MT Accumulator Delete Mod (ADM) and BS Thread
Discussion in '3rd Gen. Tacomas (2016-2023)' started by tonered, Sep 14, 2018.
  1. Jul 10, 2020 at 9:34 AM
    #1741
    Metal Toy
    Metal Toy Well-Known Member
    2021 2.7L AC 4x4
    The dry heat does lessen the blow a bit, but it is still pretty hot. I was in Wisconsin a couple summers ago when it was 90 and high humidity and that was brutal. Much worse than our 100 - 110 days here in AZ.
  2. Jul 10, 2020 at 9:37 AM
    #1742
    tonered
    tonered [OP] bartheloni
    tony
    Lynnwood, WA
    I was in Vegas last year and it was only about 106. I was dying and couldn't get enough water in me. Could barely drink the fun stuff.
    Full nope. The SW is so nice, but it's a nuclear furnace for me.
  3. Jul 10, 2020 at 12:43 PM
    #1743
    MickeyB
    MickeyB Well-Known Member
    '17 TRD OR 6MT 4x4
    Mobtown skids and sliders
    Yep! Where abouts are you going to be? Chandler here, but the entire state below the rim will be toasty! :bananadead:
  4. Jul 10, 2020 at 1:13 PM
    #1744
    Metal Toy
    2021 2.7L AC 4x4
    I am in the east valley also, San Tan Valley area. Forecasting 117 degrees for Sunday now!
    CygnusX191 and tonered[OP] like this.
  5. Jul 10, 2020 at 5:20 PM
    #1745
    TeecoTaco
    TeecoTaco Liberty Biberty
    SW Ontario
    16 Taco DCSB TRD Sport 6MT
    Modified the level of gas in the tank
    Rim? Theres a rim?
    What is this rim you speak of...there is a comfortable part of AZ in July?
    How many creatures want to kill me above this rim, do i have to shovel snow?
    Do tell
  6. Jul 10, 2020 at 5:30 PM
    #1746
    Sixthelement
    Sixthelement Ran over a Yeti once, Texas, never again
    Flagstaff
    24 F150
    Fox 2.0
    They all flock up to Flagstaff. Which under normal circumstances is ok. But with COVID more and more is getting shut down. Either from spreading the infection or trashing the trails.
    But up here it’s fairly temperate with snow in the winter.
    MickeyB, tonered[OP] and TeecoTaco like this.
  7. Jul 10, 2020 at 5:41 PM
    #1747
    TeecoTaco
    SW Ontario
    By snow...do you mean you can see it up yonder in the hills...or you have to shovel it to get out as soon as you open the front door. Im familiar with the latter, not a fan
  8. Jul 10, 2020 at 5:45 PM
    #1748
    Shellshock
    Iowa
    The first time I was in flagstaff, it snowed 2 feet overnight. That’s when I found out it snows in Arizona lol
  9. Jul 10, 2020 at 6:46 PM
    #1749
    Sixthelement
    Flagstaff
    24 F150
    Fox 2.0
    It snows. But clears fairly quick from sunny areas.
    No not Minnesota style snow.
  10. Jul 13, 2020 at 12:27 PM
    #1750
    geekyadam
    geekyadam Game Master
    Adam
    Northern Virginia
    17 SPT MT DCSB
    OME lift, 3leaf AAL, uniball UCAs, 3° shims, CV bushing, U-bolt flip + Superbumps, sway bar relocate, Cooper Discoverer AT3 XLT 33s, cosmetics
    If you can update the original post, here is the correct diagram:
    Just FYI the part 31482D is actually 31482-04140 and can be ordered from any Toyota parts location for about $10 plus S&H...
    https://www.toyotapartsdeal.com/oem...=(1=2GRFKS;4=SR5;6=6F;7=DCB;0=GRN305L-PRFSHA)
    https://parts.toyota.com/p/Toyota_2...INDER-TO-ACCUMULATOR/66802545/3148204140.html
    Hope this helps anyone looking to do this themselves.
    tonered[QUOTED][OP] likes this.
  11. Jul 13, 2020 at 12:38 PM
    #1751
    geekyadam
    Adam
    Northern Virginia
    17 SPT MT DCSB
    DaveInDenver and tonered[OP] like this.
  12. Jul 13, 2020 at 12:39 PM
    #1752
    tonered
    tony
    Lynnwood, WA
    Yes. That is the diagram for the 3.5l. The diagram in the 1st Post is for the 2.7l, as noted, because those folks have asked about the ADM on the 4cyl or about using the hard line from the 2.7l. They don't have the accumulator to do the ADM and the routing is very different. So, both are a no go.
    Just curious why you needed the line from the accumulator to slave? Most folks delete that when doing the ADM.
    CygnusX191 and doublethebass like this.
  13. Jul 13, 2020 at 12:40 PM
    #1753
    tonered
    tony
    Lynnwood, WA
  14. Jul 13, 2020 at 12:43 PM
    #1754
    geekyadam
    Adam
    Northern Virginia
    17 SPT MT DCSB
    Just thought the 3.5L diagram is helpful for those of us with 3.5L, for reference. As some have said you can just bend that line rather than replacing with aftermarket line (in case worried about the flare not fitting right because Toyota has those special ones). So if you bend the one on your truck and want to replace it (or order one to bend and leave yours alone), that's the part number.
  15. Jul 13, 2020 at 12:52 PM
    #1755
    tonered
    tony
    Lynnwood, WA
    From the pics, I think everyone can locate the accumulator? I haven't heard of any issues there since this thread started, except for the 2.7l folks trying to find theirs.
    Are you certain that 31482D will go the distance? My ADM method is the brake line elbow. I don't think the Toyota line is long enough. I had to straighten some of the kinks out of that line just to get it to join up. The 16th pic in the 1st Post is my setup. It was difficult to get the elbow connected.
    If that is what you used, I would be happy to toss it in the first post with the pics.
    In general, my recommendation these days would be to just dremel out the accumulator.
    Just in case, this is the pic that I am talking about:
    moondog1 and CygnusX191 like this.
  16. Jul 13, 2020 at 1:33 PM
    #1756
    disk_55FL
    disk_55FL Well-Known Member
    disk
    Buckeye
    '17 TRD Sport MT
    Is this easier to access if you remove the left front wheel ? Can you reach in from the wheel well instead
    of laying on your back ? Asking for those of us that don't have a lift .... :fingerscrossed:
    tonered[OP] likes this.
  17. Jul 13, 2020 at 1:40 PM
    #1757
    tonered
    tony
    Lynnwood, WA
    I did mine with all four wheels on the ground. Just slide under there. No lift or jack required.
    A vehicle lift would make it easier but is not needed.
    You cannot reach in from the wheel well because the exhaust is in the way. It would be a looong reach also.
    :cheers:
    mtip and CygnusX191 like this.
  18. Jul 13, 2020 at 1:41 PM
    #1758
    moondog1
    moondog1 Well-Known Member
    GA
    01 Prerunner, 04 4x4
    I don't think so. It's also in the middle of the truck kind of. There's a big exhaust bracket in the way that's a pain and that's about it.
  19. Jul 13, 2020 at 1:47 PM
    #1759
    Shellshock
    Iowa
    I just used a jack for some more space because I’m not tiny like tony
  20. Jul 13, 2020 at 1:49 PM
    #1760
    tonered
    tony
    Lynnwood, WA
    6ft and 230-something when I did the ADM. Thanks to this fucked virus situation and my laziness, that is about 245 these days. Too much of it is in the middle.
