My Differential Breather Mod Photos
Discussion in 'Technical Chat' started by David K, Sep 5, 2010.
  1. Jun 12, 2013 at 1:09 AM
    #321
    David K
    David K [OP] Well-Known Member
    Pala Mesa, California
    2010 4WD Off Road DC
    de nada amigo!
  2. Jun 22, 2013 at 2:23 PM
    #322
    Pearcem87
    Pearcem87 Well-Known Member
    2013 TRD Off Road
    Just finished this mod, routed my breather through my bed cubby. The actual replacement breather valve I got doesn't have much articulation in the little silver cap over the valve, unlike the stock one from the axle, which moves around a lot. There is not a seal or anything, and it will freely spin, but there is not much of a gap. Anything to be concerned about? first time doing a breather relocation with this type of valve. Thanks
  3. Jun 25, 2013 at 6:21 PM
    #323
    David K
    That is the whole point of doing this mod... to put a real breather on the end of a tube, above any deep water line.
    The thing that is on the differential from the factory is a one way VENT... It has a spring loaded seal that takes a pressure build-up in the diff. to push against the little spring, and let gasses vent to atmosphere.
    A BREATHER allows venting AND vacuum breaking! That's the key, to break a vacuum created inside the diff., when you cross a stream... The sudden cooling of a hot differential makes the outside air/ muddy water want to suck INTO the differential, passing the rubber axle seals.
    Yes, it happens... either how I explained or or another way, the differential oil gets contaminated.
    Why does Toyota put a remote breather on the front differential, but not on the rear? Specially on OFF ROAD or 4WD Tacomas...??!!
    This mod put the same breather Toyota has on our front differentials, on the rear... and up high in the bed compartment or the gas fill bay, etc.
    Didn't I cover all this in the first page of this thread? No problem, I like talking about my Tacoma... Hope that explains it, but don't hold back if you have questions!
  4. Jun 25, 2013 at 7:18 PM
    #324
    Frogsauce
    Frogsauce Well-Known Member
    Chesapeake Bay
    16 TRD Offroad
    Hey David, the two breathers that are right next to the battery on an '09 off-road are the Transmission and Front Diff breathers? Or are they something else...
    I'm try to find ALL the breathers on the truck similar to this:
    http://www.tacomaworld.com/forum/off-roading-trails/15093-scuba-mod-relocating-front-rear-diff-tranny-transfer-case-e-locker-breather.html
    But I think two of them are already relocated. Either way, I am running all of them into these instead:
    Specter Breather
    Then I will partially cover those to protect from splash off the fan if it catches water.
    Does that sound sane?
    EDIT: I am running all of them to the driver side front up to a custom bracket I made. Will post pics if this all works out.
  5. Jun 26, 2013 at 8:19 AM
    #325
    David K
    Yes, front diff breather is one of the two by the battery... and your breather choice looks good to me!
  6. Jun 26, 2013 at 8:35 AM
    #326
    Frogsauce
    Chesapeake Bay
    16 TRD Offroad
    What's the other one? :confused:
    I'm going to start it this Friday since I am off. Hopefully, everything turns out nice.
  7. Aug 20, 2013 at 9:52 PM
    #327
    David K
    See this photo, lower red square, by frogsauce:
  8. Aug 21, 2013 at 8:25 AM
    #328
    David K
    FYI: ADD = Automatic Disconnecting Differential. Like 'automatic hubs', but no need to drive in reverse to complete the unlocking. Permits shift-on-the-fly into and out of 4WD-HI, from inside your vehicle, stopped or moving.
    Before the ADD or AUTO HUBS, one had to get out and rotate the hubs from free to lock to use 4WD. Before hubs (old 4WDs), the front driveline rotated even in 2WD.
  9. Aug 21, 2013 at 4:13 PM
    #329
    David K
    I welcome Toyota Tech input... The whole idea of Auto Hubs, the ADD and Selectable Hubs in general is to reduce wear on the front driveline and increase fuel economy. Is one of the two half axles spinning with one of the two front tires, or are both not connected?
  10. Aug 21, 2013 at 4:32 PM
    #330
    David K
    I hope nothing! The spinning would come from the front tires rolling since the transfer case is in 2WD.
    If someone could mount one of those web cams under the truck and drive in 2WD, we can see if either front half axle or front drive shaft rotates with the tires or just a little from centrifugal force... ???
  11. Sep 18, 2013 at 5:45 AM
    #331
    Frogsauce
    Chesapeake Bay
    16 TRD Offroad
  12. Sep 28, 2013 at 12:09 AM
    #332
    David K
  13. Oct 4, 2013 at 9:38 AM
    #333
    gonathan85
    gonathan85 Well-Known Member
    Nate
    Central California
    '13 4x4 SR5 V6 Tacoma
    Mod completed! For those of you who elected to locate the new breather in the gas cap compartment, did you have trouble drilling a hole for the hose to protrude through? I chose the rubber grommet method, and it came out clean.
    Drilling a 5/8" hole at a funny angle (due to gas door) in the plastic was somewhat precarious. I started with a 1/4" bit, after using an electrical tester to create a pilot "dimple" in the plastic. Then, I progressively stepped-up the bit size 4 more times with 4 slightly larger bits to eventually end up with a 5/8" hole. I used a 31/32 x 1/2 rubber grommet purchased at Lowes #139377 to give a clean factory finish. Also used a 1/4" to 5/8" #4 SS clamp to secure the 5/16 ID fuel line to the threaded barb fitting. :thumbsup:
  14. Dec 26, 2013 at 9:26 PM
    #334
    totmacher
    totmacher automotive hypochondriac
    Daniel
    TN (memphis-ish)
    Toyotas
    Cut & broke off stuff. Prolific ziptie and tape usage.
    Just FYI, that yellow high pressure hose on pg 1, 3/8 in x 5/8 out, is clearance item at Lowes now. I think it was $0.66 per foot when I got it today.
    They had some red air line hose that I assume would work too if you just don't like yellow.
  15. Dec 27, 2013 at 3:27 PM
    #335
    David K
    You don't see the hose unless you are under the truck, so color doesn't matter. However, the yellow sure made it nice to show the install!
  16. Mar 19, 2014 at 5:22 PM
    #336
    jtacoma1
    jtacoma1 Active Member
    J
    South Orange County, CA
    '11 Tacoma DC 4x4
    Thanks for the MOD right up. Did such a good job selling me on the benefits of the breather for the rear now I'm thinking I should change the breather in the front to the two way - similar to the part that the MOD called for in the back.
    Correct me if I misunderstood, but it seems like the front diff breather is only a one-way valve and not a "true breather".
    I understand that the front will not get contaminated due to its height compared to the rear, but being a one way valve can't it create a vacuum at one point?
  17. Mar 20, 2014 at 9:23 AM
    #337
    David K
    NO! The front breather is fine... it is the model we use for the back in this mod!!!
    That's one of the things that makes it seem so crazy that Toyota does... the good (2-way) breather in front, and a one way exhaust valve on the back!
  18. Mar 21, 2014 at 5:37 AM
    #338
    jtacoma1
    J
    '11 Tacoma DC 4x4
    Understand. Thanks for taking the time to answer.
  19. Mar 25, 2014 at 10:46 AM
    #339
    David K
    No problem... anytime!
  20. May 23, 2014 at 1:53 PM
    #340
    UTdez23
    UTdez23 Half Baked Dez Cruiser
    Jesse
    SLC, UT
    09 4x4 SR5 DCLB
    Bilstein 5100's front & rear, Eibach 620 lb Coils, Dakar Leaf Packs, Rear Diff Breather Mod, All Pro Sliders, RCI IFS Skid
    Just finished this mod!! Thanks to everyone's tips and descriptions. Was super easy.
