MT Accumulator Delete Mod (ADM) and BS Thread
Discussion in '3rd Gen. Tacomas (2016-2023)' started by tonered, Sep 14, 2018.
  1. Sep 14, 2018 at 4:07 PM
    tonered
    tonered [OP] bartheloni
    tony
    Lynnwood, WA
    Hey, Folks.
    Table of Contents
    1. What is the Accumulator
    2. Swapped, Milled Accumulator Service Option
    3. Machined Inner Disk
    4. Plug and Play Delete Kit - Out of Production
    5. Flare Explanation
    6. @sherwoods_Fleet Installation Instructions
    7. Delete Options:
    8. Prefabbed / Salvaged Hard Line Mod
    9. Flex Line Mod
    10. Hack Your Accumulator / Dremel Mod
    11. Brake Line Elbow Mod
    12. Installation Details
    13. PoS Accumulator Pics
    14. 2.7l Clutch Line Diagram
    15. Noise TSB-0186-17
    16. @ShirtTucker 's Metal Pedal Notes
    17. @TeecoTaco Needs Ti for Christmas
    A lot of MT cars / trucks come with some type of accumulator that messes with the clutch feel and engagement. This is said to help newbs learn to drive an MT and reduce shock and wear on the driveline. For anyone that knows how to drive an MT will laugh at this. The last thing anyone needs is system that doesn't follow your commands, is slow, and is inconsistent.
    Removing the accumulator will add some feel to the clutch, speed engagement when you want to, and allow you to modulate the clutch effectively when you need it, such as when downshifting to 1st while moving.
    If you want more feel, faster / direct engagement, and less wear, the ADM is for you.
    :cheers:
    @daveeasa is doing some heavy lifting here. Please, send him some of those old accumulators that are in good condition.
    It's "For The Commuity!!" :rofl::rofl:
    Here are the details:
    3. Machined Inner Disk.
    @Firn came up with a great solution that replaces the wire shim and OE disk from the accumulator. This is a matching machined inner disk that has a cavity to allow free flow. Get yours here:
    A simple, very efficient, and genius solution:
    4. Plug and Play Delete Kit - Out of Production.
    @Trident904 was fabbing formed hard lines including the coupler for this delete:
    https://www.tacomaworld.com/threads/clutch-accumulator-delete-kit.583387/
    This is no longer available. Just leaving it here for history.​
    Sorry for splitting up the installation details, but @sherwoods_Fleet 's instruction are too nice to bury further down. Of courses the PDF is attached at the bottom of this post. I know how to link it right here.​
    7. Clutch Accumulator Delete Options:
    8. 12in Prefab / Salvaged Hard Line and Coupler from autoparts stores / online:
    This is arguably the easiest method, using either scrap brake line or a 12in prefab line (3/16in double flare with M10x1.0 fittings, and an M10x1.0 coupler).
    There are some reports of leaking using the prefab lines. The reason is attributed to the type of flare fittings:
    Toyota Sleeved Fittings:
    Prefab Line Fittings:
    It is felt that the unthreaded portion of the Toyota fittings helps with getting a good seal a the slave cylinder.
    Here are the parts that @Trident904 used:
    You need to form these bends:
    Credit: @fatboyfirebass
    https://www.tacomaworld.com/threads/mt-accumulator-delete-and-bs-thread.568303/page-18#post-19311770
    Credit: @Vitalzone
    https://www.tacomaworld.com/threads/mt-accumulator-delete-and-bs-thread.568303/page-14#post-18976661
    Credit: @TD90S
    https://www.tacomaworld.com/threads/mt-accumulator-delete-and-bs-thread.568303/page-11#post-18959455
    9. Flex Line Mod with a banjo at the slave:
    10. Hack Your Accumulator / Dremel Mod:
    This is the route that @RedBeard1 and I went. Thanks, @RedBeard1 for confirming that this should work.
    I safety wired mine, while @RedBeard1 welded his to the original mounting plate:
    My plan was to use some heat to twist the bracket 90deg for mounting. Edit: don't use heat. It isn't needed.
    Mods to the elbow:
    Original Part:
    Flattened the mount bracket as much as possible without a vice:
    The mounting hole didn't align well.
    I thought a twist might help:
    Nope! Other than giving a nice perch for the safety wire.
    Final setup (the top side is to the right):
    I had to cut off the bracket that extended past the plate so that it would fit on the transmission.​
    12. Installation details:
    I clamped off the inlet line just in front of the firewall.
    I highly recommend removing the exhaust support. It is just 3 14mm bolts, makes dealing with the shield much easier, and allows the use of a straight 10mm line wrench. HF, FTW! My 12pt articulating 10mm was hosed up and almost rounded off the nipple. The HF ones are 6pt.
    3 12mm to remove the accumulator from the transmission. I removed the accumulator (4 10mm) and reused the mounting plate.
    Safety wire!
    I bent the slave line up then back to flex it in to place. I then used various tools to gently flex the slave line away from the mount bolt and transmission.
    Note: Get both nipples started by hand as far in as you can before tightening with a wrench or flexing the lines around for final alignment. You really don't want to cross thread anything here.
    Bleeding was a piece of cake. It seems that the only air in the system was near the slave. Bubbles didn't seem to travel up as the supply continued to trickle?
    Driving, there is a bit more feel. I will post up once I get more miles.​
    13. Adding accumulator pics:
    The circular wire is not a clip. It is a spacer to add preload to the plate and seal.​
    Here it is:
    From toyota.com
    These are all the lines from the firewall to the slave cylinder. It looks like a very different routing. I do not think that Part Numbers 31482 or 31482A would be of any help with the ADM.​
    15. Noise TSB-0189-17
    See the attached TSB. This basically installs a new heat shield with noise insulation installed on the inside. I did this with some Noico sound mat and it really works to keep things quiet, esp in 1st gear.​
    Kickin' write up for the FJC clutch pedal swap:
    17. Hey, @7r41lbr34k3r .
    @TeecoTaco thinks that his life isn't complete without some shiny new Ti Radio Knobs. For him, just one of your knobs is not enough. He needs all the knobs.​
  2. Sep 14, 2018 at 4:09 PM
    specter208
    specter208 Well-Known Member
    California
    2017 TRD SPORT ACLB w/ 6MT TRUCK WHITE
    TOYOTA OEM: Cast Aluminum Running Boards Mud Guards Bed Mat All-Weather Floor Liner NIssan Frontier Sliding Bed Extender
    What do you need that little piece for?
  3. Sep 14, 2018 at 4:12 PM
    9TRDTCO
    9TRDTCO Well-Known Member
    Not that I have a manual transmission, but out of curiosity, what’s does this do?
    Tac0Tic0, SpeySquatch and specter208 like this.
  4. Sep 14, 2018 at 4:12 PM
    tonered
    tony
    Lynnwood, WA
    It goes in place of the accumulator to maintain the existing turn. Standard elbow instead of the gizmo.
    MOC221_ likes this.
  5. Sep 14, 2018 at 4:14 PM
    tonered
    tony
    Lynnwood, WA
    The accumulator decreases clutch throw, slows engagement, and kills most of the feel of the clutch grabbing.
  6. Sep 14, 2018 at 4:36 PM
    su.b.rat
    su.b.rat broken truck
    definitely watching this one. long-term this is one of the main things needing a fix.
    the unfortunate thing is I've got about 10 other super annoying things needing a short term fix before i can enjoy any of it.
    Minerva09, MOC221_ and tonered[OP] like this.
  7. Sep 14, 2018 at 5:04 PM
    ShirtTucker
    ShirtTucker Taco Tip Line: 248-434-5508
    2017 V6 Sport AC MT
    Lots-o-stuff
    Definitely watching the progress of this project. Will do ASAP if all goes well.
    It appears as if it will be reversible for warranty work too, eh?
    Thanks for posting it.
  8. Sep 14, 2018 at 5:14 PM
    tonered
    tony
    Lynnwood, WA
    It should be very reversible.
    Unless they are touching the clutch or transmission, there's no need to worry since it is hidden under a heat shield.
    MOC221_ and shakerhood like this.
  9. Sep 14, 2018 at 5:21 PM
    xxtavixx
    xxtavixx Well-Known Member
    Jacksonville fl
    2018 6MT
    ARB rear locker OVtune Mobtown sliders Core-shifter short throw Trd bro-phony grill Caliraised bumper light bar Caliraised ditch lights Rigid ignite back up lights FN Five Star 16x8 Et0 255/85/16 cooper st maxx MesoJDM fuse box cover MesoJDM led interior lights Bilstein 6112 fronts Bilstein 5100 rears Headstrong 3 aal Toytec 3* shims Mesjodm dome and map lights Diode dynamix ss3 pro yellow Mobtown aluminum front skid 2lo mod SOS front recovery point
    Sub’b for write up and feedback
  10. Sep 14, 2018 at 5:24 PM
    Riding Dirty
    Riding Dirty Sinner; saved by grace
    Before: '16 TRD OR 4x4 AC QS//After: 17 T4R Pro 040
    PlastiDip
    Post pics as you go! Good luck!
  11. Sep 14, 2018 at 5:25 PM
    RocTaco
    RocTaco Free stun!
    Pete
    Green Mtns
    21' SR5 Trail AG
    YASS.
    tonered[OP] likes this.
  12. Sep 14, 2018 at 5:40 PM
    xxtavixx
    Jacksonville fl
    2018 6MT
    If you mske this work, @tonered POTUS!
    MOC221_, tonered[OP] and RocTaco like this.
  13. Sep 14, 2018 at 5:41 PM
    TeecoTaco
    TeecoTaco Liberty Biberty
    SW Ontario
    16 Taco DCSB TRD Sport 6MT
    Modified the level of gas in the tank
    You did say you were running dry on mods...lol
    Giver'
    shakerhood, tonered[OP] and MOC221_ like this.
  14. Sep 14, 2018 at 5:52 PM
    MOC221_
    MOC221_ 3 pedal metal
    Frank
    2019 DCSB Sport M/T Barcelona Red
    vF Tuned; ADM; Core SS
    TY for doing this Tony, very interested in the outcome.
    Since I have no experience bleeding a hydraulic clutch, could you include tips/tricks in that regard if you have time?
    Again, thanks!
    tonered[QUOTED][OP] likes this.
  15. Sep 14, 2018 at 5:53 PM
    tonered
    tony
    Lynnwood, WA
    You don't want me for that! Hahaha!
    LoL! The order was in on this before I posted that. :p
    TeecoTaco[QUOTED] likes this.
  16. Sep 14, 2018 at 5:53 PM
    tonered
    tony
    Lynnwood, WA
    Will do!
  17. Sep 14, 2018 at 6:19 PM
    TeecoTaco
    SW Ontario
    Done yet? :boink:
  18. Sep 14, 2018 at 6:22 PM
    MOC221_
    Frank
    Lol, 'dis guy...
    :boink:
  19. Sep 14, 2018 at 6:25 PM
    TeecoTaco
    SW Ontario
    :wave::wave:
  20. Sep 14, 2018 at 6:42 PM
    MOC221_
    Frank
    Here's the little beasty:
    I noticed that the removal procedure in the SM said to remove the front driveshaft... hoping that can be worked around.
    shakerhood, tonered[OP] and TeecoTaco like this.
