low idle
Discussion in '2nd Gen. Tacomas (2005-2015)' started by rondog, Apr 12, 2012.
  1. Apr 12, 2012 at 9:31 PM
    rondog
    rondog [OP] Well-Known Member
    Ronnie
    Escondido/San Diego
  2. Apr 13, 2012 at 9:01 AM
    rondog
    Ronnie
    Escondido/San Diego
    morning bump
  3. Apr 13, 2012 at 9:19 AM
    rondog
    Ronnie
    Escondido/San Diego
    My air filter was super dirty..hadn't cleaned it from the last desert trip. and its clean now. I took my MAF out yesterday and that tear drop looking thing it was pretty dusty so I used electronic cleaner on it and put it back in after it dried....ran the truck for about 10 minutes and it seems to improve the idle a little bit. From what I've read it takes quite some times for the ECU to adjust. Is that correct?
  4. Apr 13, 2012 at 9:40 AM
    Spaniard13
    Spaniard13 Member
    Marco
    Downey,CA
    05 PreRunner SR5 DBLCB
    blisteins 5100s toytech aal LT285/70-17 Toyo tires FN wheels: six shooters SPC LR UCA Toytec Eibach coil springs
    Have you checked your air intake/body throttle? That might be the problem for your low idle, since it could be dirty. My father's sequoia had the same problem but only that it would turn off since it was not running on its own.
    I have this product and if you use it, this might help you out more. most of it can be just cleaned with a towel.
    http://www.amazon.com/CRC-05078-Throttle-Air-Intake-Cleaner/dp/B000M8PYO2
    Hope this helped, and good luck with your taco.
  5. Apr 13, 2012 at 10:18 AM
    rondog
    Ronnie
    Escondido/San Diego
    yup thats what I used to clean it..or at least the same brand..once my airbag and seatbelt is fixed I should be able to drive it around again see if the problem persists
  6. Apr 13, 2012 at 10:21 AM
    dYL0n
    dYL0n أنا لست الإسلامي
    Dyl0n
    New Orleans, LA
    17TRDORDCSBQSJBLKBRO2SPECU1.04
    1.04. Kbro2s. ICONS.
    Reset the ECU by disconnecting the battery for 10-15 mins. Your truck will start with high RPMs and slowly drop until it settles. Hope this helps.
  7. Apr 13, 2012 at 10:58 AM
    rondog
    Ronnie
    Escondido/San Diego
    thanks, I will try that!
  8. Apr 18, 2012 at 2:53 PM
    rondog
    Ronnie
    Escondido/San Diego
    so after cleaning my throttle body like spaniard suggested, my truck isn't idling super low to the point it shuts off anymore, but I still wish it was higher. I still feel like something is wrong. The idle sits at about 150-200 when in drive or reverse at idle. Shouldn't it be more than that? I wonder if the motor in the throttle body is bad. Would this work on my truck? Looks the same and from a v6 lol
    http://www.weberbrothersauto.com/product.aspx?t=3551222
