Missing Transmission cooler.
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Zingbot, Jun 11, 2020.
  1. Jun 23, 2020 at 5:00 PM
    #681
    Sharpish
    Sharpish Well-Known Member
    Brian
    Victoria, British Columbia, Canada
    2012 Tacoma TRD OR 4x4
    It’s nothing more than a warmer really.
    jetfishn likes this.
  2. Jun 23, 2020 at 5:03 PM
    #682
    Sharpish
    Brian
    1000%
    The factory cooler isn’t going to do a hell of a lot. If you’re towing on a flat highway the transmission stays the same temp as though you weren’t towing at all. If you’re pulling hard up mountain passes and the truck unlocks the torque converter the factory cooler is a fart in a hurricane. Temps will skyrocket, anyone who tows with an ultra gauge knows what I’m talking about.
    Same with long steep ascents in 4LO (4Hi fries fluid) There isn’t enough air flow at low speed to do anything at all.
    RobP62 and KissmyTaco[QUOTED] like this.
  3. Jun 23, 2020 at 5:16 PM
    #683
    EdgeCrusher
    EdgeCrusher Well-Known Member
    Chicagoland
    '16 OR DCSB Fully Loaded
    Interesting video
    RobP62 and shakerhood[QUOTED] like this.
  4. Jun 23, 2020 at 8:48 PM
    #684
    RobP62
    RobP62 NVR20LD
    Rob
    Street, Md.
    TTC Member #0125
    You might want to look at @pmstoy10 's setup. He worked a fan into his setup. You're going to need all the help you can get.
  5. Jun 23, 2020 at 10:48 PM
    #685
    KissmyTaco
    KissmyTaco Well-Known Member
    Eric
    Phoenix, AZ
    2017 Tacoma MGM DCSB TRD Sport
    I have a Gashole
    I saw what he did. I think I bookmark it.
  6. Jun 24, 2020 at 4:11 AM
    #686
    pmstoy10
    pmstoy10 Well-Known Member
    hudson valley, ny
    2010 Tacoma DCLB TRD Sport
    Weathertech Floor Liners, UWS Toolbox, Seatbelt Chime Mod, Coverking Covers, Window Guards, Wheeler's 1.5" Single Leaf AAL, Rear Spring TSB, Front Bilstein 5100's @ 2.5", Rear Extended Travel Bilstein 5100's, removed front mud flaps, Lifetime LED Headlights, Firestone RideRite Air Bags with Daystar Cradles, Light Racing UCA's, ECGS Front Diff Bushing
    No fan..... yet.... But I haven't needed to add a fan since I'm cruising not crawling.
    @KissmyTaco - you'll definitely want something aftermarket. My trailer is 3700# dry, but we load up a ton of crap in the truck when we go for multiple weeks so I'm probably pushing 6k when all is said and done (including people, etc.). The cooler I added certainly made a huge difference towing in the ADK mountains. I keep my truck in 4th (second Gen) to keep the torque converter locked - not sure how to handle that with a 3rd gen. I'd also check out the Towing Bible thread. There was someone who had a 3rd gen and did the same thing with a fan. I think it was linked somewhat earlier, but I've been in the woods the past couple days with no service so I'm behind on the thread.
    Edit:. This is where I got my inspiration
    https://www.tacomaworld.com/threads/3rd-gen-transmission-cooler-upgrade.482280/
    KissmyTaco and RobP62[QUOTED] like this.
  7. Jun 24, 2020 at 4:58 AM
    #687
    Da Voke
    Da Voke Well-Known Member
    Canada
    2020 DCLB Sport (Stolen and recovered)
    I’d have a concern that a larger cooler in front of the radiator would obstruct airflow through the rad which would create a far bigger issue than transmission temps.
  8. Jun 24, 2020 at 5:16 AM
    #688
    pmstoy10
    hudson valley, ny
    Hasn't been my experience. My coolant temp doesn't move away from around 185 -190 even when towing. I monitor it with Torque
    Skydvrr and RobP62 like this.
  9. Jun 24, 2020 at 6:18 AM
    #689
    RobP62
    RobP62 NVR20LD
    Rob
    Street, Md.
    TTC Member #0125
    Oh, I thought you were the one that added a fan. Sorry Brother. Mornin' :thumbsup:
    pmstoy10[QUOTED] likes this.
  10. Jun 24, 2020 at 6:20 AM
    #690
    RobP62
    RobP62 NVR20LD
    Rob
    Street, Md.
    TTC Member #0125
    Hey! I have Torque! I didn't know it monitored trans temp too!!! I know what I am playing with later.
  11. Jun 24, 2020 at 7:16 AM
    #691
    Zingbot
    Zingbot [OP] Well-Known Member
    Pardon my ignorance, can someone with the factory external air cooler explain how the lines run. I need to know how to install an external cooler as I don’t currently have one. I glanced at a truck a while back and it had a line in and out of the radiator just like mine. It also had two hoses from the external cooler thru the radiator support and down to I don’t know where. Where do they go?
    RobP62 likes this.
  12. Jun 24, 2020 at 7:33 AM
    #692
    scotkw
    scotkw Well-Known Member
    A free State
    '17 DCSB V6 2wd Sr5
    Hot fluid goes in the top engine radiator trans line and comes out the bottom trans line and back to the trans.
    So , now come out of the bottom of the engine rad and go to your new cooler. Then from the new cooler back to the trans line that was on the bottom of the engine rad originally.
    Those two lines through the rad support are the feed line from the bottom of the rad, then a return line going back to the trans.
  13. Jun 24, 2020 at 7:43 AM
    #693
    pmstoy10
    hudson valley, ny
    No problem! Mornin' back atcha!
    I'd send you the custom codes but we have a different gen so I don't think they are the same.
    RobP62[QUOTED] likes this.
  14. Jun 24, 2020 at 7:54 AM
    #694
    Zingbot
    I think I understand how to add a cooler after the radiator cooler. If I wanted to do it like the factory lines how would I do that. I don’t get how there is a line in and a line out the radiator cooler just as tho there isn’t an external cooler attached. The oem external cooler has two lines and the external has 2 lines. I don’t see how they are in series as there appears to be four separate lines/hoses.
  15. Jun 24, 2020 at 7:56 AM
    #695
    RobP62
    RobP62 NVR20LD
    Rob
    Street, Md.
    TTC Member #0125
    Based on your current setup and the lack of an external ATF cooler, and also based on what @rblalliance said, look at this photo below that you posted, and that I added arrows to:
    1) You would remove the existing hose from the connection at the bottom left hand side of your radiator, the one with the blue arrow.
    2) Then you would run a new hose from this same connection to the "fluid in" connection of your new aftermarket ATF cooler.
    3) Then you would need to run a new hose from the "fluid out" connection of that new ATF cooler, and connect it to the existing hose with the blue arrow you pulled off.
    * The hose with the red arrow remains untouched.
    * The hose with the yellow X's is not part of the system at all.
    From what I am reading online and what some have said in your thread, that is the path the fluid should take.
    I'd like to hear what @gearcruncher has to say though.
  16. Jun 24, 2020 at 8:07 AM
    #696
    RobP62
    RobP62 NVR20LD
    Rob
    Street, Md.
    TTC Member #0125
    Custom codes for what? It's not a simple function of the software/app?
  17. Jun 24, 2020 at 8:14 AM
    #697
    Zingbot
    Thanks a bunch, very helpful. Thanks to scotkw also
  18. Jun 24, 2020 at 9:28 AM
    #698
    KissmyTaco
    Eric
    Phoenix, AZ
    I have a Gashole
    Thank you. I'm at 4300# empty, probably going to be about 5000-5200# in trailer for long weekends. Heading up to northern AZ presents some 6% grades so I think I can use all the help I can get.
    See you are in NY, grew up on SI, went to undergrad at SUNY Oneonta.
    pmstoy10[QUOTED] and RobP62 like this.
  19. Jun 24, 2020 at 9:56 AM
    #699
    pmstoy10
    hudson valley, ny
    Nice! Grew up near Rochester and now in New Paltz area
  20. Jun 24, 2020 at 9:57 AM
    #700
    pmstoy10
    hudson valley, ny
