Need some info on available intakes.
Discussion in '4 Cylinder' started by Mike_Sem, Aug 9, 2009.
  1. Aug 9, 2009 at 5:03 PM
    Mike_Sem
    Mike_Sem [OP] Member
    Michael
    Van Nuys
    '06 PreRunner
    I have an '06 Prerunner 2.7L and have been putting some serious thoughts on modding it up eventually.
    I want to start off with an intake. Looked for something from TRD but the only things available are for the V6. Did some more research after and found that K&N has two available intakes. the california legal 77 series and the not so cali legal 63 series air charger, which I am considering to buy. Does anyone have either one of these intakes installed on their trucks?
    If so, was it worth the $340 and is there any noticeable differnece?
    Another thing is there are two sensors hooked up to the factory intake.
    I circled them in red. Excuse the poor excuse for photo editing haha. Do the K&N intakes have slots for those sensors? The last thing I want is to waste $300+ on an intake, install it without plugging in those sensors and having to deal with a check engine light or a lean air mixture or something like that.
  2. Aug 9, 2009 at 5:07 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    honestly..........for the price of the intake............its not worth it. just get a good filter to replace the stock one. you can remove the secondary air filter behind the stock filter in the airbox also....as quite a few folks with the 4cyl have said it makes a good difference. for the"barely any gain" that an intake may give you.....isnt worth the cost,as it would take way,way too long to pay for itself.
  3. Aug 9, 2009 at 6:40 PM
    devilsalmostfree
    devilsalmostfree Well-Known Member
    Carl
    Loudon, Tn
    99 Tacoma 4X4, 5 spd, 2.7 ltr
    Deck plate mod, intake silencer removed, AFE Pro Dry S Air Filter, debadged, Goodyear Duratracs 265/75R16. Flowmaster knock-off muffler!
    do the deck plate mod, & then take off the 2nd filter that Will mentioned. i did it, & noticed a bit of a power gain, & better mpg!
    crap, just noticed urs was a 2nd gen. i dont think u can do the deck plate mod!
  4. Aug 9, 2009 at 6:47 PM
    neslerrah
    neslerrah Taco lovin'
    Harrelsen
    Tucson
    5 lug BEAST!
    Secondary air filter removed, elbow mod, BFG T/A KO (31x10.5R15), 15" American Racing Mojaves, BHLM, Dome Light MOD (Blue), Pioneer headunit, Sockmonkey 'TACOMA' Decals, Readylift 5-lug SST, Rear Shocks - Bilstein TRD, Dynomax Super Turbo #17748, DDM Slim Ballast HID Kit H4 Hi/Lo -35W 6000K in headlights, Apexcone Raptor HID Kit H3 - 35W 6000K in Hella 500s, aFe CAI #51-10762, WeatherTech Floorliner, 200W Smart AC Inverter
    Here is a link to remove the secondary air filter. You can go with a K&N drop in filter. Save yourself some money for other MODS.
  5. Aug 9, 2009 at 6:55 PM
    Tacoyota
    Tacoyota senile member
    North of Cali, South of Canada
    08 4wd
    4.56 gears, rear trutrac,DT header, 235/85r16 Duratracs, 2nd filter pulled, inter.wipers, Cruise control, Factory alum. whls/winter tires(2nd set), Afe pro Dry-S , Dumbo eared flaps cut down.
    The red circled closer to the air filter is the mass air flow i think ..95% i havn't poked at it yet though. Dnno the other one.
  6. Aug 9, 2009 at 7:01 PM
    Tacoyota
    08 4wd
    I wonder if a larger throttle body+ larger MAF senser... not a spacer.. would help. I'm thinking no because no one has even mentioned doing it ... and I doubt I'm smart 'nuff to think of it first.
  7. Aug 9, 2009 at 7:12 PM
    neslerrah
    Harrelsen
    Tucson
    5 lug BEAST!
    I think the other sensor is the IAC (idle air control) value. According to this link
  8. Aug 9, 2009 at 7:15 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    The one closest to the Air Box is the Mass Air Flow sensor, the other one is the Air Pressure Sensor. :) Welcome to TW!
  9. Aug 9, 2009 at 7:21 PM
    Tacoyota
    08 4wd
    ...I poured water on them ... they dont seem to be water detectors hmm:eek:
    My neighbor has a chimp with a sledge hammer , i'll ask him:D
  10. Aug 10, 2009 at 12:13 AM
    Mike_Sem
    Michael
    Van Nuys
    '06 PreRunner
    Damn thanks everyone... I'll end up taking that secondary filter out tomorrow... Now whats that deck plate mod thing about?
  11. Aug 10, 2009 at 1:08 AM
    neslerrah
    Harrelsen
    Tucson
    5 lug BEAST!
  12. Aug 10, 2009 at 5:49 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    You cant do the deck plate mod on your truck. Only works on the first gens.
  13. Aug 10, 2009 at 7:46 AM
    otter
    otter Well-Known Member
    Rob
    MI
    09 4 cyl Reg Cab
    The Tacoma airbox is a pretty solid design as far as airboxes go. The tube between the box and engine is about as smooth flowing as a flex pipe can be and the inlet from the outside air to the airbox isn't necked down or anything. It also pulls air from the fender, instead of in from either the engine bay or a necked down snorkel like most airboxes do. There's probably some turbulance inside the airbox, but getting rid of that by installing an intake wouldn't gain nearly enough to be worth the price.
  14. Aug 10, 2009 at 11:14 AM
    Mike_Sem
    Michael
    Van Nuys
    '06 PreRunner
    If there is a will there is a way. I'm just gonna look into and see all my possible options. That deck plate mod seems pretty bad ass. Too bad Toyota had to make it near impossible (according to others) to do the mod.
  15. Aug 10, 2009 at 12:44 PM
    Mike_Sem
    Michael
    Van Nuys
    '06 PreRunner
    Alright, the secondary filter is out!
  16. Aug 10, 2009 at 4:52 PM
    InfidelTaco
    InfidelTaco No better friend,No worse enemy...
    G
    PNW
    Prerunner
    AFE, Fox, Built Rights, Moog, SpiderTrax, Icon progressive, Grabbers
    i noticed a bit of difference with the elbow mod. real simple. i also have a drop in K&N. i havent tried the second filter delete but its coming off once i get home. i talked to gadget and another amsoil dealer a month back. They told me the amsoil drop in's are en route. they're going to keep me posted so i will do the same.
    G
  17. Aug 14, 2009 at 9:17 PM
    TacomaGus
    TacomaGus Well-Known Member
    Gus
    Morgantown, WV
    08 White TRD Sport DC
    Tinted Tails, TRD Shift Knob, Kenwood Headunit, Ebay BHLM Lights, Trimmed Mud Flaps, 265/70/17 General Grabber AT2's, WeatherTech Mats, Black Badges, Sylvania ZXE Bulbs, AFE Stage 2 Si Intake, 17x8.5 Level 8 Guardian Wheels, URD SS, Custom 2.5" Catback with Aero 2525 and Vibrant Ultra Quiet Resonator, URD MAF CAL, JBA LT Headers, OME 884's, Nitrochargers, Dakars with 3rd lead removed, Light Racing UCA's
    with a second gen taco i don't recommend going with the intake. First of b/c since you are in cali you'd have to go with the 77 series which i believe is stainless and thus heats up quicker and negates the "cold air" part and even if you could get the 63 series it's still the "aircharger" series and those suck. I have the "FIPK" series since i have a first gen and i def have noticed good results and would recommend it to anyone but i don't believe you can get the fuel injection series intakes for the 2nd gens so i think going with the deck plate mod, removing the secondary air filter, and getting either a K&N drop in or an AFE Pro Dry S would do a much better job and save you a ton of money that you could put towards exhaust or headers :)
