Maint Reqd light won't reset on my 2011
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Junebug McQuinn, Aug 21, 2011.
  1. Aug 21, 2011 at 3:10 PM
    Junebug McQuinn
    Junebug McQuinn [OP] Well-Known Member
    Wylie, TX
    2011 TRD Off Road Pre-Runner
    I changed the oil and have been trying to reset it and can't get it to work.
    I'm setting the odometer to actual mileage, taking the key out, holding down the reset knob and putting the key in and setting it to the on position. I've tried holding the knob down for 5 seconds, 30 seconds and then a minute or so and nothing. What the hell am I doing wrong? I've tried doing it different ways and nothing works.
  2. Aug 21, 2011 at 3:15 PM
    ImpulseRed008
    Susan
    SC
    08 PreRunner SR5 V6 w/tow pkg
    From elsewhere on TW.com...
    To reset you Maintenance Required light:
    1. Turn the ignition key to the "OFF" position with the odometer reading shown.
    2. Turn the ignition key to the "ON" position while holding down the trip meter reset knob.
    Hold down the knob for at least 5 second. The odometer indicates "000000" and the light goes off.
    NOTE: You will see a series of dashes that count down while the system resets itself
    If the system fails to reset, the light will continue to flash!
    You must re-perform the procedure
    __________________
    nikkerton likes this.
  3. Aug 21, 2011 at 3:17 PM
    rossk35
    rossk35 Do Work Son!
    hawaii
    07 TRD Sport Supercharged
    TRD S/C/TRD Intake/TRD Boost Gauge/DT Headers/OEM TL/ZKW retro/Pioneer DVD w/Ipod/Magnaflow/20% Tint/BHLM/JL 10" sub, JL VR components, JL 450/4 amp/Helwig Sway bar/Viper 791/ 18" limited 4runner rims
    the 11's need trip A showing instead of the odo. If you have the white cluster.
    Crow Horse likes this.
  4. Aug 21, 2011 at 3:18 PM
    Junebug McQuinn
    Wylie, TX
    I saw that, and I've been trying it. It's not working. I'm wondering if they possibly changed it for the 2011. Or maybe something is wrong with mine.
  5. Aug 21, 2011 at 3:20 PM
    Junebug McQuinn
    Wylie, TX
    Awesome, thanks! I set it to trip A and it worked.
    Babyruthless87 likes this.
  6. Oct 5, 2011 at 3:01 PM
    BlkTaco47
    BlkTaco47 Unhinged
    2016 Black AT DCSB 4x4 TRD
    JL Audio C2690tx Speakers Alpine MRV-F300 JL Audio 10" Sub - Full length Ported Sub Box Kicker Tweeters BFG KO2's 265/70/17 Tint N-Fab Bars Husky WB Mats AVS Visors Console Divider Tacoma Tonneau Cover ALL PRO 1.5" wheel spacers aFe CAI w/ Dry filter TRD Wheels Custom Remote Starter TRD Pro Grille ROAV Dash Cam 3" RC Lift Turn-down exhaust pipe TRD PRO Shift Knob vF Tune
    does it flash for an oil change or stay on steady? mine is just ON,
    not flashing.
  7. Oct 5, 2011 at 3:10 PM
    BlkTaco47
    BlkTaco47 Unhinged
    Hmm, I'm at 6k right now and it's on solid. Going out to
    start it to see if it flashes....
    EDIT: stays on solid.
  8. Oct 5, 2011 at 3:17 PM
    tcBob
    tcBob Gringo Bandito Moderator
    Bob
    07 PreRunner SR5 V6 Black
    one of the mods added it...thanks
  9. Oct 5, 2011 at 3:20 PM
    BlkTaco47
    BlkTaco47 Unhinged
    that's why I thought it was odd that it was solid and not
    flashing, hope it's not an issue this soon!
  10. Oct 5, 2011 at 3:52 PM
    ImpulseRed008
    Susan
    SC
    Mine never goes to flashing... I changed my oil about ~3500 miles before heading home from AZ earlier this year and forgot to re-set the light. Drove about 2000 over 5000 and it only stayed solid.
  11. Oct 5, 2011 at 3:57 PM
    ImpulseRed008
    Susan
    SC
    That would have driven me completely :goingcrazy: the light was bad enough. I had changed the oil, just forgot to do the light :anonymous:
  12. Oct 5, 2011 at 4:08 PM
    ImpulseRed008
    Susan
    SC
    that would definitely be EVIL!!!! You'd probably have people just re-set the light and forget about the oil
  13. Oct 5, 2011 at 4:23 PM
    Tacologist
    Tacologist Well-Known Member
    Bob
    Tenessee
    05 Double Cab Shortbed
    Rear leaf suspension. Home done tailgate re-inforcement.
    Why in the hell would Tonka change the light reset from total mileage to trip? That seems like a dumb thing to do for no apparent reason at all.
  14. Jul 1, 2013 at 5:47 AM
    skratch
    skratch New Member
    Thanks for this! been following the instructions in the manual and it wasn't working, searched and found this and it worked first time after setting it to Trip A. TW is so much more helpful than the dealership or manual. Thanks again.
  15. May 10, 2014 at 10:13 AM
    JEP
    JEP Resident Lurker
    Madison
    15 DBL V6 4WD
    N-fabs, BakFlip VP, power tailgate lock, bed lights, "raptor" grill lights. Standard mall crawler stuff.
    This gets me every time. Then i reread this thread and all is good again. Thanks TW
  16. Apr 23, 2017 at 5:11 PM
    Doughnut Spaghetti
    Doughnut Spaghetti Well-Known Member
    Kristofer
    Lansing, Michigan
    2009 Tacoma SR5
    Was tearing my hair out trying to get this to work on my 09, until I found this.
    Like this says, odo must be showing, not trip A.
    tcBob and Sidney Vicious like this.
  17. Mar 17, 2021 at 1:48 PM
    2012Tacoman
    2012Tacoman Active Member
    Jase
    2012 Tacoma TRD Sport
    I have a 2012 TRD Sport and changed the oil about 250 miles ago. My maintenance required light (which I did not even know about) recently started flashing upon startup and then go away. I have the white display and I could not reset it on the main Odometer selection. I tried again on trip A (where I save my oil change Milage anyways) and it gave me the horizontal dashes and worked fine. No more flashing light. For some reason it seems the orange/white display have different operations on resetting it. Hope this helps someone!
  18. Mar 17, 2021 at 4:21 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    Yes they changed the dash in late 2011 to white which uses the Trip Meter 1 where all of the red dash panels use the Odometer.
    2012Tacoman[QUOTED] likes this.
  19. Jun 18, 2021 at 5:52 PM
    DrMark
    DrMark Diet Mtn Dew & Guns
    Alabama
    2011 Tacoma PreRunner DoubleCab
    Thanks for this thread guys.
    If I had hair, I would have been pulling it out after the owner's manual procedure failing to work.
    Switching it on Trip A, and Shazam! Easy Peasy!
    Jimmyh likes this.
  20. Jun 18, 2021 at 8:14 PM
    Jimmyh
    SC
    2012 Prerunner SR5
    :thumbsup:
