New to suspension - Leaf spring install
Discussion in '1st Gen. Tacomas (1995-2004)' started by roboturner, Jun 18, 2021.
  1. Jun 18, 2021 at 2:41 PM
    roboturner
    roboturner [OP] Dead Eyed
    Colorado
    00 IJM AT XC 4x4 3.4L TRD | 18 CB MT DCSB 4x4 V6 Pro | 98 NW MT 4x4 3.4L SR5 4Runner
    Ok my tired OG leaf springs have to go - 224k mi and W
    I've read through a variety of posts on LS install with some differing advice on what to replace etc, so wanted to check if I am missing something before I order, and any other general advice.
    • I want to emulate stock, so no huge lifts, but ok with a mild lift/rake. After reading around it seems that General spring has the ~OEM type LSs available. That being said, read many people regret not getting the HD springs, which appear to apply a mild 1.5" lift, but also increase load capacity.
      • The PO replaced rear shocks with what look like 4600s, or some stock-like equivalent, in the last 10k mi, so would prefer not to change them if I don't have to
      • Will the HD springs provide more lift than the 4600s will allow?
    Truck usage info:
    • No wheeling
    • No topper, however may get one eventually
    • Forrest service road / dispersed camping in the summers
    • Haul dirt/rocks/do random truck-stuff semi-regularly
    Planned purchase list:
    • 2x GS HD Leaf springs (90-203HD)
      • The regular LS on GS have a passenger and driver specific, however the HD does not appear to have 2 options? Is this correct?
      • includes bushings
    • 2x Rear Shackle
      • Read in some posts that you should replace shackles while up there, necessary?
    • 4x Ubolt
      • All ubolts replaced
    Am I missing anything else? random bolts/extra bushings that may be seized/are good to replace? anything further I need to watch out for? Will i need to extend the brake-line for this spring set? I don't mind doing preventative replacements/upgrades if necessary
    Thanks much for the advice!
  2. Jun 18, 2021 at 2:51 PM
    Which Way Out
    Which Way Out Well-Known Member
    Bill
    Santa Barbara
    2002 Tacoma 4 Door Prerunner
    Sorry I don't keep all the technical stuff in my head or ever written down. But I changed my rear leafs a couple months ago with stock rated.
    Big difference in all around performance. New shocks all the way around and coils up front last year. Took awhile to settle in, but well worth it.
    roboturner[OP] likes this.
  3. Jun 18, 2021 at 2:52 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    2002 XtraCab TRD 4x4 SCv6 AutoTrans With Lots of Mods ADS COs w/Compression Adjusters Camburg Uniball UCAs Whiteline Lower Control Arm Bushings Kartek 7" Limit Straps Plastics Guy Front Bumpstops Total Chaos Sprindle Gussets Custom Alcan Springs +800 lbs +3" ADS 10" Stroke Triple Bypass w/Resi Rear Shocks Custom Rear Shock Relocate All-Pro U-bolt Flip w/Timbren Bumpstops 4.88 Nitro Gears ARB Front Locker ARB Twin Compressor Black 17x8 Konig Countersteer Type X 285/70r17 Falken A/T3w Gunmetal 16x8 SCS Ray10s 255/85r16 Maxxis Bighorns Limited Edition (Relentless) Elite Front Bumper Smittybilt X2O 10K Winch Diode Dynamics SS3 Sport Selective Yellow Fog Lights in the Bumper Diode Dynamics SS3 Pro 4,000 Kelvin SAE Driving Lights with Clear Lenses on the Bumper Morimoto D2S Projectors XB35 Ballasts + 4300K Bulbs Badland Sliders FrankenFab Tire Carrier Swingout bumper w/kitchen BudBuilt Front & Bellypan Skids BAMF Rear Diff Skid Dometic CFX 55im Fridge/Freezer Alpha II Hardshell RTT Badland Custom Bed Rack Denso 210-0461 105 amp alternator Dual Northstar 24F AGM batteries BlueSea 7622 ML-ACR Battery controller Peak DBI Dual Battery Voltage Monitor Haltech IC-7 Display with Mako Dash Insert Haltech Elite 2500 Standalone ECU Magnuson MP62 Supercharger w/URD 2.2" Pulley Denso 650cc Fuel Injectors Aeromotive Stealth 340 Fuel Pump TransGo A340F Reprogramming Shift Kit Doug Thorley Headers 2.5" Magnaflow Hi-Flow CAT Magnaflow 18" Muffler w/Vibrant Resonator 13WL Brake Calipers Braided Steel Brake Lines Kenwood TM-71A Dual Band Ham Radio Larson 70CM/2M Antenna Midland MTX275 GMRS Radio w/Roof Mount Antenna Uniden 520xl CB radio 3' Firestik Adjustable tip antenna Pioneer DEH-P9400BH HU Alpine Amps & Type R components (F) and coaxials (R) Wet Okole Seat Covers Weathertech Digital Liners Deck Plate Mod 1" Diff Drop Carrier Bearing Drop
    It is very unlikely there is any reason to replace your rear shackles. The bushings however should be replaced.
  4. Jun 18, 2021 at 3:02 PM
    rnish
    rnish Well-Known Member
    Tacoma 2nd gen
    Yes. Replace the rear shackle’s. Also consider replacing all bushings, bolts, nuts and washers. If they are all 21 YO OEM, I would replace vs refresh old hardware.
  5. Jun 18, 2021 at 3:55 PM
    6P4
    6P4 Well-Known Member
    Colorado Springs
    98/2.7L/Regular Cab/4x4/5spd/Open diff
    Here's another option. It comes as a complete kit with shackles and u-bolts: https://www.autoandtrucksprings.com...-4wd-rear-leaf-spring-kit-complete-bt90203ck/
    I haven't used these myself, but I've been eyeing them for my pending leaf spring replacement. There's a thread in the suspension forum raving about the company and a heavy-duty leaf pack they make for 3rd gens: https://www.tacomaworld.com/threads/the-best-aftermarket-leaf-packs.659052/
    If you want to buy from them, it sounds worthwhile to call or email rather than just purchasing off the website. By all accounts, the owners are super helpful and they'll make sure you get what you need.
    If you do get these, please report back so I know whether or not I should get them :)
  6. Jun 18, 2021 at 5:20 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    General Springs are good to go and often recommended by many here when someone wishes to remain 'stock'
    The HD version simply adds payload capacity; in what respect I don't know if the tension is different or if an add a leaf is simply installed.
    You can easily get this question answered by calling them directly.
    Moving forward, if you order the HD series, you will have a slight bit more lift. This could largely be due to the fact that they may be adding an add a leaf as I mentioned above, but also so that your vehicle sits at 'stock height' once you're loaded.
    I'd recommend the HD series if you're carrying a constant load, like a camper shell for example. I helped a member install his General Springs HD leaf pack as he needed to replace his leaf pack badly, but also carried a camper shell full time.
    With the leaf pack, you'll want to replace the u bolts, and that's it.
    Shackles will only need replacing if they're damaged IE rusted to shit, bent, etc.
    As for your shocks, you're good to go since you won't be doing any real flexing anyway.
    If you check this thread out, you'll see the half-assed Walk Through I typed up (with pictures) as well as the OP's truck at the bottom when we replaced his leaf pack - Advice for Leaf Spring Installation | Tacoma World
    Which Way Out likes this.
  7. Jun 18, 2021 at 5:43 PM
    roboturner
    Colorado
    Thanks! I had read your quick walkthrough early on the process and couldn’t find it again, so appreciate it and the info
    also just judging by the pics on the GS regs vs GS HD, it does look like the HDs have an extra leaf
  8. Jun 18, 2021 at 5:44 PM
    roboturner
    Colorado
    interesting, that kit is way cheap, even compared to GS. I’ll shoot them a call on Monday and ask about it. I’ll let you know if I go that direction, may be worth it to just test it out anyway
    6P4[QUOTED] likes this.
  9. Jun 18, 2021 at 6:19 PM
    Rastopher
    Rastopher Well-Known Member
    Ras
    Portland, Oregon
    2002 2.7 4x4 reg cab automatic
    Utility Shell, Ultra 062 wheels, bilstein 5100, OME880 coils, wheelers progressive AAL, Whiteline LCA bushings, poly sway bar and steering rack bushings, led dash cluster, shifter bushings, 4runner mirrors.
  10. Jun 18, 2021 at 7:14 PM
    roboturner
    Colorado
  11. Jun 18, 2021 at 7:28 PM
    6P4
    Colorado Springs
    Yeah, that's a bummer. I think this is the other thread Kristi was referring to: https://www.tacomaworld.com/threads...-souderton-pa-help-spreading-the-word.692364/
    It seems like people have been happy with the product when they got the right thing... but I guess it's a gamble and you might be in for a hard time if you need post-sale support. It's especially disappointing to see when there are so many positive reviews of pre-sale support.
    General Springs is probably a safer bet.
    I think this is where @Kwikvette comes back with "40s and tons".
  12. Jun 18, 2021 at 7:42 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    40s n tons obv :burp:
    roboturner[OP] and 0xDEADBEEF like this.
  13. Jun 19, 2021 at 2:14 AM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    Iwill say have new Hardware for the Spring Hangers I have yet to be able to get those bolts out.
    They fuse to the metal insert in the bushing I tried everything and wasted about 4 hours on one side.
    The nuts broke free and came right off.
    Good luck!
  14. Jun 19, 2021 at 7:36 AM
    devanHI
    devanHI Member
    1999 Tacoma 2.7 4x4
    OP,
    I installed the HD springs last summer and they did indeed lift the rear end. I inquired directly with general spring and they told me I should expect 1-1.5" of lift if I did not have a load/empty bed/stock bumper. So your 4600 bilstein struts should be replaced with something with longer dimensions and articulation capabilities.
    I put in new struts, shackles, ubolts and bushings on all parts replaced. I replaced them alone and suffered, have a strong second set of hands to do this. My strut mount studs were very dirty as the old bushings were allowing dirt and water between them and the studs, I cleaned them with a wire brush on a dremel. Also clean the surfaces that come in contact to your ubolts and bracket, that was caked.
    I used greasable shackles and front eye bolts, so far they work great. They do make a mess as the grease makes it way out no matter what, but that's no problem.
    My first option for struts were the extended 5100's. But I went headed and purchased the 5160's w/ reservoirs, they look sweet but a little stiff unloaded.
    Overall, if you are shooting for stock, don't use the HD's. Either way you go, I'd replace everything back there, the PO of my truck said a lot of things were done to my truck that a trained eye proved otherwise. If your truck has good powerhouse, give it good suspension and powertrain to roll on.
    I wish you luck and hope this helps.
  15. Jun 19, 2021 at 7:56 AM
    roboturner
    Colorado
    Do you recommend putting anti-seize or thread locker on any bolts/surfaces? I've got the receipt for the install on the recent struts and they do look clean so itd be a bummer to have to throw another couple hundred replacing em, but will do that if necessary. I am just going to go ahead and replace every bolt etc associated with the install as they all look original (except the upper shock bolts, replaced those when they backed off on the road, added some thread locker, no issues now)
  16. Jun 19, 2021 at 8:41 AM
    Kwikvette
    Fresno County
    4 run, 2 don't
    They're shocks; struts are not used at all on these trucks.
    If you do replace them, it's a 5 minute job, and you'd be replacing $40 shocks that you can set aside for later use.
    Do not bother with thread locker, and tighten everything down to spec only once the vehicle is resting on its own weight.
  17. Jun 19, 2021 at 2:25 PM
    Wyoming09
    New Tripoli Pa
    Super Springs
    Here I put never seize on most all hardware.
    I buy it by the case
  18. Jun 19, 2021 at 5:28 PM
    Andy01DblCabTacoma
    Andy01DblCabTacoma Well-Known Member
    Andy
    San Diego, CA
    01 Double Cab v6 4x4 TRD
    F: Kings SPC, R: 5100s+J59s. Custom armor.
    One thing I don't see mentioned here is: start spraying the forward leaf spring hanger, u bolt nuts, and rear shackle bolts with PB Blaster NOW and every couple of days until you do the job. If they haven't been off before they'll need all encouragement they can. The forward hanger bolt can be a beast to get off of there, extra long breaker bar or impact is highly suggested. Also 6-sided sockets... Harbor Freight is your friend here.
  19. Jun 19, 2021 at 5:31 PM
    roboturner
    Colorado
    Yup been PBing like crazy I can already tell I’ll likely need to cut em. Anyone have the part number or deets for the fwd hanger bolt offhand?
    thanks
  20. Jun 19, 2021 at 5:38 PM
    Andy01DblCabTacoma
    Andy
    San Diego, CA
    I highly recommend that you become familiar with parts.toyota.com - the company site, not the dealer specific sites. Get your VIN number, and paste it into a file on your desktop and use that to locate the parts you need. Then once you have the part number, search high and low until you find a specific dealer or online retailer with a price you're willing to pay.
    parts page from my 2001 4wd: https://parts.toyota.com/a/Toyota_2.../REAR-SPRING--SHOCK-ABSORBER/674460-4804.html
