Need Help Since I have had the TSB done on my Rear Springs
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jabrackin, Aug 10, 2010.
  1. Aug 10, 2010 at 7:18 PM
    jabrackin
    jabrackin [OP] Well-Known Member
    Knoxville, TN
    2008 TRD OffRoad
    The truck is now raised up in the rear and I want to raise the front to level it out. What do I need to do? What is the best spring for the front to get? Should I get a spacer? Since I had the TSB yesterday, I can tell the rear is lifted some... should i wait and see if it settles down before I get anything to do the fronts? Any help would be appreciated. Thanks!
  2. Aug 10, 2010 at 7:21 PM
    SlurpeeBlueMetallic
    SlurpeeBlueMetallic FFFFFFUUUUUUUUUUUUUUU...
    use this link and get 5100s for the front of your truck before they run out again.
  3. Aug 10, 2010 at 7:26 PM
    tacobox
    tacobox Evasive Maneuvers PMKMS
    5100 set at 1.75" will level it out or if you still want a slight rake, set them @ .85". Search alittle bit and you can find pics of both settings with the tsb
  4. Aug 10, 2010 at 7:31 PM
    jabrackin
    Knoxville, TN
    2008 TRD OffRoad
    where can i go to get these put on?
  5. Aug 10, 2010 at 7:33 PM
    hawkeye12
    hawkeye12 Go Pack Go!
    Bryce
    Raleigh, NC
    10 Black DC SB Tacoma TRD Sport
    Smittybilt nerf bars
    Any 4 wheel shop or even somewhere like merchants would probably do it, but they will charge you out the ass.
  6. Aug 10, 2010 at 7:39 PM
    SlurpeeBlueMetallic
    Bilstein 5100s are adjustable shocks that fit inside the springs on the front of our trucks. They offer "stock" height with 0" lift and options of 0.85", 1.75" and 2.5". You can use your stock springs with the 5100s which makes for, IMO, the most economical way to get a moderate front-end lift without completely sacrificing ride quality (spacers suck in the ride quality category).
    Notice I said "without completely sacrificing ride quality"... the 5100s achieve lift but pre-loading your springs, effectively reducing the amount of travel they can provide by the amount of lift you have selected. Note this also makes the springs stiffer overall since you have "pre-loaded" them to get your lift. Since the 5100s are better overall shocks than the stock ones you likely will have improved ride quality at the 0" and .85" settings. At 1.75" the ride seems comparable, although noticeably stiffer over bumps. At 2.5", ride quality degrades quite a bit, becoming quite stiff. Some folks like this but it's not for me...
    I originally installed my 5100s post-TSB at 1.75". This was after I let the rear settle for a few months and hauling a few heavy loads. The measurements said I was dead-even level front to back but the body lines and my hood scoop really made it look like my front end was slightly higher. I also noticed ride quality was "meh" at 1.75" so I lowered it to 0.85. Now, despite the front end really being 1" lower than the rear it looks right to my eye and the ride quality is still improved over stock.
    Putting them on isn't difficult, although many skip using a spring compressor and pay a shop $40-60 bucks to disassemble the struts, remove the old shocks and install the new ones. This just leaves you with removal/replacement of the struts, which isn't too tough even with just basic automotive hand tools. Check out this thread... post 1 has a good walkthrough and the missing pictures showing those steps are on page 9.
  7. Aug 10, 2010 at 7:40 PM
    tacobox
    A 4x4 shop if there one close to you. If not your local mechanic should be able to do the install. Its a simple front strut replacement. Just make sure the truck gets a alignment after the install.
  8. Aug 10, 2010 at 8:04 PM
    Larry
    Larry CARL
    CARL
    Excellent post Chad. :cheers:
  9. Aug 10, 2010 at 8:11 PM
    SlurpeeBlueMetallic
    Thanks Larry :cheers:
    I encourage folks to give the 5100 install a shot as it's a great DIY project with a good payoff. I tackled it with Chris4x4's "How To" article (and one from TN) even though previously the most complex thing I'd done to a vehicle was rotate tires and change fluids and it was an enjoyable afternoon. Now having to take it all apart again to lower it to 0.85" wasn't so enjoyable but I just couldn't leave it looking like an ass-dragger :rolleyes:
  10. Sep 1, 2010 at 12:34 PM
    knayrb
    knayrb Well-Known Member
    Somewhere in the square states
    2010 Dbl-Cab Off-Road
    Pure stock
    Would you please take a picture of your truck with the TSB and no lift in front? I'm trying to decide if it will work for me. I don't want to lift my truck.
  11. Sep 1, 2010 at 6:38 PM
    scottri
    scottri Well-Known Member
    Scott
    Tigard Oregon
    '10 Sport DC TRD Sport PreRunner
    Cover King Seat Covers, WeatherTech Liners, PopNLock, storage bin locks, N-Fab Step bars, and G4 Elite Tonneau cover.
    Just load couple of fat chicks in back and haul 'em around for a while. That will settle 'em!
  12. Sep 3, 2010 at 5:30 AM
    knayrb
    Pure stock
    Duh. :confused: I put block of wood under the hitch and used a jack to raise the back up about 1 inch. That gave me the look I needed to see.
  13. Sep 3, 2010 at 7:02 PM
    maju
    maju Well-Known Member
    Davenport Fl
    10 DC Silver TRD Sport 4x4
    Undercover tonneau, Scangauge II, Garmin GPS, Michelin LTX M/S2
    cant you just put a couple hudred pounds in the back for a month or so.
  14. Sep 3, 2010 at 7:42 PM
    fubar718
    fubar718 Well-Known Member
    Jose
    NJ
    2010 double cab, TRD offroad
    great post. ive been looking for this info.:)
