Nexus Collaboration: YWNexus Blackhawk
Discussion in 'Performance and Tuning' started by Mooseditty17, Jan 21, 2022.
  1. Jan 24, 2022 at 8:44 PM
    #101
    Kevinpd325
    Kevinpd325 Well-Known Member
    Kevin
    San Diego
    2017 Tacoma TRD Sport 4x4
    Racks/Storage • Prinsu Cabrack w/ load panels • Leitner Designs ACS • Leitner Designs cargo pods (x2) • Leitner Designs accessory mounts (x4) • Leitner Designs Hi-lift mount • Rotopax mounts (x6) • Harbor freight roof mounted rifle case • FWP Fab bed rail shovel and axe mounts (modified for Leitner ACS) • FWP Fab bed corner mounts (modified for Leitner ACS & air fittings) Wheels/Tires • BFG 285/70 R17 KM3 • Pro Comp 61 series Cognos 17x9 wheels Electrical/Power • Genesis Offroad dual battery system • Odyssey group 34 AGM batteries • Renogy 100w solar panel w/ Voyager charge controller • Renogy 3000w pure sine power inverter • sPod4x4 BantamX • Warn winch isolator solenoid • Powertray x2 (right side modified for solar charger) • DC Power Engineering 270A alternator Engine/Performance • IS350 Custom tune • Revolution gears (5.29 ratio) • Eaton E-lockers (front & rear) • OME carrier bearing drop • Custom rear differential breather • K&N drop-in air filter • Dobinson snorkle • AC drain line mod • Start-X remote start • Redline tuning hood struts Exterior • Meso Customs Gashole • TRD Pro grille w/ LED lights • Pop & lock tailgate lock actuator • Anytime Backup Camera (modified for 2nd rear camera) • AVS in-channel weather guards • Expedition Essentials bedside compressor mount • Custom CMC & pinch weld mod • OEM spare tire well modified to fit 285/70 R17 • Goat armor (arachnid black) • Leitner Designs bed stiffeners • Black raised tailgate letters • Bed stickers removed • Debadged 100% • Herculiner bed liner • Mountain Hatch tailgate insert • Modified right side bed storage compartment for water and power connections • Vinyl wrapped hood & roof • Tacoma Twins Prinsu grab handles & Prinsu accents Interior • Meso Customs lower switch panel • Meso Customs interior chrome delete • Meso Customs extended fuse panel cover • Meso Customs overhead 3 switch panel • Relocated center 12vdc outlet • Dual USB outlet mounted in overhead console • Blue Sea dual USB outlet mounted on rear of lower console • Expedition Essentials 3TPAM w/ Blue Sea rapid charger • Doc Loco Molle rear wall panel • 67 Designs ball mounts • 67 Designs carbon fiber arms • 67 Designs universal device holder • 67 Designs sPod touchscreen mount • Ram Mounts Tab-tite iPad holder • ch4x4 cubby switch mount (water pump, winch power & air compressor switches) • Interior panels painted American flag pattern • Tuff skins glovebox letters • GPCA headrest grab handles • desert.does.it seat jackers Lighting • Caliraised LED dual function 40” light bar • Caliraised LED ditch light brackets & side shooters • Caliraised LED amber chase lights • SpartanX Customs stealth scoop light w/ Nitevision function • SDHQ Dual hidden light bar mount • Extreme LED 30" dual function light bar (x2) • Auxbeam 6x2 amber LED light pods (scene lights) • Opt7 Quantum rock lights • LED interior lighting upgrade • SpartanX Customs tricolor LED headlights & fog lights • yodaTEQ underhood LED lights • Meso Customs V2 Dome light • Meso Customs total tail lights Comms • Uniden Bearcat CB radio (mounted in center console) • Anytone AT878UV UHF/VHF radio • Rago antenna mount Armor • SSO slimline bumper w/ stage 2 • RCI sliders Suspension • Icon Vehicle Dynamics Stage 4 • Icon Vehicle Dynamics tubular UCA w/ delta joint • Icon Vehicle Dynamics RXT leaf springs • Overland Custom Designs swaybar disconnects Recovery • Smittybuilt XRC 9500 w/ synthetic cable (rewired for wireless remote) • Factor55 flatlink • 40” Hi-lift jack w/ Jack Mate • Rototrax • Vault hitch shackle block • Gear America recovery kit Audio • Kicker KS series speakers • Kicker CS dome tweeters. • Kicker 10” powered subwoofer • Subaru Kicker tweeters • Kicker Key 180.4 plug and play amplifier • Mat66 sound deadening (whole interior) Accessories • ARB twin compressor • ARB 35L fridge/freezer • Expedition Essentials propane mount w/ 11 lb tank • Outer Limit Supply first aid kit w/ magnetic mount • Rotopax Gen2 2gal fuel & water cans • Fuelpax 3.5gal cans • Quick release fire extinguisher mounts x2 • Fire extinguisher x2 (5lb & 1lb) • Seaflo series 33 water washdown pump • Custom ABS 5 gallon water tank • Roam Vagabond XL Rooftop Tent • OVS Nomad 270⁰ awning
    Has been for a couple years. I'm on my second set because the company made upgrades. They're made by Overland Custom Designs. Have to custom order them though. Message them on IG. Super responsive.
  2. Jan 24, 2022 at 8:46 PM
    #102
    Kevinpd325
    Kevin
    San Diego
  3. Jan 24, 2022 at 8:53 PM
    #103
    Kevinpd325
    Kevin
    San Diego
    No. There are 2 quick release pins you pull to disconnect it. Swaybar is free to float afterwards. Repinning is kinda tricky, but not terrible. Best way I've found it to get it on level ground and tuck the wheels.
    Mooseditty17[OP] and SpeySquatch like this.
  4. Jan 24, 2022 at 8:54 PM
    #104
    Kevinpd325
    Kevin
    San Diego
    Makes a hell of a noise, but thus is life.
    Mooseditty17[OP] likes this.
  5. Jan 24, 2022 at 8:58 PM
    #105
    Kevinpd325
    Kevin
    San Diego
    They recently added rubber bushings to them, which is why I bought new ones. Haven't gotten the opportunity to test them out yet... Been busy as hell with this tune.
  6. Jan 24, 2022 at 9:55 PM
    #106
    Kevinpd325
    Kevin
    San Diego
    "What's this? Another tune? Why is this different?" You might be asking...
    We all took a step back from a couple years ago to reflect on where the Tacoma was and what the 2GR-FKS platform was about. That led us to really do some digging into the engine/transmission tunes available and completely start over. We took lessons learned and what didn't work so well, and set out in search for actual performance from the engine without power adders. What we found in this journey, and it has been a journey, is that everything else out there just didn't quite do it for us. It was either too touchy (tip-in), didn't deliver properly (dead pedal), or just plain left the engine kinda starving. So, the 4 of us put our heads together and compiled our own tune, dead set of delivering the product to the Tacoma community that they deserve. The tune that SHOULD have been delivered with your truck! Nexus is the way it should have driven to begin with.
    Nexus has been run and tested in various, and extreme environmental conditions and tuned for all terrains. We've run it through blazing desert, mountain elevation, jungle mud, and deep snow. It just keeps pulling. The transmission has been refined to control temperature, yet provide solid delivery to the wheels. It's been tested using all sorts of intake setups, tire diameters, and gear ratios for thousands of miles and all different styles of driving. This isn't something we blasted a few runs on a dyno on a weekend then tossed some charts at you. We spent countless hours building this and the tools to help us make it the living breath WILD BEAST of a truck tune you deserve to drive! We already know there's something you HATE about the tune you're driving. Let us help you love your truck again!
  7. Jan 25, 2022 at 5:29 AM
    #107
    Watkinseli91
    Watkinseli91 Well-Known Member
    Eli
    Greenville, SC
    2021 LR PRO
    Any love for us M/T guys? Had any guys rowing gears with this tune yet?
    Need guinea pigs? :p
    Bob1971 likes this.
  8. Jan 25, 2022 at 5:50 AM
    #108
    Skydvrr
    Skydvrr IG: @kalopsianick
    Nick
    YMH
    Black '17 OR
    Parasitic draw? More like short to ground lol.
    https://www.tacomaworld.com/threads/cooling-issues-not-anymore.682278/
    This isn't a common amp draw number, but it is a possible number. When I ran the AGM tune, my backup cam and other quirks seemed to sprout up. And I never really bothered w it after that.
  9. Jan 25, 2022 at 5:56 AM
    #109
    Mooseditty17
    Mooseditty17 [OP] Seasoned Rookie
    AJ
    WI
    2017 TRD OR : M+W Nexus Tuned
    Tune: Nexus +P Add ons: +3" custom suspension 295/70/18 Yokohama M/T Tires KMC XD Grenade OR wheels KN intake Blackhawk MBRP Exhaust TJM Rock Crawler Bumper Lighting (+10 H.P.)
    Once we finalize all the AT files and get distribution rolling, we will concentrate on the M/T. We've done some testing, but it's not fully ready for release yet. I'll see if the boys are interested in utilizing you as a tester.
  10. Jan 25, 2022 at 5:59 AM
    #110
    Watkinseli91
    Eli
    Greenville, SC
    2021 LR PRO
    If you end up needing a few folks for testing, I wouldn't mind seeing how things go.
  11. Jan 25, 2022 at 10:58 AM
    #111
    fxrman
    fxrman Well-Known Member
    palm springs
    Quicksand 2016 trd double cab off road
    OVT 1.03 Tacoma bed matt Husky floor liners Insain fab aluminum bumper with Baja design s8 30" light bar DB custums grill with Baja design s8 30" light bar
    Well I guess I should send in my dongle
    And get the VF tune registered then figure out how to get it installed and learn how to flash again since I only did it once at least 3 years ago.
    The premium performance version sounds like what I want.
    ktbell444 likes this.
  12. Jan 25, 2022 at 11:25 AM
    #112
    ktbell444
    ktbell444 One who throws exceptions
    ᚺᛖᛚᚺᛖᛁᛗ
    That's what I'm driving and there's honestly nothing comparable in terms of tunes for the Tacoma (that I've test driven).
    shotgunbilly420 likes this.
  13. Jan 25, 2022 at 11:31 AM
    #113
    SpeySquatch
    2016 TRD OR DCSB
    you are driving the +P or the one above that? What is your setup and mpgs?
  14. Jan 25, 2022 at 11:35 AM
    #114
    ktbell444
    ᚺᛖᛚᚺᛖᛁᛗ
    Pretty much the same as I was getting before. Mind you, I have the worst luck. I get stopped at every traffic signal. I also remote start the truck every morning to "defog" so my MPG's have never been "great". But I think my average to work this morning was around 16 with a 7 mile trip, no interstate speeds. That's what I was seeing with just standard 2.0 as well.
  15. Jan 25, 2022 at 11:36 AM
    #115
    SpeySquatch
    2016 TRD OR DCSB
    but you are driving the regular +P or the premium +P? What size tires? Gears?
    Asking because I’m evaluating
  16. Jan 25, 2022 at 12:03 PM
    #116
    Bob1971
    Bob1971 Well-Known Member
    Tim
    KY
    White 2020 Trd OR
    Bed cover, step bars, SCS SR8 wheels
    Following to hear about the MT tunes.
  17. Jan 25, 2022 at 1:06 PM
    #117
    ktbell444
    ᚺᛖᛚᚺᛖᛁᛗ
    +P Premium with stock tires and gears.
  18. Jan 25, 2022 at 1:29 PM
    #118
    rlx02
    rlx02 ¯\_(ツ)_/¯
    Western WA
    2017 Inferno DCSB TRD OR 4x4
    Are there different versions for those of us regeared with bigger tires or does that matter.
  19. Jan 25, 2022 at 1:36 PM
    #119
    Mooseditty17
    AJ
    WI
    Absolutely!
    3.90
    4.88
    5.29
    And really any size tire...
  20. Jan 26, 2022 at 12:11 PM
    #120
    MLee
    MLee Well-Known Member
    Mark
    Knoxville TN
    2018 Limited Cement
    OTT 7.0
    Been on the Daily Driver since last July, and I've been pretty satisfied to leave it alone. Every once in a while I read the latest from the most popular tunes to see what improvements they feel they have made. AJ, any comments to tempt me to fork over another $125-$150 and jump to Nexus? I suspect it to be a further refinement of DD plus some other minor improvements, I can't imagine it's a big jump. DD is still pretty dang good in my opinion but then DD was a noticeable improvement over the original M+W so......
