Maintenance help?
Discussion in '4 Cylinder' started by mlach1127, Jan 31, 2014.
  1. Jan 31, 2014 at 5:26 PM
    mlach1127
    mlach1127 [OP] Member
    Mark
    Dighton, MA
    05 2.7/5spd
    Hello all.
    I have an 05 4cyl/5spd. Recently bought it off my father.
    Nothing has ever really been done to it, other than a clutch, and rear axle seals.
    I now need a front wheel bearing, and not sure what else I should do. Plugs have never been replaced. The truck has 160k on it. Any help would be appreciated, as well as what part brands are recommended.
  2. Jan 31, 2014 at 6:23 PM
    iroh
    iroh Well-Known Member
    michigander
    07 AC SR5 2.7 5MT 4x4
    tonneau
    It likely needs lots of stuff. If it hasn't been done yet, change all fluids, includings diffs (GL5 75w90, or 90w), transmission (Redline MT90 or Amsoil MTG work well if you can't find any dino non-GL5), transfer case if you have one (same as tranny), coolant (use Toyota SLLC), power steering (Dexron III ATF), and have the brake fluid changed out.
    Plugs are an easy job on the 2.7, so change them with the OEM denso iridium.
    Inspect those u-joints and grease them religiously if they have zerks. They're designed for purging so feed them until all the black crud is out every time.
    All I can think of off the top of my head
  3. Jan 31, 2014 at 7:05 PM
    worthywads
    worthywads Well-Known Member
    Peoples Republic of Boulder
    05 5-lug access I4 Stick, 70 Challenger Vert
    Consider never buying from your dad again. ;)
  4. Jan 31, 2014 at 10:42 PM
    mlach1127
    Mark
    Dighton, MA
    05 2.7/5spd
    Thanks guys.
    He has had some service done on this, but I have no clue what was done. As receipts weren't kept.
    As far as ball joints go, what brand is recommended? SKF? I've always used Timken in my Domestics.
  5. Feb 1, 2014 at 8:31 AM
    iroh
    michigander
    tonneau
  6. Mar 13, 2014 at 4:09 PM
    george3
    george3 Well-Known Member
    New Jersey
    2008 2.7 Manual Trans Tacoma
    Seat belt beeper, Cabelas (Weathertech) floor liner gray, Covercraft Seat Savers in Taupe, Protecta Heavy Duty Rubber Truck Bed Mat, Pop n Lock PL5200, Pace Edwards Full Metal JackRabbit, Wolverine oil pan heater, Scangauge2, afe pro dry s filter, Remote Underbody 4 Piece LED Light Kit (White) used as Bed light, DIY Washable Cabin Air Filter, PA15-TOY, 4x4 Illuminated Switch, full synthetic, Redline Tuning Hood Support, Smittybilt Nerf Steps black powder-coated
  7. Mar 13, 2014 at 10:36 PM
    G17GUY
    G17GUY Well-Known Member
    Modesto Ca
    tacoma
    spining hub caps chrome stick-on trim new car smell air freshiner stering wheel suicide knob nut sack on hitch back window curtain
    Check water pump weep hole for leakage
    Check drive belt
    Air filter
    Break pads/rotors
  8. Mar 13, 2014 at 10:56 PM
    frizzman
    frizzman Well-Known Member
    Pittsburgh, PA
    04 XCab 4x4 TRD/OR
    OME 2.5,Tundra 17s,Falken Wildpeak AT3W hitch w/ 7-pin, ARE cap, JVC HU w/BT, HID/LED lights
    http://www.tacomaworld.com/forum/2nd-gen-tacomas/
    hit up the 2nd gen area and search for maintenance items.
    I would think timing belt/chain if it's never been done (usually 70-100k for change interval)
    best thing to do is really ask your dad what he remembers doing and write it down as a checklist to go over and cross off
