Manual Transmission Fluid Change?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by nad, Sep 23, 2009.
  1. Jan 4, 2010 at 8:27 PM
    PA452
    PA452 Well-Known Member
    Western PA
    15 Access TRD Offroad, V6, 5spd Auto, 4x4
    Let me ask you, when you changed the fluid in your 6MT, did it take more than 2 qts or less? I know the manual calls for 1.9 qts, just wondering if it does indeed come out to 2 or less.
  2. Jan 4, 2010 at 10:20 PM
    singlefin
    singlefin Well-Known Member
    Hood River, OR
    Syncro
    Haven't done it in this truck yet, but yes its 2qts. If your worried about it buy 3 qts.
  3. Jul 23, 2014 at 4:09 PM
    marcom13
    marcom13 Member
    Help!!!
    I'm new to changing tranny fluid, I think I just fill the T-case, thinking it was the tranny--Maybe thats why it over flowed after 1 qt. Tranny I read is just ahead and then Ive got the front differential. I'm using 75-90 synthetic. Anyone got images or description of locations of fill and drain plugs.
    Please feel free to flame me, I just need the info !!!Leaving in the afternos and towing a small camper.
    Thanks for any help.
    You guys run a great forum.
  4. Jul 23, 2014 at 6:29 PM
    Hartford
    Hartford Well-Known Member
    Maine
    2011 Acc Cab 5spd
    This is your transfer case.
    http://i175.photobucket.com/albums/w144/jspuds/DSC00064.jpg
    As long as you didn't drain the transmission and add fluid to the transfer case you will be fine. Doesn't sound like you did as you only got a quart in there, which wouldn't be possible if the transfer was already full.
    If you have an automatic transmission this is the drain plug for it.
    http://i207.photobucket.com/albums/bb4/cb4x4/oilchangeplug004.jpg
    In the morning I can post up a picture, not taken from another thread, of the manual trans for you.
    TreeFortRichard likes this.
  5. Jul 28, 2015 at 8:46 AM
    dayNnite4
    dayNnite4 We can't stop here, this is bat country.
    Nick
    Southern NH
    '11 4x4 5-speed AC
    Does the 5 speed manual use the same fluid as the 6 speed?
  6. Jul 28, 2015 at 8:56 AM
    adamr94
    adamr94 Well-Known Member
    Adam
    NC
    06 Regular Cab 4x4
    Yes, but it takes a little bit more.
  7. Jul 28, 2015 at 9:02 AM
    Manwithoutaplan
    ID
    SAR Taco likes this.
  8. Jul 29, 2015 at 10:15 AM
    Manwithoutaplan
    ID
  9. Nov 2, 2017 at 6:49 PM
    TRON
    TRON Well-Known Member
    All Wheel Drive X-runner
    TRD Blower, 2.3 Pulley, NST OverDrive Pulley Kit, B&M Shifter, TR Lowering Kit, Spec Clutch, Xrunner Body Kit
    Redline is great but not so great in the cold winter months
  10. Nov 2, 2017 at 7:13 PM
    Taco'09
    Taco'09 Well-Known Member
    That is part of the reason why I have been recommending the GM12346190.
  11. Nov 3, 2017 at 5:41 AM
    tacoma steve
    tacoma steve Well-Known Member
    NH
    2012 TX Baja
    Sub’d I need to change mine to
  12. Nov 7, 2017 at 12:15 PM
    dayNnite4
    Nick
    Southern NH
    '11 4x4 5-speed AC
    What intervals do you guys change your MT fluid at? I hadn't seen it anywhere in the owners manual
  13. Nov 14, 2017 at 8:35 PM
    dbbd1
    dbbd1 Well-Known Member
    50k should do it...
  14. Oct 26, 2018 at 2:03 AM
    20somethingwidataco
    20somethingwidataco Yes, my avatar is a real car.
    Will
    Washington State
    2008 AC TRD SPORT M/T
    ACLB 6 SPEED: Suspension: Bilstein 6112s (3rd perch) (F) Taco Lean Spacer Bilstein 5160s (R) TSB Leaf Pack Wheelers Offroad 3 leaf progressive AAL Wheelers Superbump Front Duro Bump U bolt flip kit Duro Bump progressive bump stop 3rd gen TRD offroad sway bar Wheels and Tires: Summit Racing Wheel Dakars (Polished Silver) 285/70r/17 Goodyear Wrangler Duratrax (Load D) "Performance": AFE CAI with custom powdercoated white filter cover MagnaFlow Performance Series Exhaust URD Cam gears XTP Intake Manifold Spacer OTT Torque Tune Brakes: Stoptech Slotted Rotors Stoptech Sport Ultra Composite Brake Pads Wheelers offroad SS brakelines (Front) Interior: Kenwood DD headunit Oem Subaru Kicker Tweeters Alpine 6x9 (Front) & 6.5 (rear) (With Taco tunes speaker mounts) Alpine 500 watt amp Sound Deadening (Doors, Rear "wall", Roof) ODI Rouge Shift Knob Weather Tech Mats Painted/wrapped trim pieces Console Safe Console Vault Gridx Organizer Ram Phone Mount Meso Customs dual color map lights Meso Customs dual color dome light Wet Okole seat covers (Black) Wet Okole center console cover (Black) 1" Seat Raisers (Driver & Passenger) AJT Designs climate control and 4x4 knobs Back Up Camera Lighting: Retrofits (Mini H1's, RGB Halos, 5500k Bulbs)(Lenses wrapped in self healing PPF) Diode Dynamics SS3 Max SAE (Yellow) Diode Dynamics SS5 Pro (Yellow) Driving lights (ditch lights) Anytime fog mod Rigid Industries E series 32" Combo bar (spot/flood) Diode Dynamics XPR Reverse Lights Diode Dynamics XP80 turn signals Diode Dynamics HP5 Third brake light LED brake, parking lights and license plate lights Armor: Apex All Pro sliders BPF steel skid plate Bigass Trailer Hitch Camping/Storage: Tonneau Cover (Truxedo Roll Up) KB voodoo bed bars Pelican Vault (for gear) LED interior lighting Extra D rings in bed (6 total) Custom Powder coated white snow shovel with custom bedrail mounts Amazon special Traction Boards Hi Lift 48" Jack Other: All pro Bed Stiffeners Relentless Fab tailgate panel TRD sport graphics (Turd Gen spec) Anti Sun glare hood scoop wrap (Satin Black) Custom FleeBay grille 4 Hella supertones ECGS needle bearing Many Patches BPF shackle mount (With smittybuilt shackle) Tinted windows (Front/Rear) (18%) Meso Customs gasshole AVS inchannel window visors Diff Breather Kit 2012-2015 Oem Turn signal/folding mirrors (w/ sequential signals) 2012-2015 Oem LED taillights Full Size (285/70r17) spare DIY Larger Engine Splash Guards DIY Vipercut TRD radiator cap AC drip line mod Anti Tweeker tailgate lock
    How often should you change? I have 119k on my rig. Not sure if its been changed or not
  15. Oct 26, 2018 at 8:31 AM
    #35
    HillJackJDS
    HillJackJDS Well-Known Member
    Dale
    2008 Tacoma 4WD
    I rolled 109,000 yesterday in my 4WD 2008 Tacoma 4 cyl 5sp manual. I am interested in this thread and completing this work prior to the rotten cold and sloppy snow.
  16. Aug 12, 2019 at 9:25 PM
    #36
    Manwithoutaplan
    ID
    i change mine every diff change!
  17. Jan 31, 2020 at 7:30 AM
    #37
    flynonh2o
    flynonh2o Member
