"Maint Req'd" light blinks 6 times when I start engine...?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by JWWPHOTO, Apr 23, 2009.
  1. Apr 23, 2009 at 4:36 AM
    JWWPHOTO
    JWWPHOTO [OP] Well-Known Member
    Westlake, Louisiana
    2008 Tacoma Pre-Runner w/ TRD packag
    What's up with this?
    My code scanner is picking up nothing. It the Maint Req'd would stay on, I would know that the oil needs to be changed and for that matter, I know how to reset it when that happens..
    I just hit 30,000 miles in my 08 Tacoma.
    I change all the oil regular and this is missing me....
    It's probably something simple.
    Jeff W. Waldrop
  2. Apr 23, 2009 at 4:41 AM
    badguybuster
    badguybuster Well-Known Member
    Michael
    West (by GOD) Virginia
    2016 Tacoma TRD Sport
    New truck....so nothing yet
    Then change your oil. The ONLY time my maintenance light comes on is to remind me to do it.
  3. Apr 23, 2009 at 4:55 AM
    mws4ua
    mws4ua I'll try being nicer if you try being smarter.
    Birmingham
    Sold my truck Jan '13... Still hang around.
    It's reminding you to change your oil. Use the search. There's a way to reset the light and it's been covered somewhere.
  4. Apr 23, 2009 at 4:58 AM
    David Tarantino
    David Tarantino Well-Known Member
    N.J.
    08 tacoma
    Maint Reqd light is not going to set a code a eng light will
    your just do for a mileage based service :)
  5. Apr 23, 2009 at 5:11 AM
    mws4ua
    Birmingham
    Well what do you know, I found the procedure and yours truly was the one that posted it! (I gave credit where it was due, though... I had found it somewhere else on TW.com and copied/pasted.)
    Check out the Ultimate Oil Change Thread for your answer.
  6. Apr 23, 2009 at 5:12 AM
    FoxySandChick
    FoxySandChick Well-Known Member
    Kristin
    Henderson, NV
    07 DC 4x4 Base model V6 Impulse Red Pearl
    De-badged, limo tint, black wet okole's, weathertechs, extra d-rings, TSB bilsteins
    Are you sure it is the maintenance required light? No offense, just making sure cause some people have made this mistake. Have you changed the oil yourself in the past or had a shop do it? I'm pretty sure you wouldn't get a code for a maintence light, but the check engine light would definately throw some codes.
    The maintenance light is supposed to come on at 4500 mile intervals and blinks then turns off every time you turn on the truck for the next 500 miles and at 5000 miles it will stay on meaning that is when the oil change is due and so on for every 4500-5000 miles from the times it is reset.
    edit: mws4ua posted what I was looking for.
  7. Apr 23, 2009 at 5:41 AM
    JWWPHOTO
    Westlake, Louisiana
    The "Maint Req'd" light stays on when the prescribed mileage has elasped for an oil change. As I stated, I know how to reset it when it stays on.
    In this case is blinks 6 times upon engine start. If it is in the owners man, I would invite someone to kindly tell me what page it is on. I can't locate it.
    jeff
    GarageGirl18 likes this.
  8. Apr 23, 2009 at 5:50 AM
    mws4ua
    Birmingham
    If you want it to stay on solid, just wait a few hundred miles. Like Foxy said, it blinks 6 times when you turn on the truck from miles 4,500 to 5,000. After 5,000 it stays on solid. You can re-set at any time to take the mile count back to zero.
  9. Apr 23, 2009 at 6:26 AM
    JWWPHOTO
    Westlake, Louisiana
    OK, I just never noticed the light "blinking" during these previous "500" mile periods.... (And at 30000 miles, I have go thru about 6 oil changes.)
    I stand corrected and enlightened. Is this in the 2008 Tacoma Owners manual? Anybody know a page number...
    Thanks
    Jeff
  10. Apr 23, 2009 at 6:29 AM
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    Mine did this the other day. I have recently done oil change but didn't reset light. Oil change thread to reset light here I come...............
  11. Apr 23, 2009 at 6:32 AM
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    Here ya go, fresh from the ult oil change thread.............
    To reset you Maintenance Required light:
    1. Turn the ignition key to the "OFF" position with the odometer reading shown.
    2. Turn the ignition key to the "ON" position while holding down the trip meter reset knob.
    Hold down the knob for at least 5 second. The odometer indicates "000000" and the light goes off.
    NOTE: You will see a series of dashes that count down while the system resets itself
    If the system fails to reset, the light will continue to flash!
    You must re-perform the procedure
  12. Apr 23, 2009 at 6:32 AM
    mws4ua
    Birmingham
    You seem a little skeptical... w/ all the "" in your post and the request for a manual page number. Don't believe us?!?!?
    I don't know if it's in the manual and I don't have mine handy. They might have kept it out so you'd have to drive to the stealership and they could scam you into services you don't need.
  13. Apr 23, 2009 at 6:33 AM
    mws4ua
    Birmingham
    Dude, I just posted the link to this is #5.
  14. Apr 23, 2009 at 6:49 AM
    JWWPHOTO
    Westlake, Louisiana
    It's not that I am skeptical or doubt anybody, but don't you think Toyota would want to tell my my light is blinking 6 times?
  15. Apr 23, 2009 at 6:53 AM
    JWWPHOTO
    Westlake, Louisiana
    MWS4UA and all the others, thanks for reading and responding to my post...
    Jeff
  16. Apr 23, 2009 at 6:55 AM
    mws4ua
    Birmingham
    No worries. I'm just messing around.
    Honestly, if you have your manual handy, it'd probably be faster for you to flip through every page of it to find the answer than wait for a page number from one of us. The truth might be that it's just not in there, though.
    You're welcome.
  17. Apr 23, 2009 at 7:40 AM
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    Yeah saw it. Wasn't tryin to steal your thunder.
  18. Apr 23, 2009 at 7:42 AM
    mws4ua
    Birmingham
    whatever, thunder thief!
  19. Apr 23, 2009 at 7:50 AM
    Snipe
    Snipe Well-Known Member
    Pacific NW
    08 TRD Off Road
    Page 159 Section (g) Engine Oil Replacement Reminder Light (for vehicles sold in the U.S.A.
    There ya go :D
  20. Apr 23, 2009 at 7:52 AM
    FoxySandChick
    Kristin
    Henderson, NV
    Mine is on page 161, but it is in the section with the explanation on all the dash warning lights.
