maintenance required flashing?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by kevinklk97, May 16, 2009.
  1. May 16, 2009 at 6:29 PM
    kevinklk97
    kevinklk97 [OP] Active Member
    Clarksville TN
    2007 doublecab PreRunner
    I have an 07 dbl cab I just hit 20,000 miles on it this week and noticed the "maintenance required" light flashing about 5 times when i first start it after that it goes off. Has anyone alses did this when they hit 20,000 miles.
  2. May 16, 2009 at 6:31 PM
    Brunes
    Brunes abides.
    Rotorhead
    Around
  3. May 16, 2009 at 6:31 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Neds the oil changed...OR if it has been changed recently, you need to reset the light.
  4. May 16, 2009 at 6:33 PM
    wwjdweldingman
    wwjdweldingman Member
    sourthern cali
    2wd 05 Prerunner SR5 w/ LSD
    double din dvd system. tinted windows, billet grill, AFE intake, HIDs 8000K high/low, black headlight mod.
    I'm not sure about 20,000 but my 05 does the exact same thing when its time to change the oil, if you look in your manual that's also what it says.
  5. May 16, 2009 at 6:42 PM
    kevinklk97
    Clarksville TN
    Ok I'm about 500miles from the oil change i"m gonna change it and hopefully that will solve it. Thanks for advice
  6. May 16, 2009 at 6:43 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    After you change it, reset the light.
  7. May 16, 2009 at 6:49 PM
    REVHARD25
    REVHARD25 Well-Known Member
    so cal
    RUGGED TRAIL PACKAGE
    Tint on front windows. Dnx7120 kenwood. Rear tsb springs. Wet okoles seat covers UWS truck box Weathertech floor mats TSB floor mat hook grommets Satoshi grill AFE drop in filter Fumoto drain valve Bed mat
    wait the 500 miles and reset the light when your ready to change the oil:D
  8. May 16, 2009 at 7:07 PM
    BakoTruck
    BakoTruck Well-Known Member
    Matthew
    Bakersfield, CA
    05 PreRunner TRD
    Sounds like the oil change light. I would also like to point out since I do all my own oil changes is that you should still write down your miles on each oil change and go off of that vs what the car says. I say this because if you disconnect the battery for cleaning or whatever it will erase the oil change mile information from your cars computer on some cars. I'm not sure if this is true with the Tacoma's but it was the case with my 99 Firebird. So I always record the mile information after each oil change and go off of that. :cool:
  9. May 17, 2009 at 5:41 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    That light will start flashing at 4500 miles after the last time it was reset.
    And if it doesn't get reset, at 5,000 miles...it'll stay on constant.
