N/A vs TRD S/C
Discussion in 'Performance and Tuning' started by s7racing, Aug 19, 2012.
  1. Aug 20, 2012 at 1:44 PM
    MadToy
    MadToy Well-Known Member
    Nick
    Huntersville, NC
    07 Midnight Blue TRD
    OME 886, Dakar leafs, LR UCA's, 16x8.5 Level 8 ZX, 315 MTR Kevlar, All-Pro sliders, BudBuilt skids, Undercoverhwms winch mount, Warn M8000 with synthetic rope, ATO Hi-Lift bed mounts, Diff locker override, Hitch harness relocated to bumper, Undercover bed cover, Gromm Aux adapter, Grillcraft grill, DT pipe bombs, Custom Magnaflow exhaust, Brute Force HC bumper, TRD Supercharger
    When calculating the cost of an N/A build, you need to add the X1 or UCON to the cost. You'll notice that all of the guys running good N/A numbers have the X1 (which also changes cam timing). All of those parts, without an X1 or UCON would probably be hardly noticeable in power gains. It's the tuning that brings it all together.
  2. Aug 20, 2012 at 3:17 PM
    Lucario Runner
    Lucario Runner Resident Truck/SUV racer
    Robert
    San Antonio, TX or nearest race track
    06 Toyota 4Runner
    AFE stage II intake, APR X1, URD 70mm Throttle Valve (ported and knife edged), NST intake manifold spacer, URD spec U headers, Denso IKH20, URD fuel pump, APR fuel rail, URD Y pipe, URD spec u catback, lightweight water pump pulley, Greddy sandwich cooler plate, Earls oil cooler, IPT valve body, FJ TRD shocks, Cusco front and rear sway bars, Energy Suspension rear track rod bushings and rear link bushings, Carbotech pads, Stoptech ss brake lines, Stoptech slotted rotors, Motul 600 rbf, Limited Grill, Painted hatch cover by me, Painted valve covers by me, Cobra CB, TRD rad and oil cap, Escort 8500, Autometer oil psi and temp gauges, AEM wideband afr gauge, Flexpod, Pioneer 400w speakers.
  3. Aug 21, 2012 at 11:53 AM
    TRD2006
    TRD2006 Well-Known Member
    stock 2006 4x4 TRD Sport
    I want the TRD supercharger, but IMO nothing is better that RAW v8 horsepower and not having the use of nitrous or turbo or superchargers.
  4. Aug 21, 2012 at 6:00 PM
    bongwhisperer
    bongwhisperer Well-Known Member
    horn that plays "la cuka racha,"
    I don't think you would get that gain even if you had all of the above that you just mentioned.
    http://www.youtube.com/watch?v=lPgcIGOsIhQ
  5. Aug 21, 2012 at 9:27 PM
    s7racing
    s7racing [OP] Well-Known Member
    There is a dyno in this thread http://www.tacomaworld.com/forum/performance-tuning/229882-n-power-gains-dynos-w-mods.html, with that exact setup plus nst pulleys and he pulls 241 rwhp. Stock is 190-200 so seems like you can. Only variable there is the nst pulleys, how much do those help?
    Any ways I just placed an order for my headers, intake and maf cal. I'll give a honest opionion of these mods and let you guys know if it's worth it or not.
  6. Aug 22, 2012 at 4:20 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    To complement s7racing, Lucario Runner just had a new dyno done, with the addition of the URD y-pipe. Referenced in this thread, and the last page of the thread s7racing linked.
    He is up to 245whp and 295 wtq, with Dtlt, URD Y, TRD intake, and X-1.
    That is 40 whp right there.
  7. Aug 29, 2012 at 6:44 PM
    s7racing
    So far I've got the intake and maf cal on. I did the intake first and drove around for a day, noticed much better throttle response with smudge more top end pull. With the maf cal it now pulls harder all the way through the rpm's, really impressed with this. Gonna put the headers on tonight.
  8. Aug 29, 2012 at 10:40 PM
    s7racing
    Finished headers up, for as easy as the passenger side goes on the driver side makes up for it ten fold. What a bitch!! Overall took about 2.5 hrs and was actually pretty fun. It's def faster than stock now throughout the rpm range, with most notable gains above 3k as expected. I'm happy, can't wait to go rip the sand dunes!!
  9. Aug 30, 2012 at 8:23 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Which year is your truck s7?
    Also, could I entice you into getting a dyno on a DynoJet? ;)
  10. Aug 30, 2012 at 8:43 AM
    s7racing
    2009, I would be interested in getting a dyno and looked into it to do a before and after. Unfortunately I live in Humboldt county and the nearest one is about 200 miles away. I might do it around Xmas when I'm in SoCal for a couple weeks.
  11. Aug 30, 2012 at 8:53 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Oh wow! Butt dyno will do good then. ;)
  12. Aug 31, 2012 at 9:27 PM
    s7racing
    So I've gotten a lot more seat time with these mods now. All this talk about loosing low end power is comical. Power is drastically increased throughout. I was driving a curvy mountain road and the difference in power while in third gear between 2-3k is amazing. In 6th gear I can maintain 75 up a steep highway grade with ease, before I would slow to around 65 by the top of the grade.
    I also did some pulls next to my buddies 07, we are both six speeds, I have 285/75/16's while he's on 265/70/17, he used to blow the doors off my truck, now I'm pulling him.
  13. Aug 31, 2012 at 9:30 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Glad to see the lid to the box has been opened for another, on the 1gr. :). Those few mods makes a big difference. :thumbsup:
