New to Offroading. What hand tools are you carrying, and in what?
Discussion in 'Off-Roading & Trails' started by tonykarter, Dec 13, 2018.
  1. Dec 13, 2018 at 5:25 AM
    tonykarter
    tonykarter [OP] Crappie Savant
    Snuff Gully, Texas
    2018 DCSB 4x4 Sport 1993 4Runner SR5 4x4, 411,000 miles
    Pine tree air freshener
    My previous offfroading has been limited to hunting treks down well-maintained national forest backroads. For your adventures out there beyond the realm what hand tool collections are you taking with you? How are you packing them to take up little room?
  2. Dec 13, 2018 at 5:28 AM
    m603holden
    m603holden @Koditten Pirate Radio member #063
    Marteeen
    New England
    2017 Tacoma DCSB OR MT
    Lots of sail boat fuel
  3. Dec 13, 2018 at 5:56 AM
    Elkyri
    Elkyri Living on the Raggedy Edge of the 'Verse
    2017 DCSB TRD-OR
    Thanks for linking that freakin' comprehensive list. I think I'll skip the "funky fishing hat" but it's a good list to treat like an a la cart menu. Thanks.
    @tonykarter if you don't already have a tow strap and intend to buy new consider buying a "snatch strap" instead. Different to a plain tow strap and more expensive but a good investment.
    Also, instead of jumper cables I've taken to packing one of these. Not only will it jump start your truck without having to maneuver two vehicles into just the right spot but it can be used to charge cell phones and other USB charged items; you can recharge it by plugging it into the accessory outlet (cig lighter) in your truck.
    https://www.amazon.com/dp/B015TKUPIC?ref_=nav_ya_signin
  4. Dec 13, 2018 at 5:58 AM
    m603holden
    Marteeen
    New England
    No prob!
    Ham radio never hurts ;)
    Tac0maSteve likes this.
  5. Dec 13, 2018 at 6:05 AM
    tonykarter
    Snuff Gully, Texas
    That is a comprehensive list for sure. Thanks for putting me on to it. I'm interested in the hand tool sets people are including as part of this load-out. Looking for a comprehensive set of repair tools that pack down small and dense. Currently I'm resolved to carrying my boat tool kit, a tall plastic version of the .50 cal ammo box full of every tool that I didn't have when I needed it over the last 40 years. Now that I've downsized from a 1/2 ton longbed pickup I need to trim storage size where possible. What sets are others carrying, and most important, how are you doing it compactly?
  6. Dec 13, 2018 at 6:10 AM
    m603holden
    Marteeen
    New England
    Crafstman 165pc set
    https://m.sears.com/craftsman-165pc-mechanics-tool-set/p-A014491227
    ColoradoTJ likes this.
  7. Dec 13, 2018 at 6:12 AM
    kbp810
    kbp810 Well-Known Member
    Au Gres, MI
    2016 Tacoma TRD OR
    Recovery gear (d-rings, soft shackles, tree saver strap, kenetic rope, tow strap), jumper cables (or a jump box), air compressor, small ratchet straps (for helping to re-set a bead), and at a minimum I would include: a BFH (big f'in hammer), a basic mechanics set of wrenches/sockets/screwdrivers, an axle nut socket (I forget off hand if this was a 35mm or 36mm... lord knows I've made good use of mine, I just don't recall the size off hand), a couple of big adjustable wrenches to help cover the range of larger bolts such as jam nuts and what not (don't recommend them for general maintenance, but on a trail, they can come in handy in a jam), and vice grips.
    You never know what might happen, but here are some of the plausible things that might fail that you would want to have the tools on hand to address: broken CV axle, broken/bent inner tie rod, torn brake line (if no spare lines, vice grips can help clamp off a line until you can get off the trail), broken wheel studs, driveshaft u-joint.
  8. Dec 13, 2018 at 6:17 AM
    m603holden
    Marteeen
    New England
    ....hack saw...because, you know.
    Metal and wood blade. Wood blade makes short work of trail cleanup of fallen wood if you're not packing a sawzall
  9. Dec 13, 2018 at 6:56 PM
    Canoehead
    Canoehead Well-Known Member
    Duncan
    Dartmouth, NS Canada
    2007 DCSB, lots of scratches
    Rearview mirror upside down
    You are talking repair tools I think?
    I started with an empty tool bag, and then I try to do all the work I can in my driveway. With every job I add the minimum necessary tools into the bag, and this bag stays in the truck. In some cases there are tools I keep in the shed because they make the jobs easier, but because I can do the work without them I don't carry them all the time. From this approach, I learn more about the truck with every job, and I also have the tools that match my experience and expertise at hand. I find this better than carrying a comprehensive set of tools, like a full socket set, because there are a lot of sizes you may not need... like nearly all the imperial ones. It is also important to me that every tool I carry has passed the test in my own hands. Turns out you can do A LOT of work with a tool bag that is not much bigger than your .50 ammo box!
    My truck is a Second gen so I started here for some ideas: https://www.tacomaworld.com/threads...ckets-and-wrenches-for-2nd-gen-tacoma.158302/
  10. Dec 13, 2018 at 7:21 PM
    tonykarter
    Snuff Gully, Texas
    Good experience there. That's what I am trying to do, parry it down to just what is absolutely needed. This thread is my try at lucking into someone's well-considered hand-tool inventory, cuz', much of what is in that ammo box I'll never use on this truck. I do the same thing you do every time that in-tank fuel pump goes out on my '97 C1500. It takes only seven tools to do the whole job, and those are the only tools I get out. (Even have it written down somewhere!) This is a job I have done way too often since '97. As a result I can change that fuel pump out faster than Gump can field clean and assembly his rifle...SARGEANT! However, there's a '93 4Runner out there that I know little about. BECAUSE IT DOESN'T BREAK DOWN!
  11. Dec 13, 2018 at 7:24 PM
    tonykarter
    Snuff Gully, Texas
    My Kingdom for a 3rd Gen list like that...
  12. Dec 14, 2018 at 1:42 PM
    jbrandt
    jbrandt Made you look
    Justin
    '04 TRD Tacoma 4x4 DC
    Don't buy one of those big tool kits. You likely don't need 85% of the tools in them. That's just extra money, and extra weight you likely don't need. Those kits are usually stocked with pretty inferior quality tools, too.
    I would just start and the front of the truck and work your way back and makes notes of the different sizes of sockets/box wrenches you need. There are probably only like 4 or 5 metric sizes you really need to bring. I have a few odd ball sizes for things like the uniball bolts on my upper control arms.
    Then bring a whole bunch of zip ties, duct tape, wire, adjustable wrenches, ratchet straps, pliers, bungees, hammer, screwdrivers, etc... I also bring a hatchet, toilet paper, air compressor, and other odds and ends.
    I currently have all (most?) of that stuff in a yellow-top box from home depot and strap it in my bed and some of those plastic ammo boxes from harbor freight. I have a portable air tank form harbor freight as well that I strap in the bed, too.
    But I'm really thinking about just getting a roll up tool bag or two - much easier to keep the tools organized and easy to find, and getting rid of the yellow top and getting a couple Rubbermaid Actionpacker boxes, where I can keep extra fluids/spare parts in one box, tools in the other.
  13. Dec 14, 2018 at 6:12 PM
    tonykarter
    Snuff Gully, Texas
    No, I'm not. I've got oceans of tools here. Last thing I need is another tool set to say grace over. Just fishing for that perfectly-conceived tool list and a concise way to travel with them. That bow to stern audit sounds like a wonderful idea. Somewhat similar, I remember back when I was restoring Triumph TR-6's. Everything on them was 15mm except the engine. Everything on it was 9/16". British Leyland had entered into a deal with International Harvester to source the engine from them. It was a proven cast iron block inline six that IH had been using on their tractors for years, but it was imperial. All you needed to work on those cars was 15mm and 9/16"! And bailing wire. And a miracle.
    Canoehead likes this.
  14. Dec 15, 2018 at 2:13 PM
    jbrandt
    Justin
    Yeah, would be nice if you could consolidate the sizes and make everything 14 or 15mm... It seems like 14mm is one of the sizes I use the most.
