N-Fab Light bar and Baja Design Lights installed
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TRDProBuddy, Aug 23, 2015.
  1. Aug 26, 2015 at 6:39 PM
    JPA2002
    JPA2002 Well-Known Member
    Roanoke, VA
    2021 DCSB TRD Pro
    Pics of my switches are in this thread.
  2. Aug 26, 2015 at 6:45 PM
    TRDProBuddy
    TRDProBuddy [OP] Well-Known Member
    MD (Kent Island)
    2015 TRD Pro (Inferno)
    Nope, I bought 2 of the inline holders and 4 of the diodes, I wanted to have a couple of spares
    Diodes were $1.35 each
    Inline Holders were $1.74 each
    You get a price break if you order more, but only a few pennies
  3. Aug 26, 2015 at 6:50 PM
    JPA2002
    Roanoke, VA
    2021 DCSB TRD Pro
    Well, they want me to order 5 holders and 4 diodes.
    Jon
  4. Aug 26, 2015 at 7:13 PM
    JPA2002
    Roanoke, VA
    2021 DCSB TRD Pro
    If anyone needs a holder and diode, let me know. I had to order 4 diodes and 5 holders.
    Jon
  5. Aug 26, 2015 at 7:30 PM
    TRDProBuddy
    MD (Kent Island)
    Not sure why? Maybe cause I ordered a few other things along with those
  6. Aug 26, 2015 at 8:34 PM
    dzcustom
    dzcustom Well-Known Member
    2015 Tacoma PreRunner SR5 V6 BRM
    Nice setup. I wanted to go with this N-Fab light bar (without the LED light) as well and mount some mini Amber or yellow lights (still researching as to which) on each end.
    How are you enjoying the lightbar and winch setup?
    Also, what winch setup is that?
  7. Aug 26, 2015 at 9:04 PM
    Poindexter
    Poindexter Well-Known Member
    north of Denali
    15 V6 auto 4x4 mag gray
    I am confused about the diode. The switch schematic shows the diode installed in a switched ground system, but our 2015s use a switched positive system for hi-lo switching, see my recent H4 thread in tech chat.
    I repeated my findings with test points on an H4 extension. That is I stripped a little bit of wire on all three legs of the extension...
    Let me get on my pc with the rwal keyboard
  8. Aug 26, 2015 at 9:39 PM
    Poindexter
    north of Denali
    Ok, so the pinout on my H4 connector is pictured in this thread. I built this table plugging into the H4 connector on the factory wiring harness with the headlamp disconnected. https://www.tacomaworld.com/threads/need-confirmation-h4-pinout.386322/
    Then I bought some H4 extensions like these:
    http://www.eachbuyer.com/h4-male-to...USD&from=pla&gclid=CJDwtdWzyMcCFZBcfgodAOYDyA
    I stripped a bit of wire on each of the three conductors, soldered in test leads and taped everything up so I could install the extension between the factory harness and the factory headlight, and then repeat the testing with the headlight in the circuit, but without having to worry about shorting anything out.
    The data is the same. My 2015 uses a switched positive system for the hi-lo headlamps.
    You certainly could provide a switched ground with your AoB switch to power your new LEDs out on the Nfab bar...
    OTOH your car audio link shows a quenching diode across the coil terminals of the relay rather than inline with the switch. That probably is a good idea given the amount of electronics in our trucks. There may very well be a switching transistor between the switch on the stalk and the head lamp bulb. Cheap insurance for the money.
    I am attaching the schematic for my lights in sharpie with where I am going to put a quenching diode in pencil...
  9. Aug 26, 2015 at 9:55 PM
    Ajak
    Ajak Well-Known Member
    ATX
    '07 DCSB Indigo Ink
    You been pulled over yet for blocking the license plate?
  10. Aug 26, 2015 at 9:57 PM
    Poindexter
    north of Denali
    Its prertt common up here, to bloxk the front plate with moose lights. If i get a ticket ill just move the plate down.
  11. Aug 27, 2015 at 10:37 AM
    stump jumper
    stump jumper Well-Known Member
    Bill
    Texas
    2017 Tundra 4x4 CM TSS
    no, shortly after I installed the bar I moved the license plate down. I bought a flat plastic holder at Auto Zone and zip tied to the lower grill. I did not think the plate would look right mounted on the bar and also worried that it would be flopping in the wind.
  12. Aug 27, 2015 at 11:12 AM
    Gasturbine
    Gasturbine Well-Known Member
    Central Ohio
    2011 Regular Cab 2.7l 5-speed 4WD
    32" BFG KO tires on MT rims, Front lifted 2", N-Fab 12,000lb front pull point w/10,000lb red clevis, mud flap delete, tail pipe delete, 20" LED light bar, 2 Hella 500s, N-Fab light bar mount, tinted windows.
    The N-Fab bar is nice. Top quality, good powder coating, solid (no vibration, even at speed) and is mounted like a tank!
    It will also support lights up to 9" which is nice because I run 2 Hella 2000 rally lights.
    Jessrin likes this.
  13. Aug 27, 2015 at 6:12 PM
    JPA2002
    Roanoke, VA
    2021 DCSB TRD Pro
    I like the lightbar and light. The winch is a Smittybilt XRC 9.5K, and honestly, I haven't used it yet. I put the rope on, rolled it in, and that was it.
    The lightbar has several places to mount various configurations of lights.
    Regards,
    Jon
    dzcustom[QUOTED] likes this.
  14. Aug 27, 2015 at 7:40 PM
    dzcustom
    Thanks for the info. Much appreciated. I am still doing some research on how I want my setup.
    How did you mount the winch?
  15. Jun 9, 2016 at 8:57 PM
    #35
    NMPatronis
    NMPatronis Well-Known Member
    Nick
    Plainfield Illinois
    2012 MGM DCSB TRD Off Road.
    Working on it!
    I was wondering the same thing did you use the undercover winch mount? Any issues with the winch or light bar mounted so close together?
    Thanks,
    Nick
  16. Jun 10, 2016 at 10:27 AM
    #36
    stump jumper
    Bill
    Texas
    The light wire to the HVAC and shifter backlighting is green with white stripe. I would think the seat heater switch wire is the same color. I am going to change mine out this summer and use some that are illuminated. I was going to pull the HVAC panel but sounds like that I do not need to do that.
  17. Apr 19, 2021 at 2:28 PM
    #37
    pavement.is.lava
    pavement.is.lava Well-Known Member
    SLC, UT
    2015 DCSB TRD OR 6MT
    285/75r16 KO2s, Dobinsons 3” lift, BAMF bumper/sliders, skids, Allpro Rack
    What winch mount is this? I'd like to combine the other light bar with the U.S. Offroad hidden winch bumper, but am trying to understand how it will all co-mingle.
