Moving USB to console or glove box?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 12SuperWhiteDC, Oct 2, 2012.
  1. Oct 3, 2012 at 12:50 PM
    ProForce
    ProForce IG @proforce1
    Anthony
    SoCal-Ontario
    09 MGM TRD Sport DCSB 4.0 Auto 2wd
    Too many to list. See build page. Link in signature
    This is what I'd do. Perfect and clean
  2. Oct 6, 2012 at 9:49 AM
    12SuperWhiteDC
    12SuperWhiteDC [OP] Well-Known Member
    West Alabama
    12 DC SR5
    No pics, but I did move the USB port to the glove box this morning. A couple how-to notes:
    -remove the HVAC controls (look to Youtube for video on Tacoma stereo replacement, it's easy)
    -access the back of the USB plug with a thin flat-blade screwdriver
    -press down on the tab that secures the wiring harness to the USB plug and remove the harness (enlist the aid of someone with small hands to help)
    -the USB plug pushes out of the front of the dash (if you get the screwdriver on the top tab holding the plug in you'll have an easier time removing it)
    -the USB plug cannot simply be gutted of its wiring and returned to the dash, and replacement dash "blanks" are about $5 at the dealer's parts counter (part # for 2012 is 55539-52060-CO)
    -a 3' USB extension is plenty to reach the glove box; use a 6' extension if moving it to the console
    -if moving the USB plug to the console, unscrew the shifter knob and pull up on the gear selector cover to remove it (this should give you enough access to route your extension)
  3. Oct 6, 2012 at 8:09 PM
    Onetime27
    Onetime27 Well-Known Member
    Joe
    Columbia Gorge, OR
    16 TRD Off-Road DC
    ^ Good detail! Thanks for the follow up.
  4. Jul 16, 2013 at 9:45 PM
    RobAF
    RobAF Member
    Rob
    Albuquerque, NM
    '13 TRD Double Cab
