My last post I promise!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TOYOTA 09, May 9, 2011.
  1. May 9, 2011 at 8:00 PM
    TOYOTA 09
    TOYOTA 09 [OP] Kicking Ass Since 1981
    Maine
    2009 SR5 MT 4x4 Access Cab
    Preview 2009 SR5 4x4 MT Black Sand Pearl (Access Cab) SUSPENSION ToyTec 5100 Billstein Coil Overs (3" Lift) Fox 2.0 Remote Res Rear Shocks Total Chaos UCAs Full Dakar Leaf Pack w/Extra AAL TIRES & WHEELS BFG AT KOs 265/75/16 load range E American Rancing AR-23 Wheels Borla CAT back exhaust AFE cold air intake w/custom TRD clear cover Satoshi grill w/Grill Craft insert Hella 500 behind grill lights Rigid Industries Backup lights Interior Custom LEDs and Bed Lights Backup Cam Anytime MOD Leather armrest and rear seat MOD Weathertech floor liners Custom rear gear/dog platform Cobra CB and Garmin GPS Bed Mat UWS low pro tool box with Custom LED lights Diff breather MOD Custom painted engine cover Wet Okole seat covers
    You guys have been very patient with my postS over the past few days, as I am trying to finalize my wheel / tire upgrade. After long hours on the Internet I have finally come down to this wheel / tire upgrade for my 2009 4x4...
    BFG A/T 265/70/17 on XD revolvers: 17x9 with -12 offset.
    I am good to go with this upgrade even though I dont have a lift? Or will there be rubbing?
    Last post I promise.....the the next post will be pics of the upgrade.
    Thanks for all the help!
  2. May 9, 2011 at 8:11 PM
    Superx2
    Superx2 Well-Known Member
    Joey
    Iowa
    dude! who cares if you post anymore thats what TW is here for. screw people who give ya shit. (unless they are moderators) :cheers: sorry but i cant answer your question.
  3. May 9, 2011 at 8:15 PM
    tostidos
    tostidos Well-Known Member
    Apple Valley, CA
    07 LT 6spd
  4. May 9, 2011 at 8:16 PM
    OZ-T
    OZ-T You are going backwards
    Peter North
    British Columbia
  5. May 10, 2011 at 3:10 AM
    chad68
    chad68 Master Jedi Member I am...
    Chad
    In a (Toyota) van down by the river! Sonoma Cownty
    2009 4x4 reg cab. Modded with more to come
    Polished 16x8 Pro Comp 1069's 4" BS Nitto Mud Grapplers 305/70/16 Magnaflow & glasspack muffler Stainless tip K&N 63 series Aircharger Vent visors Autometer volt and dig. temp. gauge custom mounted Factory chrome rear bumper (not black factory, one) TRD pedal covers TRD skid plate Hurst T handle shift knob Rear Tint Clear bra on the sides Chrome extinguisher Icon non resi coilovers, ICON RR shocks, black seat covers. And some other crap
    No you pretty much say screw them too.
    A 265 tire IMO and by most tire manufacturers is too narrow for a 9" wide wheel.
  6. May 10, 2011 at 3:19 AM
    TOYOTA 09
    Maine
    So everyone here with the xd revolvers are running 285s?
    I think the bfg at has a cross section of 10.5? That would give me at least 1/2 inch of rubber on either side of the wheel....maybe I should look for 17x8's?
    Problem is I'm really looking for. -12 offset for a wider stance and I don't wanna run spacers...
  7. May 10, 2011 at 6:39 AM
    bjmoose
    bjmoose Bullwinkle J. Moose
    San Jose CA
    '11 Std Cab 4x4 5sp
    I wouldn't go past the recommended rim width for the tire I was running.
    With -12 offset and a 32" tire (265/70R17=32" diameter) you'll likely have to remove your front mudflaps.
    As always, YMMV and objects in the mirror are closer than they appear.
  8. May 10, 2011 at 8:19 AM
    tostidos
    Apple Valley, CA
    07 LT 6spd
    If you go with that size tire without s lift I almost guarantee you will be rubbing.
  9. May 10, 2011 at 12:30 PM
    TOYOTA 09
    Maine
  10. May 10, 2011 at 12:34 PM
    OZ-T
    Peter North
    British Columbia
    You can run 265/70/17 on the stock wheels and stock suspension with no rubbing , I did for about a year and a half .
    I was also able to clear my mudflaps .
  11. May 10, 2011 at 12:38 PM
    tostidos
    Apple Valley, CA
    07 LT 6spd
    I did tons of research too and thats why I bought the 265/70/17 and just letting you know I rubbed quite a bit with 265/70/17s I dont know if it was entirely because I had 1" wheel spacers but when I turned the wheel in any direction I rubbed at about 75% to the turning stop. If you offset is going to give you that "wider" look it may rub.
  12. May 10, 2011 at 12:40 PM
    OZ-T
    Peter North
    British Columbia
    On stock wheels ?
  13. May 10, 2011 at 12:45 PM
    97yota4wd
    97yota4wd Well-Known Member
    Eric
    Mesa, AZ
    alot of metal, small engine, decent travel.
    caged, camburg long travel, 50t leafpack (soon to be installed) light rack over cab, 5pt harnesses etc
    when you have wheels that are wider than stock, more offset, or a wheel spacer it increases the chance of rubbing because the turning diameter is more. as a reference.. i had 31s on my stock wheels with no rub, i put on 15x8 wheels with 4.5mm offset(i think) i rubbed at full lock with the steering wheel on the drivers side. then i got the bright idea... if i buy wheel spacers i wont rub anymore!!!! yeah no. it rubbed 10000 times worse because the turning radius is more. hopefully this helps
  14. May 10, 2011 at 12:49 PM
    Reaper10
    Reaper10 Well-Known Member
    Brandon
    Oak Harbor, Washington
    '10 Silver DC 4x4 TRD OR
    Billstein 5100's all around, ToyTec coilovers up front, ToyTec 1.5" AAL in the rear with TSB leaf springs, Light Racing Upper Control Arms, XD Revolvers in Black wrapped in 265/70/17 BFG TA/KOs, AFE Pro Dry S Airfilter, Pioneer AVIC-X920BT in-dash NAVI, Devil Horns by Andres, 14 inch shorty antenna
    I've got the 17 x 9 revolvers wrapped in 265/70/17 BFG/s No problems at all over the last 8000 miles. Because of the offset of the rim they rubbed, mostly in reverse. Even with the coilovers up front I still had to do some trimming of the plastic fender liner to avoid rubbing at full lock in reverse and when the tires are stuffed. Even after all of that with that tire and wheel combo I still occasionally rub the rear fender liner with the coils compressed and in a turn. For the life of me I don't understand how guys are running those big ass tires and getting full articulation from the suspension.
  15. May 10, 2011 at 12:51 PM
    TOYOTA 09
    Maine
    Ok I think I'm am understanding...I can run the 265/70 or 265/75 on STOCK wheels with no rubbing, but if I get a wheel with an offset like the XD REVOLVERS, I would most likely rub without a lift. So if I wanna upgrade my wheels I should go with a 0 offset wheel.
  16. May 10, 2011 at 12:52 PM
    tostidos
    Apple Valley, CA
    07 LT 6spd
    No they were KMC xd222 wheels. and yes that makes sense but the OP was saying how he wanted that wider look so he was getting a -12 OS. im not sure how far that is but if its anywhere wider I have a feeling he will be rubbing. I believe the OP was talking about getting after market wheels KMC XDs too. Just wanted to share my experince so he gets it right and doesnt have to spend the extra moolah like I did.
  17. May 10, 2011 at 12:53 PM
    TOYOTA 09
    Maine
    So you are running a lift?
  18. May 10, 2011 at 12:54 PM
    tostidos
    Apple Valley, CA
    07 LT 6spd
    no do not get a 0 offset wheel you will not clear your calipers. and then you will have to put a wheel spacer on which is exactly what I ran into. I dont know exactly what you need to clear the caliper but it isnt much maybe 3-5mm?
  19. May 10, 2011 at 12:54 PM
    TOYOTA 09
    Maine
    Anyone know of a nice aftermarket wheel close to the stock steel specs... Looking for anything but black
  20. May 10, 2011 at 12:54 PM
    jjew18
    jjew18 the Nightman cometh!
    Alliance Airport
    05 PreRunner SR5
    Added extra awesomeness to its original awesomeness.
    Dammit OZ, why would you ruin a perfectly good thread with this filth?
    Winner goes all the way!
