n0rth's Tacoma build
Discussion in '2nd Gen. Builds (2005-2015)' started by n0rth, Sep 20, 2010.
  1. Oct 9, 2013 at 10:14 PM
    #941
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Another sac truck!
  2. Oct 9, 2013 at 11:18 PM
    #942
    IDtrucks
    IDtrucks Unhinged and Fluid
    Mark "Buck"
    Jackson Wyoming
    where in the 48 pages are pics of your tub?
    jk. i think i found it. but i didnt see any pics of you actually cutting stuff out
  3. Oct 9, 2013 at 11:23 PM
    #943
    Blackdawg
    Monte
    Wyoming/St. Louis
    Why would you look at a 2nd gen tub job for reference anyways mark haha
  4. Oct 9, 2013 at 11:23 PM
    #944
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    just getting ideas man :cool:
    seeing how others do it
  5. Oct 9, 2013 at 11:27 PM
    #945
    Blackdawg
    Monte
    Wyoming/St. Louis
    ...again.
    Why are you looking at 2nd gens haha totally different. Go look at mrbeggins build. Best tub job I have ever seen.
  6. Oct 10, 2013 at 7:07 AM
    #946
    NYCO
    NYCO go explore...
    bOb
    Colorado
    Blue Betty - '06 TRD OR
    dents & scratches
    yea i'm looking to get a set of TC stock length LCAs and was looking at a set of coilovers for the setup, but it's hard to justify that much $$ in coilovers when my OME is doing great..
  7. Oct 10, 2013 at 7:58 AM
    #947
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    he really is, isnt he?
  8. Oct 10, 2013 at 8:13 AM
    #948
    n0rth
    n0rth [OP] Well-Known Member
    J.W.
    New Mexico
    2019 Tundra Platinum
    2009 Tacoma Access Cab SR5, 4wd, 2.7L URD S/C, 4:88's ARB lockers, 36x9.8r16 Radial TSL
    Not any time soon, but getting the most out the rear suspension is a step in the right direction towards that eventual goal.
    I went through all kinds of threads looking at how folks clearance their junk. I never went with an actual tub just a BFH and some cutting tools and have worked on 2 1st gens doing the same thing with good results. You wouldn't want to burn your truck down cutting and welding:eek:
    http://www.tacomaworld.com/forum/2nd-gen-builds/114291-n0rths-tacoma-build-5.html#post2406252
    http://www.rocksolidtoys.com/forum/showthread.php?t=248&page=12
    Agreed, I picked a set of ext. Icons at one point in time and ended up sticking with the OME set-up then. My current set up seems to be doing just fine I like that things are pretty simple but every time I look there are new things I want.
  9. Oct 10, 2013 at 8:28 AM
    #949
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    :rofl: so you didnt do any welding? You just liberally beat the fuck out of it?
  10. Oct 10, 2013 at 8:39 AM
    #950
    n0rth
    J.W.
    New Mexico
    Pretty much, cut the pinch weld and zippered it back, beat it flat and used some spray on bed liner to seal it and called it good.
  11. Oct 10, 2013 at 10:01 AM
    #951
    n0rth
    J.W.
    New Mexico
  12. Oct 10, 2013 at 10:54 AM
    #952
    JLink
    JLink Well-Known Member
    Josh
    Ocean, NJ
    Lifted, Locked, Armored. Ready To Wheel.
    So jealous of the area you get to explore
  13. Oct 10, 2013 at 2:20 PM
    #953
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    for some reason I cant imagine how 36s fit by just hammering it (given the 1"bl)
    why does everyone bother tubbing if you can hammer it into clearance:confused:
  14. Oct 10, 2013 at 2:22 PM
    #954
    Blackdawg
    Monte
    Wyoming/St. Louis
    cause....
    2nd
    gen
    only 2nd gens i have seen really tub are not running BL and have 37s
  15. Oct 10, 2013 at 2:23 PM
    #955
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    FUDB
    he said in the 1st post 2 1st gens did it
    but fine
  16. Oct 10, 2013 at 2:39 PM
    #956
    Blackdawg
    Monte
    Wyoming/St. Louis
    :D <3
    i know Silas rode around with just hammered fire wall for a while on his AT 35s. But couldn't offroad with them.
  17. Oct 10, 2013 at 3:47 PM
    #957
    n0rth
    J.W.
    New Mexico
    Thanks
    You start hammering when that no longer works you begin tubbing, the 2 first gens I talked about both had 6" lifts one on 33's and the other on my old 315/75r16 MTR's.
    I've considered tubbing the truck but haven't needed to with the lift, BL, trimmed fenders some cutting/hammering and bump stops etc..... The other thing is skinnier tires less area affected inside the wheel well on a stock rim, I still rub but overall it works pretty damn good.
  18. Oct 10, 2013 at 5:22 PM
    #958
    BradyT88
    BradyT88 Well-Known Member
    Are your FJ wheels the same back spacing as the OEM Tacoma wheel?
  19. Oct 10, 2013 at 5:33 PM
    #959
    n0rth
    J.W.
    New Mexico
    They're 16inch x 7.5inch x 10mm offset. 6 on 5.5 in (139.7mm) Bolt Circle. 106 mm Center Bore (C.B.). not sure what the BS is on the stock wheel it may be same but only 7" wide? My tires measure 35.8x9.8 across the tread to call them 12.50 is way off.
  20. Oct 10, 2013 at 7:04 PM
    #960
    BradyT88
    Is the tread the widest part though? My KM2's are listed as 10" wide with a tread width of 7". When you throw a tape measure on them, the tread measures about 7" and the widest part of the tire is pretty close to 10".
    This isn't the best pic, but you can see how rounded the sidewall is and how skinny the tread is.
    As for the backspacing. Looks like the FJ's have a 4.3" BS and the OEM Tacoma wheels have a 5.5" IIRC. So you're FJ's stick about about 1.7" further than the OEM's.
