more hp
Discussion in '4 Cylinder' started by prerunner05, Nov 10, 2009.
  1. Nov 10, 2009 at 8:42 AM
    prerunner05
    prerunner05 [OP] Well-Known Member
    David
    middlesex,va
    05 prerunnerSR5 5spd
    265/65/r17 . fog lights. secondary air filter removal,AFE Pro S dry drop in. double din navigation HU 6.5" componet speakers in the back
    So have any of you guys added/modded anything to notice an an appreciated hp gain. Love my 2.7 but just want a lil more:D.
  2. Nov 10, 2009 at 9:04 AM
    humanoid
    humanoid bite me
    Sunny SoCal
    I had a '99 Xtra Cab PreRunner SR5 V6
    Slap on a turbo or a supercharger, only proven ways to gain HP.
  3. Nov 10, 2009 at 10:34 AM
    Juggernaut
    Juggernaut Captain
    Sacramento
    18 PreRunner TRD OffRoad DCSB
    I believe every TRD sticker you place on your truck will add 3 horse power.
  4. Nov 10, 2009 at 10:39 AM
    BirdTRD
    BirdTRD Unsuspectingly striking from above
    Greg
    New Mexico
    TRD Off Road 4x4
    Front (2.75" total): 1.6" Eibach coils, Toytec 0.5" (L) & 0.25" (R) top plate spacers, 5100's @ 0.85", Built Right uniball UCA's, Differential drop, Removed sway bar Rear: TSB springs, Wheeler's 1.5" AAL, 5100's, 2* shims, Carrier bearing drop, F and R Spidertrax, 285/75-16 Goodyear Duratracs, Self-fabbed sliders, rear bumper, and skid plates, Cobra 75 CB, Bed lined slim lo-pro tool box, Bed Extender, Diff breather mod, Two tail gate security mods, Exhaust dumped behind axle, Can't leave shit alone so plenty more coming...
    New air intake/filter system in combination with a free flow cat back exhaust system can boost you a little with any added stress on the engine. In fact, they can even reduce stress on the engine. I haven't researched it much, but chip/programs can do good things too w/o stressing the engine like turbos or supers would.
  5. Nov 10, 2009 at 10:42 AM
    08pretaco
    08pretaco Well-Known Member
    az
    2014 Tundra 4x4 CM 5.7L SR5
    alpine developments finally came out with a supercharger look into that. other than that the only way your gonna get more power is regearing, down side to that is freeway driving rpm's. other than that intake, exhaust and crap dot do all that much! chips dont do anything but mess your engine up, from what other people say. only "chip" that might be worth it is urd maf calibrator.
  6. Nov 10, 2009 at 10:46 AM
    Yoytoda
    Yoytoda The Little Truck That Could
    Roland
    Big Bear,CA / Upstate NY(Saratoga)
    2010 Tacoma Regular Cab 4x4
    completely stock
    I put a magnaflow high flow cat-back on my truck with not much noise gain (throatier at low RPMs no rice sound) but there is definitely a power gain. Its hard to notice upon take-off but i notice no more downshifting to fourth on long hills to maintain 70mph. I also noticed 1-2mpg increase. My 4x4 2.7 averages 23-24mpg 60% highway 40% city with some CA traffic here and there and i dont drive easy. Im very happy with my little reg cab.
  7. Nov 10, 2009 at 10:59 AM
    BirdTRD
    Greg
    New Mexico
    TRD Off Road 4x4
    I never claimed "exhaust and crap" will turn your truck into a top fuel funny car. It just frees up some of the potential of your engine while decreasing stress. It frequently even increases your mpg! Most hardcore supers and stuff will do little more than burn through your engine. Various engine parts (heads, cams, rods, rockers, etc.) just aren't designed to run at the levels chargers put you at.
    Re-gearing does not increase power. It just changes the way the existing power is transferred to the road. Like you said, there is a penalty to that change as well.
  8. Nov 10, 2009 at 2:39 PM
    Yoytoda
    Roland
    completely stock
    On a V6 tacoma gains from exhaust and intake are not that noticable as stock parts are well matched for cfm limits intake and exhaust of a stock engine. The 2.7l intake and exhaust seem to be really restrictive and the 2.7 does not breath good. The engine has to work harder to pull air in and push air out. The restricted air flow causes the ecu to lean out the fuel mixture to compensate for lack of air. This is done to pass emissions. When you free up the intake and exhaust the ecu will automatically richen the mixture and your engine will run better and the added fuel, less restriction, and more power will allow you to drive without having to keep your foot in it giving you better mpgs.
    I had a car with an aftermarket onboard computer that would tell me my throttle position. After the addition of K&N intake and Borla exhaust my car required 7% less throttle input to maintain 80mph. the power gains were not noticable while driving other than noise, and i had a 4mpg increase.
  9. Nov 10, 2009 at 3:29 PM
    08pretaco
    az
    i have a afe air filter, jardine cat back, secondary filter removed, and the inner fender "intake" taken out. i dont feel any noticeable performance or have difference in gas mileage.
    oh and forgot dt headers. that was the most noticable even at that im whatever about it. though i do think the best mod for our trucks is the dt header
    thats why i mentioned your losses at higher rpm's. if you want power and dont do alot of freeway, i think regearing would be a great idea, if you hardly see the freeway. otherwise go other routes
    "I had a car with an aftermarket onboard computer that would tell me my throttle position. After the addition of K&N intake and Borla exhaust my car required 7% less throttle input to maintain 80mph. the power gains were not noticable while driving other than noise, and i had a 4mpg increase."
    Thats awesome! wish my taco got a decent amount of power from the mods i got!
  10. Nov 10, 2009 at 7:43 PM
    Yoytoda
    Roland
    completely stock
    "i have a afe air filter, jardine cat back, secondary filter removed, and the inner fender "intake" taken out. i dont feel any noticeable performance or have difference in gas mileage."
    That blows, thats alot of money and parts that should have given you some gains. Ive wondered if the mileage will peak and no matter what else you do it wont get better. I want to get larger tires but dont want to lose the mileage. Hopefully some of these mods will allow the truck to not lose as many mpgs with 265/75-16s as a stock truck would
  11. Nov 10, 2009 at 7:45 PM
    ktmrider
    ktmrider Senior Member
    07 DCLB 4x4 Sport S/C
    Junk
    flame stickers 5 hp each you get 5 of them and a few trd stickers and you will be hauling
  12. Nov 10, 2009 at 9:08 PM
    kcbmx
    kcbmx doing my thing.
    Marco
    Bakersfield CaLiFoRnIa
    2tr-fe 4wd
    spit cup, weathertech floor mats, riffle rack, and bilsteins.
    youll loose about 2mpg. i noticed this after trowing some nitto m/t tires.
  13. Nov 10, 2009 at 9:22 PM
    ColtsTRD
    ColtsTRD Well-Known Member
    Scott
    AZ
    x2 :laugh:
  14. Nov 10, 2009 at 9:48 PM
    prerunner05
    David
    middlesex,va
    thanks for the feedback. i was thinking dt headers and manaflow muffler as next mod, but it kinda suxs to hear you dont really notice anything from them.
  15. Nov 10, 2009 at 9:52 PM
    DanGer
    DanGer Avatar approved by 98tacomav6
    Northern Virginia & Blacksburg
    07 Base 4Cyl 4x4 Manual
    White Head Light mod, White shorty antennae, Doug Thorley Long Tube headers, AFE Drop in air filter, Secondary Air Filter Removed,
    Can I ask why exactly you think that and what your rationale is behind that statment?
  16. Nov 10, 2009 at 10:01 PM
    Kelson
    Kelson Well-Known Member
    Kelson
    Honolulu, Hawaii
    08 5-Lug Reg. Cab SR5
    SR5 Exterior/Interior (Color matched Front Bumper, Chrome Grille Surround and Chrome Rear Bumper/Silver Scoshe Dash Kit, A/C Bezel, A/C Vent Surround) LED license plate and white interior lights, Wet Okole Seat Covers, iPad in-Dash, JL CL-RLC, JL 13TW5 sub, JL 500/1 Slash V1 amp, JL XR 6.5 Components, Rockford Fosgate 6X9s in Boxes Front XRunner Coils, DJM Control Arms and Rear 4X4 Leafs, Custom 2" Angled Streetacos.com Blocks Front XR Bilstien Struts and Rear XR Bilstien Shocks, CravenSpeen Antennae, RX-8 Rims w/ Fronts:235/40-R18 Sumitomo HTR Rears:245/40-R18 Goodyear Eagle GT, 35% Tint front windows, OEM Sliding Privacy Glass w/ 5% Ceramic Tint, Flowmaster Super 44 dumped before the axle, URD Short Throw Shifter, Door Sill Protectors, Door Edge Guards, OEM Sport Pedals,The Retrofit Source Morimoto Mini D2S Stage III 35W 5K HID Headlights, OEM Fog Lights w/ piss yellow bulbs, OEM Cruise Control, Porsche 944 Bucket Seats, BeefedTaco Skid Plate, Whale
    my whale adds 100 HP
  17. Nov 10, 2009 at 10:08 PM
    Yoytoda
    Roland
    completely stock
    Im speaking more percentages than actual numbers. The V6 may gain good horsepower but the 4 cyclinder gains the same horsepower but the percentage is higher. ( Ex. a K&N intake gives a V6 10hp which relays to a 3.5% gain. A K&N intake on the 2.7 gives about 8HP gain which is close to a 5% gain in HP over stock)
    Looking under my truck the stock muffler on my 2.7 seems to be quite a bit bigger than the v6 muffler which to me translates to more baffling (maybe in an attempt to mask 4 cylinder buzz) The airbox on the 2.7l also seems larger, however the air inlet to the box is much smaller.
  18. Nov 10, 2009 at 10:12 PM
    DanGer
    That makes sense, but I personally think the stock system is about as efficient as it gets. I agree if anywhere, the muffler would be the "weak" point which is why I recommend to anyone upgrading the exhaust to skip the full catback system and just replace the muffler.
    FWIW chris4x4 dynoed the K&N systems and they all lost HP on his V6. I dont think there is any intake system better than stock for the I4
  19. Nov 11, 2009 at 7:41 AM
    08pretaco
    az
  20. Nov 11, 2009 at 5:53 PM
    prerunner05
    David
    middlesex,va
    idk about some of you other guys, but i installed my afe pro s dry drop in air filter, and secondary filter removal, and i'll be damned it seems i may have lost some acceleration power just don't feel the same. headers and muffler definetly next for me.
