My Tacoma Vibrates at 25-35mph ??? HELP
Discussion in 'Technical Chat' started by kills4kiks, Mar 13, 2012.
  1. Mar 13, 2012 at 10:24 PM
    kills4kiks
    kills4kiks [OP] Well-Known Member
    Adam
    CALI
    05 PreRunner SR5
    murdered out, Halo H.I.D. Head lights, Icon coilovers, aal, pro comp 3000 struts, powder coated rims, Hella Black Magics
    my trucks auto but when its in 2nd gear around 25 - 35 mph my truck vibrates. only when i apply gas. if im coasting it dosent vibrate. i was thinking its the transmishion going out, drive shaft, or motor mount
    anyone have this problem b4 ? HELP PLZ:(
  2. Mar 14, 2012 at 10:31 PM
    Texoma
    Texoma IG: Triple C Chop Shop
    Chris(Topher)
    Lago Vista, TX
    10 Taco 4x4
    A bunch a cool stickers, a bada ass MetalMiller Tx Longhorns grill emblem painted Hemi Orange, JBA long tube headers with o2 sims, Diff breather mod, Red LED interior lights, Fancy head unit that plays ipod n movies, Also DIY install factory stuff like, factory cruise control, factory intermittent wipers, OME nitro struts with 886x springs and toy tec top plate, JBA high caster UCA's for better alignmnet and dey beefier too, Old Man Emu Dakar leaf springs in da rear with the gear, U bolt flipper, Ivan Stewart TRD rims with 33" K Bro 2's, some bad ass weather tech floor liners so I don't muck up my interior, an ATO shackle flipper for mo travel in da rear wit the gear, also super shiny Fox 2.0 shocks back there too, all sorts of steal armor for bouncing off of the rocks like demello sliders, AP front skid, trans skid, n transfer skid, demello gas tank skid, and a tough as nails ARB bumper with warn 8k winch, I'm sure there's more
  3. Mar 14, 2012 at 10:32 PM
    ColtsTRD
    ColtsTRD Well-Known Member
    Scott
    AZ
    Get your u joints checked
  4. Mar 14, 2012 at 10:33 PM
    LAoffroadin
    LAoffroadin BURY ME WITH MY TACO!!
    Joshua
    Northwest
    2012 offroad 4x4
    ICON stage 5 coilers w/ ICON ucas, dakar leaf pack with Fox rears, k&n cai, LED cab light, raceline 16 inch wheels , toyo m/t 33",painted front yota emblem gloss white, retrofit headlights with mirrimoto 3 " lenses running the 6k headlights. Bhlm, bestopper, wet okole seat covers (max 4), weather tech mats,winch with piaa fogs. All pro apex front bumper. Sliders etc
  5. Mar 14, 2012 at 10:35 PM
    ColtsTRD
    Scott
    AZ
    I had the same vibes and all 3 of my u joints were bad and my carrier bearing!
  6. Mar 15, 2012 at 8:16 AM
    kills4kiks
    Adam
    CALI
    05 PreRunner SR5
    how much did that cost to fix and where did you get it done ... i looked under my truck yesterday and the rear transmison mount was broken im going to replace that first i hope that solves the problem
    Thanks for all your guys help!
  7. Mar 15, 2012 at 7:54 PM
    Texoma
    Chris(Topher)
    Lago Vista, TX
    10 Taco 4x4
    That's probably it.
  8. Mar 16, 2012 at 6:07 PM
    kills4kiks
    Adam
    CALI
    05 PreRunner SR5
    i replaced the rear trans mount ... helped alot ... but now i think i need to replace the u joints and carrier bearing as well -_- it still vibrates and has a squeek to it =(
  9. Mar 21, 2012 at 9:18 AM
    kills4kiks
    Adam
    CALI
    05 PreRunner SR5
    Just an update if anyone else has this problem it ended up being a rear transmission mount and the rear U Joint
    Now she rides like new!
    PS super easy Do It Yourself!
  10. Jul 8, 2013 at 9:44 AM
    BigBro
    BigBro Husband & Daddy ;)
    Carson
    Atlantic Beach, FL
    2005, PreRunner, SR5, Crew Cab, Radiant Red
    Anytime Fog light mod, Rack Mounted OffRoad Lights, Rear Mounted Bed/Reverse Lights, Painted Hood Cover, Painted Lower Front Bumper, Replaced Rear Bumper from chrome to black.
    Having the same problem. Right around 30-35mph crazy vibrations. Just got my tires rotated an balanced and it didn't go away. I have an 05 Prerunner.... So its going to be my U joints?? For the guy that isn't sure what those are...... Is it still a good DIY? I did replace my front wheel bearings my self about 20k miles ago.
  11. Jul 9, 2013 at 8:47 AM
    kills4kiks
    Adam
    CALI
    05 PreRunner SR5
    Check out this video it might give you a better idea of what you're up against!
    If I were you I'd replace all 3 U-Joints ... I only replaced one and I ended up having to replace the other 2 shortly after.
    P.S. Don't get Cheep U-Joints from AutoZone ...Do it right the first time and Get them from Toyota!!!
    Also if you have a manual press use a press not a hammer to put the U-Joints back in place.
    3 part video
    1) http://www.youtube.com/watch?v=6tJWEVGqP6s
    2) http://www.youtube.com/watch?v=Udm39WHuiHw
    3) http://www.youtube.com/watch?v=DekWjflBfp4
  12. Oct 9, 2018 at 4:44 PM
    Kylewisee
    Kylewisee Member
    Kyle
    2006 Trd sport
    6" lift 2015 front end swap 20x12 XD riots 35” trail graps Db customz grille CW custom lights
    Do y’all know what the problem could be for me, it vibrates bad around 25-35 and I just had a one piece driveshaft built for it so I know it can’t be the U joints since they are brand new
  13. Oct 9, 2018 at 5:07 PM
    Texoma
    Chris(Topher)
    Lago Vista, TX
    10 Taco 4x4
    Would help to know what else is done to your truck along with any other maintenance and replacements you've done recently, and how many miles you have.
  14. Oct 10, 2018 at 6:38 AM
    Kylewisee
    Kylewisee Member
    Kyle
    2006 Trd sport
    2006 with 160,000 miles, one piece driveshaft and it has a new rear end
  15. Oct 10, 2018 at 6:41 AM
    Texoma
    Chris(Topher)
    Lago Vista, TX
    10 Taco 4x4
    No lift? Stock wheels n tires? Never replaced ball joints, tie rods, or any bearings? Why new rear end? Was it bent? Or do you mean you regeared? If so, who set the gears up?
