NetMonkey's build
Discussion in '2nd Gen. Builds (2005-2015)' started by NetMonkey, Sep 18, 2010.
  1. Sep 18, 2010 at 12:27 PM
    NetMonkey
    NetMonkey [OP] Well-Known Member
    Geogetown, TX
    2010, 4x4, DC, off-road, shortbed, automatic
    Toytec Ultimate Lift @ 3", Mickey Thompson MTZ's 285/75/16, Moto Metal 955b, rear 2" ALL, Marlin Crawler sliders
    whoot... i have finally done enough to my truck to make a build thread :)
    so, here is what i have now:
    • Toytec Ultimate kit with coils set at about 3", silver springs, 2" add a leaf, 5100's on rear, axle shims, front diff drop, sway bar relocator
    • Total Chaos upper control arms
    • Moto Metal 955b, 16x8, 0 offset, 4.5 backspace
    • Mickey Thompson MTZ's, 285/75/16
    • Marlin Crawler rock sliders
    • Body mount chop
    • Misc
      • CB -Uniden 520XL with firestick NGP antenna
      • Front and rear facing dash cams.
      • Tinted windows at 30%
      • Scangauge
      • Illuminated 4x4 switch
      • Lighted cup holders
      • Hi-Lift jack
      • Diff breather mod
      • CV boot mod
      • Shorty antenna by AntennaX
      • Tailgate "lock"
      • Tacoma World sticker (its super aerodynamic and adds 20 mpg :) )
    i had the lift work done by a local shop and i have to give the owner a major plug:
    Darren Castine at Twizted Engineering did a fantastic job on my truck. he runs a small shop in broomfield and can do ANY work you desire, from custom fabrication, to bolt on lifts, engine rebuilds, or fully custom rock crawlers. anything that you desire, he can build. if you are in the denver/boulder area, i highly recommend him. you can find him at:
    555 Alter St Unit 15-B
    Broomfield, CO 80020
    303 410 0804
    DarrenC@TwiztedEngineering.com
    sooo... on to the pics...
    here is the stock truck before the lift
    here it is now :)
    the tires dont stick out too far from the fenders. i chose the 16x8 rims to keep the tires in more than the 17x9's would.
    the sliders stick out to be almost flush with the fenders.
    i chose the mickey thompson MTZ's because i wanted an agressive tire, but that also have some siping for the winters here. also, these 285's are a D load range so they are lighter than many other 285's which are typically an E load range.
    weld on sliders
    i chose the toytec ultimate kit because it was just easy to have everything i needed included in 1 kit. also, because darren is an authorized dealer and installer for Toytec.
    this is a before pic of the body mount and the plastic inner fender well.
    this is the after pic of the body mount chop and trimming on the inner fender well. you can also see that the inside of the fender was trimmed too.
    this is how the front of the inner fender well was trimmed. darren didnt actually cut it away, he instead folded the access up and strapped it all together with zip ties. this kept the plastic ridged so it wont flop around.
    here is the underside of the front inner fender well. you can see how the access is folded up and tied together. its a good idea, but i hope that over time, the holes and zip ties dont tear or brake.
    here is a pic of the CV joints/boots before the lift
    here is the CV joint/boot after the lift. the angle isnt too bad. it looks like some of the fins are touching, so i hope they dont wear too bad.
    this is the clearance at the body mount at full lock
    looking up from underneath of the body mount with the tire at full lock. the tire probably wouldnt have rubbed under normal driving, but trimming it guarantees that no rubbing will happen while off road.
    front inner fender well at full lock.
    another view of how the front fender well is strapped up
    tire at full lock.
    yay :)
    miscellaneous mods:
    CB
    Build thread:
    http://www.tacomaworld.com/forum/2nd-gen-tacomas/134082-my-cb-installation-detail.html
    Dash cam build thread:
    http://www.tacomaworld.com/forum/au...am-genius-dvr-fhd590-installation-review.html
    scan gauge
    Rocky Mounts bicycle mount
    illuminated 4x4 switch
    build thread:
    http://www.tacomaworld.com/forum/lighting/78339-4x4-illuminated-switch-cup-holder-light-mods.html
    lighted cup holders
    build thread
    Hi-Lift.
    build thread:
    http://www.tacomaworld.com/forum/2n...my-hi-lift-install-other-fun.html#post3178179
    diff breather mod
    build thread:
    http://www.tacomaworld.com/forum/2nd-gen-tacomas/157168-my-hi-lift-install-other-fun.html#post3178179
    CV boot mod
    Build thread:
    http://www.tacomaworld.com/forum/2nd-gen-tacomas/190669-my-cv-boot-mod.html#post4117432
    comments about the lift and tires:
    • i am very pleased with the lift and tires. i am so glad that i did it. its a completely different truck.
    • the ride feels so much more solid. on the stock tires and suspension, the back end would jitter and hop over bumps, railroad tracks, etc, but now, it just rolls over eveything without extra movement.
    • the truck also feels heavier... if that makes sence. i guess its from the added weight of the rims and tires. the truck feels planted to the ground.
    • i do feel a difference in the gas and brake pedal. it does take a bit more to get rolling and a bit more to stop. i matched the scanguage with my gps and it looks like i might cut 50 miles off a tank of gas (400 miles to 350 miles), but its worth it :)
    • the tires arent too loud on the street either. interestingly, the loudest they get is between 45 and 55 mph. above 60 and 70 mph, the wind noise seems louder than the tires.
    • darren was able to get the alignment perfect. there is no wandering. the truck tracks straight. i do feel more response (than stock) in the stereing wheel, but i think thats more from the size of the tires rather than from any bump steer.
    • i do have an ever so slight vibration at 5mph when talking off from a stop. and i mean very slight. sometimes i dont feel it. other than that, there are absolutely NO vibrations. not under acceleration, deceleration, or at any other speed. the 5mph vibration is carrier bearing, but i dont even think its worth it to mess with a drop for it.
    • with the truck at stock, i was starting to get some axle wrap, but with the 2" ALL, the axle wrap is totally gone.
    thanks for looking :)
  2. Sep 18, 2010 at 12:31 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
  3. Sep 18, 2010 at 1:15 PM
    Incognito
    Incognito No better friend, no worse enemy
    VA
    2012 Pyrite AC TRD OR
    Spacer lift, bumper stickers, ejector seat, etc.
    Looks great!
  4. Sep 18, 2010 at 1:19 PM
    MOT
    MOT Prez of @BattleBornToyotas
    Daniel
    Las Vegas
    08 DB DC 4X4 Sr5 Sport
    Black Housing Head, Custom Retro fit, T-Rex #2 Eyelids 50 inch ToughLight Radius Bar and 2 20 inch Bars behind grill with BAMF mount, T-Rex #2 Eyelids, Custom Vegas Dezert Fab Front Bumper and Rock Sliders,Wet Okole's, WeatherTech Mats, Magnaflow Exhaust, Pro Comp 6 InchStage 2 Lift, K&N Intake,
    Very nice and clean!
  5. Sep 18, 2010 at 2:29 PM
    HondaGM
    HondaGM Call sign Monke
    James
    South-Pole, Alabama
    2023 access cab V6
    very nice rig
  6. Sep 18, 2010 at 3:05 PM
    08PRELB
    08PRELB Don't Tread On Me
    Adam
    805
    08 Prerunner LB
    Toy Tech Ultimate Lift kit,Buildt Right UCA's 285/70/17 BFG AT, Camburg Spindles, BHLM, K&N, Flow Master 50, Spider Trax, URD MAF CAL, Satoshi Grill, any time fog mod, 20% tint, Katzkins Leather Interior, FX-R Projector Retro
    Nice truck i like what you have done so far
  7. Sep 19, 2010 at 7:26 AM
    allrsdup
    allrsdup Well-Known Member
    Sahuarita AZ.
    2018 dcsb trd offroad 4x4 Inferno
    looks great and i like all the detailed pics. the body mount chop looks factory nice job!
  8. Sep 19, 2010 at 9:26 AM
    JRW1223
    JRW1223 Well-Known Member
    Jordan
    Tucson, AZ
    07 DCab 4x4 sport
    All Pro long travel, All Pro Front bumper, BFG 285/75/16, American Racing Ledge Wheels 16x8, Vision X 8.7" Tungsten Halogen Off Road Lights
    Looks great! I like you wheel/tire combo!
  9. Sep 19, 2010 at 10:42 AM
    HuntnTruk
    HuntnTruk Tacohead
    Kevin
    New York-not the City
    Indigo SR5 4x4
    This is a strange request but could you possibly post a picture of you standing next to your truck and list your height. I have never seen a lifted taco in person and am having a hard time gauging the relative difference. Or could you just tell us how it is getting in and out. Did you notice if you have to jump up to the seat now? I know it is strange questions. Thanks
    Truck looks awesome by the way. Nice job
  10. Sep 19, 2010 at 10:50 AM
    NetMonkey
    Geogetown, TX
    hehe... sure. i can get my wife to take some pictures :)
    having the sliders helps getting into the truck. i grab the steering wheel with my right hand and place my left foot on the slider and then slide my right leg and hip over the seat. without the sliders or a step, you really have to reach to get into the truck. i am 5'8". i will post pics later today.
  11. Sep 19, 2010 at 10:51 AM
    NetMonkey
    Geogetown, TX
    thanks for the compliments, everyone :)
  12. Sep 19, 2010 at 4:34 PM
    NetMonkey
    Geogetown, TX
    here are some pics of getting in the truck.
    i am 5'8" so the truck is probably around 6'.
    my thigh is horizontal when stepping on the slider, so trying to step directly into the cab would be difficult (for my short legs anyway).
    so, i step up on the slider and then swing my right leg into the cab and around the seat. ya, its "harder" than at stock height, but its really no big deal :)
  13. Sep 19, 2010 at 6:32 PM
    HuntnTruk
    HuntnTruk Tacohead
    Kevin
    Indigo SR5 4x4
    Sweet thanks man. Thats what I was hoping for. I want to have to gain a little elevation when getting into my truck, rather than sitting down into it.
  14. Sep 27, 2010 at 4:54 PM
    NetMonkey
    Geogetown, TX
    so my wife and i did a little road trip and some mild off roading last weekend. and... wow...those tires are super grippy off road. it is amazing what it will crawl over without slipping at all. i dont have to worry about anything off road; just point the truck and go.
    however, i pay the price for all that grip with reduced gas mileage. going from 31's to 33's dropped the mileage by about 2mpg.
    also, the top speed (that i feel comfortable driving anyway) is less too. 75mph feels really fast so i find myself slowing down alot. and going up the winding mountain roads is slower and more work on the engine.
    still, its all worth it :)
  15. Oct 7, 2010 at 1:51 PM
    Kappes03
    Kappes03 Legend of the UG
    Colorado
    2014 Tundra CM
    Nice build man. I was trying to remember if you were at the last MOD day. After seeing your pic of you hoppin into the cab I remember who you were haha.
  16. Oct 7, 2010 at 2:00 PM
    NetMonkey
    Geogetown, TX
    yup :)
    :wave:
    i signed up for the 2nd mod day as well.
  17. Oct 7, 2010 at 2:50 PM
    Kappes03
    Colorado
    2014 Tundra CM
  18. Oct 7, 2010 at 3:13 PM
    Namyo
    Namyo -
    Hell yea!! Looks right man!
  19. Nov 6, 2010 at 4:40 AM
    romafern
    romafern Hug diz nuts
    Rob
    80918 Let's meet!
    Paid for and saving a shit ton of $$$$$
    Thinking of adding a second battery...
    Monkey,
    so how much would this cost? Lift only/wheels/rims? Trying to get a budget idea here....Thanks.
  20. Nov 6, 2010 at 5:10 AM
    Mark C.
    Mark C. If you want it bad, you usually get it bad!
    Mark
    Connecticut
    2010 MGM SR5 4WD AC
    LED Dome, Reed Switched LEDs in Glove Box and Center Console, Bumper Fogs, Tailgate anti-theft, LEDs over Cig lighter, Back-up camera anytime, Outside Temp add-on, Hidden GPS power, Sockmonkey 3rd Brakelight decal, 4X4 switch illumination, reed switch controlled engine compartment Flood LEDs, Elite Hitch Cover, Plasti-dipped cupholders and door switch control panels, Elite Hitch Cover.
    Very Nice outcome! Looks really great!
