ND4's Fog Light Anytime Mod... NO splicing, No Bending, 100% reversible
Discussion in '2nd Gen. Tacomas (2005-2015)' started by nd4spdbh, Jan 4, 2014.
  1. Dec 11, 2021 at 1:47 PM
    #1081
    gotblika
    gotblika Well-Known Member
    Maui
    2015 DCLB Sport 4X4
    5100'S 887 SPC B110 EL096R
    Those terminals on the relay need shrink wrap over them. Did you check the fuse?
    I really prefer the bent pin single wire method. Way cleaner and no chance of short.
  2. Dec 11, 2021 at 1:51 PM
    #1082
    DoulosXP
    DoulosXP Well-Known Member
    Cary
    WA
    2015 MGM DCSB TRD Off Road 6 Speed
    Thanks for the reply. Yes, fuse is still good. Assuming it is the 15a FOG FR in the main fuse box under the hood. I will shrink tube all the connectors now. Think I can reuse the same relay location or should I move it to the open spot next to it?
  3. Dec 11, 2021 at 7:44 PM
    #1083
    gotblika
    Maui
    2015 DCLB Sport 4X4
    @DoulosXP Hope some of the better wiring guys will step in.. but I’d start off by checking for voltage between that melted terminal and the one right next to it. Should be ~12v.
  4. Dec 11, 2021 at 11:21 PM
    #1084
    DoulosXP
    Cary
    WA
    @gotblika Thanks, appreciate your help! Yeah I checked the voltage of the terminal and the relay just to be sure and both tested correctly. I decided to de-pin the terminals and re-pin them in the next blank in the relay box. Tested and fogs work again! Then I shrink wrapped everything and buttoned it all up. I’ll keep an eye on things just in case.
    gotblika[QUOTED] likes this.
  5. Dec 12, 2021 at 11:10 AM
    #1085
    nd4spdbh
    nd4spdbh [OP] Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    Yeah having exposed stuff like that is always no bueno.
    As far as the melting, looks like your flat blade connector was not properly seated / making very minimal contact down in the terminal which created heat and caused the melting. The two big blades even if they shorted out due to lack of insulation would just make your fogs go on constant.
  6. Feb 27, 2022 at 11:55 AM
    #1086
    herecomesace
    herecomesace Well-Known Member
    2013 Tacoma TRD Offroad Access Cab MGM Supercharged
    Finally got around to doing this. Works great, thanks OP!
  7. Mar 15, 2022 at 7:53 AM
    #1087
    deanosaurus
    deanosaurus Caveman
    Northeast Region
    09 TRD OR AC
    I haven't read the whole thread, so maybe this is old news. I found a clean route for the +12 lead - through a vent hole and across the factory loom to the smaller relay box.
    nd4spdbh[OP] likes this.
  8. May 30, 2022 at 11:33 AM
    #1088
    Airdreams
    Airdreams Well-Known Member
    Boise
    2005 access cab
    Softopper, 2022 TRD suspension, 2020 TRD Wheels, Pioneer stereo, K&N
    Subed
    Going to be doing this soon to mine. Just all the lovely rain All weekend long well I don't feel like going outside and messing with it. Lol
    On really dark nights and you have to use your high beams to see things way out in the distance (like dear/elk jumping out into the road), It would be nice to have the fog lights to see up close as well.
  9. Jun 25, 2022 at 1:46 AM
    #1089
    sentientprogram
    sentientprogram Well-Known Member
    Excellent tutorial and Im loving the results
  10. Sep 27, 2022 at 3:49 PM
    #1090
    JasonLee
    JasonLee Hello? I'm a truck.
    Q322+3C Denver, Colorado
    15 TRD OffRoad
    TRD Supercharger and more.
    It looks like the images are long gone. Today I went in to relocate my TRD Supercharger intercooler 12V tap from the EFI fuse to here and at the same time investigated also changing to the stealth version. Unfortunately, my general purpose blade connectors are larger than the original ~5mm wide one on the Red-Black wire, so I didn't feel like I wanted to move that one over to the unused spot and run the tap to the relay there.
    Does anyone know the Toyota part numbers or sizes/sources of the female blade connectors on the 2.5 gen secondary fuse box (that houses the fog light, EFI, and AC/DC inverter relay)? @Puppypunter / @caribe makaira / @daveeasa ?
    Female blade connector removed from the secondary fuse box on the Red-Black wire on my 2015. (Approx 5mm wide, ~2mm tall)
  11. Sep 27, 2022 at 4:27 PM
    #1091
    daveeasa
    daveeasa FBC Harness Solutions
    David
    PNW
    2016 Tacoma OR DCSB 6MT, 2005 RC 5MT PreRunner, 2002 Tundra SR5 RCLB 4x4
    Caribe probably has this info but give him some time b/c hurricanes are real and PR is getting a shellacking.
    JasonLee likes this.
  12. Sep 27, 2022 at 5:12 PM
    #1092
    Puppypunter
    Puppypunter Well-Known Member
    Johnny
    2019 Black SR
    Can you get a few side shots?
  13. Sep 27, 2022 at 5:40 PM
    #1093
    JasonLee
    15 TRD OffRoad
    It's all back together and buttoned up in the garage. It's a decent disassembly time to pull the pin out, but I can tell you it's an otherwise standard female blade terminal like this one:
  14. Nov 18, 2023 at 12:27 PM
    #1094
    TxStVanWilder
    TxStVanWilder The Pale Horse
    Tx
    2013 TRD Sport
    I’ve had this done since about 2015. I have had KC G4’s for about 2 years.
    recently quit working so now I have to figure out where the power is not going to/through.
    whether it be one of the relays (everything else works fine) or maybe even the switch.
  15. Jan 18, 2024 at 8:47 AM
    #1095
    TxStVanWilder
    Tx
    2013 TRD Sport
    with truck running, the blue relay on the right side of this photo, the wire that is closest to my camera and up in the photo shows no voltage. Assuming it’s the ground.
    The other 3 wires all have 14 volts to them.
    The fog lights still do not illuminate.
    Is there anywhere else to check other than the plugs at the fog lights for voltage or lack there of?
    not a great electrical guy here (obviously) so any help would be great.
  16. Jan 18, 2024 at 7:56 PM
    #1096
    KRAMERICA
    KRAMERICA Old Man Mike
    Middle Tenn
    '18 F250 Super Duty
    A couple of rear window decals...
    Have you tried swapping the relays around?
  17. Jan 21, 2024 at 5:35 AM
    #1097
    09Greyghost
    09Greyghost Member
    09 Tacoma 4x4 access cab
    Nicely done sir a clean professional install the way it should be. Not sure if something like this can be done on 3rd gen due to the canbus system.
  18. Jan 21, 2024 at 9:20 AM
    #1098
    nd4spdbh
    SoCal
    10 yr checkin on my mod.
    Never once an issue, it's been installed as pictured in the original post for all this time with zero fuss and zero need to change things. My fog lights are on pretty much always too haha.
    dk_crew, srspicer, Naveronski and 7 others like this.
  19. Jan 21, 2024 at 11:49 AM
    #1099
    TomTwo
    TomTwo I love God but I cuss a little
    Bill
    I-85 Southbound
    2013 TRD Double Cab Sport
    Mine has been that way for 8+ years without any issues :fistbump:
  20. Jan 21, 2024 at 12:01 PM
    #1100
    sberkley92
    sberkley92 Saturdays Are For Tacomas
    Bakersfield, CA
    '15 DCSB PreRunner TRD OR
    Bilstein 5100's, Deaver AAL, SCS SR-8's, 285 KO2’s, LED Interior Lights, Debadged, Hella Optilux Extreme Yellow fog light bulbs, Super 44 series flowmaster muffler, color matched grille surround..
    Link to that lower valence bumper? Looks clean!
