Maxtrac Spindle Lift for 2nd Gen Prerunners
Discussion in 'Suspension' started by markmatters, Feb 11, 2012.
  1. May 18, 2013 at 4:08 AM
    #2261
    YotaMatt
    YotaMatt Livin Low, Ridin High
    West Point VA
    12 PreRunner DC TRD Sport
    Spidertraxx 1.25" spacers in front and rear, 4" Maxtrac Spindles,Billy 5100s at 0", OME 885 Springs, 1/4" top spacer on both sides, 1.5" AAL, 3" Block, 1.5" 4crawler driveshaft spacer, 17x9 XD Spys with 35x12.50 Nitto Mud Grapplers, Magnaflow offroad Stainless Exhaust, Volant Intake with scoop,Camo emblems, BHLM, Tinted tailights, Anytime fog mod,Alpine Type R 12, Kicker 1000 watt amp,600 watt 4 channel memphis and all memphis components, 35%tint front all the rest at 5%, Hella 500s with sylvania zxe bulbs, sylvania zxe headlights, sylvania zxe fogs, Weathertech digi fits, flyzeye blue/white, LED map dome license plate lights, Redline hood struts, Tailgate EZ Down, Custom TRD Camo Browning Edition Bedsides, Camo wet okoles, Ridgid Dually bed lights, SOS Concepts Tire Carrier
    The 2 inch aal should be enough with spindles only in the front...3.5 inches of lift is gunna sit ass high
  2. May 18, 2013 at 8:50 AM
    #2262
    StreetTaco4Me
    StreetTaco4Me Taco Shot
    Bryan
    Ventura County, So. Cal.
    2001 4runner SR5
    looking to replace shocks and add spacer lift...I do not off road at all just like the height of a lift
    OK so no need for blocks also in back...
    OME 60091 Rear Shocks (pair) $190
    or
    Bilstein 5100 Rear Shocks (pair) $166
    which of the 2 shocks is better given the price?
    1.25" spacers in front only, not needed on back, or I need two pairs of spacer 1 in fron and 1 in back?
    thanks again
  3. May 18, 2013 at 9:12 AM
    #2263
    YotaMatt
    West Point VA
    I like the Bilsteins....shouldnt need blocks...I ran 3" in front and 1" in rear and sat level so 4 and 2 will be perfect
    U have to have spacers in front to run the wheels...I would get them all around so it looks even
  4. May 18, 2013 at 9:58 AM
    #2264
    StreetTaco4Me
    Bryan
    2001 4runner SR5
    Ok thanks again...a few more questions but I swear I am almost done, just 6 more points of clarification and I think I will all set to place my order, I really appreciate the time you are spending to help me.
    1. Installing a 1" block though should get me that slight forward nose down lean that I would prefer though right?
    2. if I choose to do the 1" block in addition to the 2" aal, should I get the Bilstein/RCD 5100 Extended Rear Shocks (support 3"-4" lift) then, instead of the Bilstein 5100 Rear Shocks ?
    3. also would the u-bolts that come with the 1" block be long enough to support the 3" total lift (2" aal + 1" block)
    4. If I do go to 3" would the extended brake lines in the rear be the wise choice as opposed to trying to stretch the existing lines, or are the existing lines plenty long?
    5. (super lame question) having a 2013 do i have a 3 leaf spring or a 4 leaf spring?
    6. is axle wrap a serious concern with a 1" block? or is that anything I need to worry about?
  5. May 18, 2013 at 10:19 AM
    #2265
    YotaMatt
    West Point VA
    1.yes
    2.yes
    3.usually the ubolts that come with blocks are pretty long
    4.recommended but not required
    5. my 2012 prerunner has the 4 leaf..but some have 3...need to look at yours
    6. i dont have any major axle wrap and im running 3" block
  6. May 18, 2013 at 10:53 AM
    #2266
    StreetTaco4Me
    Bryan
    2001 4runner SR5
    great info...thank you again so much. you have been a tremendous help!
  7. May 18, 2013 at 11:40 AM
    #2267
    BORNWILDGUY
    BORNWILDGUY Well-Known Member
    Rich
    Florida
    2020 TACOMA TRD SPORT DCLB LIFTED W KDMAX-PRO XT TUNE
    FULLY LOADED WITH THE TECH PACKAGE, LEATHER, JBL SYSTEM W UPGRADED JBL SPEAKERS IN AL DOORS AND SUB, LED HEADLIGHTS, MOONROOF, EXTANG FULL TILT COVER, NFAB SIDE STEPS, OEM ROOF RACK, TRD PRO TAILS, COLOR MATCHED TRD PRO GRILL WITH WHITE RAPTOR LIGHTS, 15% TINT ALL THE WAY AROUND, TINTED WINDSHIELD 50%, BILSTEIN 6112'S W 650# SPRINGS AND 1/4 SPACER, ICON LEAF SPRINGS W 5125 REAR SHOCKS, WELD LEDGE 6 WHEELS 18 X 9 -12 W 275/65R18 TOYO AT III LOAD C TIRES
    If you are going to install a small block go with the 1.5. The 1.5 has a taper to it and the 1" doesn't.
  8. May 18, 2013 at 4:22 PM
    #2268
    StreetTaco4Me
    Bryan
    2001 4runner SR5
    ok will do...what does the taper offer that the 1" w/o taper does not...in other words what is the benefit of the taper?
  9. May 18, 2013 at 4:25 PM
    #2269
    YotaMatt
    West Point VA
    Angles the driveshaft better to prevent vibes..they many shims that will do that as well
  10. May 18, 2013 at 4:32 PM
    #2270
    StreetTaco4Me
    Bryan
    2001 4runner SR5
    ok...got it...thanks again guys...
  11. May 18, 2013 at 4:41 PM
    #2271
    StreetTaco4Me
    Bryan
    2001 4runner SR5
    maybe I can get helkp on this one too...in all my talking of a lift my brother in law wants one as well...same truck as me 4x2 no off roading dbl cab sport
    he wants a 2" lift front and back...does not want to deal with coil overs or new UCA
    i told him billstien 5100s front and back...that could adjust the front 2" and the rear 2"...was not sure does he also need a 2" aal? any other bolts or anything you can think he would need to add?
    ballpark price?
  12. May 18, 2013 at 4:58 PM
    #2272
    YotaMatt
    West Point VA
    Go with this and get the 1.5" aal..430 $
  13. May 19, 2013 at 12:05 AM
    #2273
    StreetTaco4Me
    Bryan
    2001 4runner SR5
    looks good that was i was thinking for him...but are new rear shocks necessary why not just use the existing rear shocks and buy
    5100 fronts set them at 1.75
    1.5 rear aal
    or are the stock shocks not long enough with the 1.5 rear aal? cost is only $305 that way...
    2 questions regarding that kit...it states
    "NOTE: Front Upper bushings and washers are not included from Bilstein in this part number, order separately if needed."
    is that something he would need for install?
    and
    "NOT RECOMMENDED FOR USE WITH SPACERS OR LIFT COILS UNLESS LOWEST (STOCK) SETTING IS USED."
    that still gives a 2" lift in the front on the 2" setting, correct?
    also he wants to run 285/70/17 on the stock sport rims but he does not want to trim anything...will he rub with those wheels and should he stay down at 265/70/17?
    or will the spidertraxx spacers (which i think he would need, please correct me if I'm wrong) be enough space to get him clearance in the wheel well to run the 285s?
    He still needs and alignment as well after install correct?
    thanks again...I am will not hijack this thread with anymore small lift questions:D
  14. May 19, 2013 at 5:47 AM
    #2274
    YotaMatt
    West Point VA
    He has to go 3" to clear 285s without trimming. ..he has to run wheel spacers to use stock wheels
    Longer shocks arent required but are recommended
  15. May 19, 2013 at 7:54 AM
    #2275
    Mr Salty
    Mr Salty "Give up the good to go for the great"
    Hermmy
    SoCal (Bro Capital of the world)
    White SR5 Pre-runner
    Lots of chrome
  16. May 19, 2013 at 8:03 AM
    #2276
    Mr Salty
    Hermmy
    Lots of chrome
  17. May 19, 2013 at 8:04 AM
    #2277
    bkmcinty
    bkmcinty Well-Known Member
    Fort Myers, FL
    08 PreRunner SR5
    Black Badges
    I'm running the 4" block and I must say it rides a lot better than I thought it would......granted its still rougher than stock but you have to expect that......I do not have the ext brake lines and haven't had any problems. I keep my eye on them and they seem to have plenty of room to move. I don't do a lot of offroading and really the only time the ass moves in over huge speed bumps in my neighborhood haha. I mean maxtrac sells the kit with the 4" blocks with no ext brake lines and I'm sure they tested their own kit out before selling it to the public.....I'm sure it's not a bad idea to get longer ones but for a street queen like mine I guess it's not a must have.
  18. May 19, 2013 at 8:26 AM
    #2278
    Mr Salty
    Hermmy
    Lots of chrome
    Stock brake lines were designed to accommodate the down travel of the factory packs (where the length of the lines come into play). When you modify the rear, you're extending the brake lines down further.
    Runner 4" blocks in the back with stock lines would be a concern of mine if I were you, but thats just me. Not sure if you ever us all the down travel in the rear, but if so perhaps you are tugging on those lines pretty good.:eek:
    BTY, doesn't Maxtrac's 4" kit include 2" blocks in the back.
  19. May 19, 2013 at 8:27 AM
    #2279
    StreetTaco4Me
    Bryan
    2001 4runner SR5
    sounds good...I am new to all this and have a lot to learn I will be happy to take any amount of advice anyone wants to share with me :D
    regarding a 5100 and 1.5 aal
    toytec not that I have to buy from there states
    ""NOTE: Front Upper bushings and washers are not included from Bilstein in this part number, order separately if needed."
    and
    on the 1.75 gstting i would get 1.75 lift in front w/o spaces or lift coils right?
    so i am trying to verify...if we get 5100s for the fron set them to 1.75 and get a 1.5 rear aal...we will get my brother in law just short of a 2" all around lift?
    also Toyomatt, why would you recommend getting the rear 5100 as well? just wondering what they offer over the stock rear shocks...thanks again everyone
  20. May 19, 2013 at 9:09 AM
    #2280
    Mr Salty
    Hermmy
    Lots of chrome
