New UCA's or Maxtrac spindles?
Discussion in 'Suspension' started by 05RedTaco, Oct 25, 2012.
  1. Oct 25, 2012 at 6:37 AM
    05RedTaco
    05RedTaco [OP] Nom Nom Nom
    Tony
    Scottsdale
    2000 Tacoma XtraCab 2.7L 4x4
    I have currently 5100's with stock TRD Off Road coils set to 2.5. My caster is way off. It rides OK, but my driver side tire rubs on UCA at full lock. I would like to correct the caster. I know one way is to get new UCA's.
    I have been thinking about spindles, because the Maxtrac spindles are $540 shipped and the Total Chaos UCA's are $650 shipped. Spindles are cheaper and will give me 1" more lift which would be nice :D If I install spindles will my caster be within specs? Also if I install spindles what setting would I put my 5100's at?
    Lastly if I get spindles what to do about the rear? Can i add another AAL to my leaf pack? I currently have Toytec 2" AAL. Or should I just add a block to have the truck sit level? I want to steer away from getting new leaf pack until my stock leaf pack is completely shot...
    Here is picture of my current alignment specs;
  2. Oct 25, 2012 at 11:50 AM
    veet skeet
    veet skeet Well-Known Member
    Cali
    14 4Runner Trail Edition MGM
    Bilstein 5100s, 17' Method NV Race Wheels, Goodyear Duratrac 265/70/17, Demello Sliders, Xenon/LEDs All Around, Dark Window Tint, Gobi Roof Rack (In the Mail), JL Audio Subs, Alpine Speakers and Amps
    If you get the spindles, you can either set your 5100's at 0 and get close to 4' of lift and get these smoothest ride or you can preload at .85' and get more than 4' of lift but compromise ride a little bit because of preload. If you have a 2' AAL in the back, you should be almost level, maybe a little bro lean in the front I would assume if you set the 5100's at 0 with spindles.
    You won't have to get new UCA's if you set the 5100's at 0 or .85, you can use stock UCA's and be within stock specs for alignment because the spindles allow the lift without changing ride geometry.
  3. Oct 25, 2012 at 3:12 PM
    05RedTaco
    Tony
    Scottsdale
    Thats good news! Now more questions;
    1, will i need wheel spacers with these spindles? I am running 265/75/16's on stock TRD off road wheels.
    2, As far as I can tell I should be able to lift the truck total of 6" with the spindles using 5100's OME 885 and TC UCA's correct?
  4. Oct 26, 2012 at 9:23 PM
    05RedTaco
    Tony
    Scottsdale
    Anyone?
  5. Oct 26, 2012 at 9:37 PM
    GREEKBOY12295
    GREEKBOY12295 Well-Known Member
    Nick
    Phoenix, AZ
    2005 Toyota Tacoma PreRunner
    Radflo 2.5 Coilovers, Viper Alarm 5902, Bilstein 5100's, Polk Speakers, Blacked out grille and Emblems, All Pro 3" leafs, Pioneer AVH-4300 Double Din, BHLM, 4" Maxtrac Spindle, Aero Turbine 2525xl, Ultra Gauge, Rockford Fosgate 300 mono amp, 10" Kicker CVR
    Id like to say yes? Im not sure though.
  6. Oct 27, 2012 at 7:33 AM
    05RedTaco
    Tony
    Scottsdale
    I would like to get more specific answer than that. And if I do need wheel spacers I would like to know what size...
  7. Nov 11, 2014 at 12:25 PM
    HectoRome
    HectoRome Grizzled Contracting NCO
    07 PreRunner SR5 TRD Off-Road Debadged, Icon Stuffs, MaxTrac Spindles, Dirt King LCAs
    NO!
    You will Not need spacers, even with out the Maxtrac spindles you will not need spacers as those size tires will fit. Be aware that some of the more agressive side walled tires ( Duratracs Etc. ) have a tendency to be very close so keep that in mind when purchasing tires in the future.
    According to the Maxtrac website the spindles add "+0.75" Track Width increase per side" and they recommend "4.75" Max Backspacing or less" which will be fine with your stockers.
    They also recommend 17" wheels but plenty of people run these with 16" wheels with no issue . . .
    http://www.maxtracsuspension.com/05-13-tacoma-fj-cruiser-4-lift-spindles.html
    Also check this very useful thread . . .
    http://www.tacomaworld.com/forum/suspension/203889-maxtrac-spindle-lift-2nd-gen-prerunners.html
  8. Nov 11, 2014 at 12:26 PM
    HectoRome
    DANG ! Sorry, didn't see how old this thread was . . .
  9. Nov 11, 2014 at 2:20 PM
    sevank21
    sevank21 Well-Known Member
    Walker
    las Vegas
    2016 4x4 offroad
    Lmao, more than 2yrs old
  10. Nov 11, 2014 at 2:37 PM
    HectoRome
    Yeah, I'm an idiot !
  11. Nov 11, 2014 at 2:42 PM
    crazy joker
    crazy joker Well-Known Member
    Jesse
    Charlotte area, NC
    2014 DCLB sport 4x4
    skid plates and skinny tires
    Haha. But you were trying to be helpful, so I think you are not an idiot.
