Malburg114's 3Link go fast SAS
Discussion in '1st Gen. Builds (1995-2004)' started by malburg114, Jan 4, 2013.
  1. Oct 15, 2020 at 1:51 PM
    #1281
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    Engine cage if you aren't in a rush!
  2. Oct 15, 2020 at 2:08 PM
    #1282
    slander
    slander Honorary Crawl Boi
    Hickory, NC
    02 Tacoma, fixed with curse words.
    I didn't go near the core support. I would notch the frame rails. Are you tucking the frame rails in a bit?
  3. Oct 15, 2020 at 6:51 PM
    #1283
    malburg114
    malburg114 [OP] Well-Known Member
    Las Vegas, NV
    2001 Toyota Tacoma TRD
    Got the fenders off and everything off the fender wells/core support. I already bought the tubing so going to do an engine cage to tie into an internal cage. B6CD5BE5-3B88-4716-B478-2B4C8A808DE8.jpg
    Lfaub03 and jubei like this.
  4. Oct 15, 2020 at 6:54 PM
    #1284
    malburg114
    Las Vegas, NV
    Any more picture of this and where it’s tied into the firewall?
    I was going to do this but I want to raise the frame rail to be level with the oil pan so I don’t have to notch it for more uptravel. Trying to keep the rails same width ish just higher.
    slander[QUOTED] likes this.
  5. Oct 15, 2020 at 7:00 PM
    #1285
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    @Anthony250 's truck. His cab cage has tubes joining in the firewall afaik.
    https://www.tacomaworld.com/threads/anthonys-99-tacoma.175933/page-24
  6. Oct 16, 2020 at 12:34 PM
    #1286
    malburg114
    Las Vegas, NV
    Superjoints and kingpin rebuilds and inner shafts showed up today. Just need to pull the trigger on hubs and I’ll have everything.
    62DA1E4A-1F97-495E-8973-979EC1B4A20A.jpg 1DB3E5E9-8D30-4A7F-AB99-AAB1A91777DA.jpg
    jubei, cbechtold, Lfaub03 and 4 others like this.
  7. Oct 17, 2020 at 7:46 PM
    #1287
    malburg114
    Las Vegas, NV
    More progress. Front end is cut off. Got the new frame tubes cut and slid into the old frame. Time to start plating and gussetting it and do the motor mounts.
    1486D89E-55A9-4044-8283-5FE084909835.jpg B2F4AF94-0A20-436A-A4A1-EC1016178464.jpg
    I promise the radiator is crooked lol251F6465-E878-4038-9F7A-A7724672B99E.jpg EB3FE449-509D-4D32-BA08-E07DDFB8A647.jpg
    can’t beat that for sliding it in and eyeballing it. That’s 180 degrees to the bottom of the frame under the cab 2529CEE3-98D4-41FA-8971-1F65552223E2.jpg 1D27444D-A10A-45EB-A0EE-06FA5EF3A5C4.jpg
    alee891, Snowy, slander and 1 other person like this.
  8. Oct 17, 2020 at 8:52 PM
    #1288
    slander
    Hickory, NC
    You don't measure until it's all done!!!
  9. Oct 21, 2020 at 7:30 PM
    #1289
    malburg114
    Las Vegas, NV
    Got the frame plate templates made and one side done on the outside. Was excited to do this but it’s kicking my butt lol need to find some more 3/16 and get it all welded up and then it’s on to engine mount and links
    56844AED-32DE-4C07-BAF0-C9A658EFBC61.jpg 7658826B-09DA-49F7-A539-CC8674C92883.jpg A7DA9A69-6EE7-4F5E-A711-22A7BF1606AD.jpg 79087EFF-0F95-465F-AC9B-BBC0B83A407E.jpg 937FAF26-95FA-4C6A-B8E8-4977EC660423.jpg
  10. Oct 21, 2020 at 8:12 PM
    #1290
    Kkrause09
    Kkrause09 Well-Known Member
    Kyle
    Tacoma sas
    Looking good, excited to watch the transformation
  11. Oct 21, 2020 at 10:23 PM
    #1291
    malburg114
    Las Vegas, NV
    Thanks it was a little over whelming at first when I cut everything on but now I can start to see it so that helps lol
    Kkrause09[QUOTED] and slander like this.
  12. Oct 25, 2020 at 9:21 PM
    #1292
    malburg114
    Las Vegas, NV
    Making these frame plates can be so time consuming.
    After being cut on the plasma and before clean up and holes
    And after
  13. Oct 26, 2020 at 8:01 PM
    #1293
    malburg114
    Las Vegas, NV
    No more leaky Toyota steering boxes
    121031CC-435F-4AE8-ACA4-6652BE5BBC1F.jpg 99220ACC-978F-4B37-96FB-73FDA3C6DF46.jpg
  14. Oct 28, 2020 at 5:27 PM
    #1294
    malburg114
    Las Vegas, NV
    Outside of the frame is plated and motor mounts are in. It stayed level to the frame so that’s good. It flexes a little when jacking it up from way up front but still need to plate the inside the frame.
    9E7D901D-0B61-45E6-A5DD-8ED1FF847C28.jpg 993F2AF7-4532-46C3-9576-68492924ECA3.jpg D171B58E-98EB-4960-A05F-A2967C856A12.jpg 40D8A895-B06B-4220-9094-F14B6F928326.jpg 73DC4C3F-681A-4973-8D82-2141EF36BE22.jpg
    Yota X, Lfaub03, cbechtold and 5 others like this.
  15. Oct 28, 2020 at 6:17 PM
    #1295
    slander
    Hickory, NC
    That looks good! Some flex is good so you don't break the frame rails and crack welds and cross members.
    malburg114[OP] likes this.
  16. Oct 28, 2020 at 6:20 PM
    #1296
    malburg114
    Las Vegas, NV
    Yeah I think it’s partly due to no inside plating yet and the back top of the new frame is still open. Going to have to undo the cab and jack up the front to finish the weld though...
    Ritchie and slander[QUOTED] like this.
  17. Oct 28, 2020 at 7:02 PM
    #1297
    slander
    Hickory, NC
    Yea those welds sucked from what I remember. A lot of welding via a mirror from what I remember. I didn't undo the cab, I probably should have! Curious to see if that makes it any easier.
  18. Oct 29, 2020 at 6:52 PM
    #1298
    malburg114
    Las Vegas, NV
    Inside frame plates kicked my ass... didn’t even get one side done. This showed up in the mail so I put it together and it eats material like nothing.
    Broke Okie Ty, slander and Ritchie like this.
  19. Oct 29, 2020 at 7:17 PM
    #1299
    slander
    Hickory, NC
    Yea the scab plates take FORVER!! Just wait until you get to the steering box mount, THAT was an asskicker, at least for me.
    Ritchie and malburg114[OP] like this.
  20. Oct 29, 2020 at 7:19 PM
    #1300
    malburg114
    Las Vegas, NV
    I have the template for the steering box so that should actuallly be easy unless I have to notch the frame for the box because the radiator may be in the way.
