Maint. Req. cause of intake
Discussion in '2nd Gen. Tacomas (2005-2015)' started by norcalbb11, Jan 5, 2009.
  1. Jan 5, 2009 at 8:11 AM
    norcalbb11
    norcalbb11 [OP] Nor*Cal
    Cali
    09 Taco Sport 4x4
    flowmaster 40 series, tinted windows, airaid CAI, removed 2nd filter, aries black bull bar
    Hey everyone, first of all hope everyone had a great new years and christmas, anyways i went to a mechanic the other day to talk about getting my lift done and all that and then we were just talking and he was talking about the intake and i told him that i have the airaid intake and he was like oh man i hope its not an oiled filter and of course it is and he said that it will make the engine light come on because of the oil getting in and to the sensor, so i would really like to find a dry filter that will go on my airaid so i dont have to go with the AFE pro dry cause i spent around 300 for my intake already so if anyone could help me that would be great, and if its easy to clean the intake and the sensor or whatever it would be cool to find out how to do that, thanks everyone!
  2. Jan 5, 2009 at 8:36 AM
    Dark Knight
    Dark Knight Well-Known Member
    Jeff
    NC/SC
    4Runner Trail, 88 pickup, Tundra Platinum
    A few bolts are different.
    no worries norcal, what your mechanic was describing with the oiled filter only happens when the filter is over oiled. The TRD intake filter is even oiled. You should not have a problem with the airaid filter as is, factory oiled. When you do clean it just take precaution to not over spray with the recharge oil.
  3. Jan 5, 2009 at 8:38 AM
    98tacoma27
    Ben
    Not Beech Creek
    ^^^^X2
    As long as it is not over oiled, you should be fine.
    Whats the model number of the intake?
    It is easy to clean the sensor. Simply remove it and spray it with this:
    Some people use just regular electrical contact cleaner. Whats the difference between the two? No clue or than MAF cleaner is designed especially for the MAF sensor.
  4. Jan 5, 2009 at 9:01 AM
    norcalbb11
    Cali
    09 Taco Sport 4x4
    yeah i havnt even re-charged it yet so i know i did'nt over oil it and ive had the intake on for about 5,000 miles and it still looks new but so im not sure why the light came on, im not sure where the sensor is located.
  5. Jan 5, 2009 at 9:05 AM
    j0sh
    j0sh Well-Known Member
    Oklahoma
    '10 TRD Sport 4x4
    AFE Filter, TRD Catback
    i have had my afe intake on for close to 30k miles, and have yet to see any problems. like they said, just dont over oil it. usually after i oil mine i will take a paper towel and kinda of touch it around the filter to absorb any extra oil.
  6. Jan 5, 2009 at 9:18 AM
    Dark Knight
    Jeff
    NC/SC
    the sensor is located on top of the factory intake box, Your airaid probably didnt come with the intake tube did it? If it is the airaid quick fit kit Part # 510-179 then your MAF sensor is still on the factory part still there, on the lift side directly under the engine cover.
  7. Jan 5, 2009 at 9:38 AM
    norcalbb11
    Cali
    09 Taco Sport 4x4
    well i know they took off the stock tube, i will have to look for the model number, i would really like to find a dry filter so i dont have to mess with the oil, the mechanic told me if i just clean the filter with soap and water and let it dry i could put a silk stalking over it and it acts like a dry filter and works great, anyone ever try that?
  8. Jan 5, 2009 at 9:48 AM
    Dark Knight
    Jeff
    NC/SC
    no have not tried that. AEM should have a dry filter to fit it.
  9. Jan 5, 2009 at 9:56 AM
    norcalbb11
    Cali
    09 Taco Sport 4x4
    i meant stocking but you guys know what i mean haha, and ill check out the AEM filters and see if i can find one to fit, im guessing online is the best way to find one right?
  10. Jan 5, 2009 at 10:05 AM
    Dark Knight
    Jeff
    NC/SC
    yep AEM has all their stand alone filters listed by size, just grab your Tape measure and get a few numbers from your current filter and you should be good to go. AEM Dry Flow
  11. Jan 5, 2009 at 10:11 AM
    norcalbb11
    Cali
    09 Taco Sport 4x4
    very cool, so im guessing i still need to clean the sensor to get the maintanance required light to go off right?
  12. Jan 5, 2009 at 10:24 AM
    spp
    spp OC, Kalifornia
    OC California
    Don't confuse the check engine light with maintainance required which is for oil change intervals as opposed to sensor malfuntion.
  13. Jan 5, 2009 at 10:27 AM
    norcalbb11
    Cali
    09 Taco Sport 4x4
    yeah i was thinking the same thing, i am going to get my oil changed this week since i am getting close to needing it done, and if it turns off then all is well but still wanted to find a dry filter so it was a win win thread for me haha, thanks.
  14. Jan 5, 2009 at 10:53 AM
    spp
    spp OC, Kalifornia
    OC California
    It doesn't just turn off you have to reset it. If you get your oil changed at the dealer they should do it for you. Instructions are in the owners manual.
  15. Jan 5, 2009 at 1:54 PM
    norcalbb11
    Cali
    09 Taco Sport 4x4
    well i actually got my oil changed just now at this place i always go to and the light went off so ill see if it stays off, im not use to a light coming on when i need to change my oil
  16. Jan 5, 2009 at 2:06 PM
    4x4Runner
    4x4Runner Sam’s gone, man. Moderator
    Drunken Sailor
    Not north, not south, not west, mostly east
    1WD
    nuttin fancy
    Correct!
    Read this. You have to manually turn off the Maint Req light. It is an idiot light to remind you that your oil needs changing.
  17. Jan 6, 2009 at 6:20 PM
    spp
    spp OC, Kalifornia
    OC California
    If the light went off it is because the guy who changed it knew enough to reset it for you. Apparent ly he knew how to RTFM.;)
