 75 w/ 3' Firestick, 2M/ 70cm Radio w/ Diamond NR770HB, Pelfreybilt bed bar, Lightforce Stiker 170s, BD 20" OnX6, BD S2 ditch lites on SDHQ mounts, BD SAE Fogs
    I says the dB rating on the bottom of the package.
    Its simple plug and play for installation. At the most, it would be a simple connector change. The horn is already wired though a capacitor.
  3. Apr 29, 2016 at 11:20 AM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    I am seriously considering the upgrade. I say go for it.
  4. Apr 29, 2016 at 1:50 PM
    ghayduke
    ghayduke Member
    Maryland
    None yet - WTB 1st gen
    If you want something a little better quality than Harbor Freight, these have a good reputation:
    http://www.stebel-usa.com/
    I installed one on a motorcycle and it was a huge improvement. Not quite plug & play, requires installation of a relay (at least on a MC) but the instructions are not hard to follow.
  5. Apr 29, 2016 at 2:01 PM
    uurx
    uurx Well-Known Member
    long island, new york
    '12 t|x pro
    I am not a fan of those horns posted by the OP.
    I have used hella super tones before in a few subarus I have owned, I know a few tacos are running them as well.
    Are your stock horns that bad? I find my horn to be pretty good, and passengers actually have commented (I like using it, calms my nerves more than cursing and flipping the bird)
    Could always do a set of real train horns compressor and all, could be a good excuse for dual purpose on board air tank
    https://www.tacomaworld.com/threads/taco-horn-replacement.5213/
  6. Apr 29, 2016 at 3:25 PM
    Yoda's TRD
    Yoda's TRD Well-Known Member
    David
    Haslett, MI
    2025 TRD Sport Hybrid
  7. Apr 29, 2016 at 3:27 PM
    Naveronski
    Naveronski Well-Known Member
    Fort Worth
    2014 MGM DCSB TRD:OR
    I went with the Hella Supertones in mine, replacing the stock set. Much louder, and a more distinct sound. It took some getting used to, but I like it.
    uurx likes this.
  8. Apr 29, 2016 at 7:32 PM
    Silence9
    Silence9 Solve et Coagula
    Alberta, Canada
    Those PIAA Bass ones sound really nice. More aggressive than the toy-car sounding stock horn.
    TBH the package the OP showed looks like it came from a bubble gum machine. Not sure if I'd get those.
  9. Apr 30, 2016 at 7:24 AM
    Healyj7
    Healyj7 2010TRD Cape Cod
    Cape cod MA
    2010 Tacoma 4x4 crew cab...
    Led third brake light All bulbs changed to LED Blue... Bed cover Extra tie downs in bed Borla 3' aftermarket excuast Blacked out front grill Smoked front lights White turn/running lights Bed security Mod 2 inch front lift and level with bilstein front and rear shocks... 1 Inch wheel spacers BF Goodrich AT tires 270/75/17
    Which ones are the easiest plug and play without having to wire or add anything?
  10. Apr 30, 2016 at 7:35 AM
    El Tano
    El Tano i am the one who knocks
    Pasadena. CA
    10 Tacoma TRD sport
    Corvette homelink FRONT: 5100 Blinstein set at 0 Procomp 3" leveling kit Allpro UCA’s. REAR: Icon Multi Rate RXT Leaf Pack 5100 Blinstein. 17x9 kMC wheels 0 BS 285/70 17 Wildpeak A/T4W C range Amp research steps. and a bunch of TSB's
    Scoobarooo likes this.
  11. Apr 30, 2016 at 7:37 AM
    Scoobarooo
    Scoobarooo Well-Known Member
    Casey
    Brooksville, FL
    '02 DCSB TRD OR
    3" OME/Bilstein, Retrofits, Custom Bed rack/Toolbox, Amsoil Everything, tons of others.
    I have a set of Hellas on my WRX, but my girl laughs at me every time I honk :(
  12. Apr 30, 2016 at 7:46 AM
    greeneggsnspam
    greeneggsnspam ಠ_ಠ
    Houston, TX
    .gif
    Too poor to list anything interesting.
    Just run train horns and be done with it.
    @SMKYTXN needs to hurry up and do his so that he can give everyone a write up.
    SMKYTXN likes this.
  13. Apr 30, 2016 at 7:51 AM
    joeybags
    joeybags Well-Known Member
    joe
    pa
    2011 4x4 trd sport mgm
    I've got the shocker from hornblasters people move out of the way.:))
  14. Apr 30, 2016 at 7:56 AM
    dumbassdave
    dumbassdave Active Member
    Dave
    BC, Canada
    07 SR5
    I went to the auto wreckers and picked up a Chevy Truck horn and added it to the stock horns. One hell of a $10 upgrade.
  15. Apr 30, 2016 at 8:54 AM
    ghayduke
    ghayduke Member
    Maryland
  16. Oct 5, 2016 at 6:59 AM
    jgang
    jgang Well-Known Member
    I had an on-board air system in my 2006 DCSB and hooked up a Grover air horn to it. Truly an attention getter that saved my a$$ on a dozen occasions, even at freeway speeds. Kind of a pain to hook up and dial in along with the expense, but there's no substitute if you need/want something that will get people's attention RIGHT NOW. Just be judicious in it's use for real "emergencies" so as to avoid simply pissing someone off. If I used my horn, it was for a damn good reason. Still debating putting one on my 2013 DCLB. I may try the PIAA Superior Bass just for the simplicity until I get the time, funds and ambition to go with a full air setup again.
    Healyj7 likes this.
