"Official" Firestone RideRite + Lift Thread
Discussion in '2nd Gen. Tacomas (2005-2015)' started by littleblue81, May 28, 2013.
  1. Jul 27, 2021 at 10:01 PM
    #821
    79CHKCHK
    79CHKCHK Padawan of Rock Lobster
    SoCal no mo
    2018 Super White TRD Pro AT
    Firestone makes brackets for their own kits. They are bolt on and are pretty cheap if I remember correctly. I made some out of spring steel, I had an extra set of scrap leaf springs sitting around. Just drilled a hole in the Firestone bracket and bolted the scrap steel to it. No issues in the last 4ish months.
    DanishTaco likes this.
  2. Jul 27, 2021 at 11:23 PM
    #822
    raskal311
    raskal311 Well-Known Member
    S. Cal
    5100 set to max, pending LSD and TRD CAI
    the Firestone spacers looks like they run $60+
  3. Jul 28, 2021 at 4:26 PM
    #823
    corprin
    corprin Well-Known Member
    corprin
  4. Jul 28, 2021 at 10:39 PM
    #824
    bagleboy
    bagleboy Well-Known Member
    Scott
    Norcal, Santa Rosa
    2014 5-lug AC 2.7L VVTI
    Snug top Rebel, Thule tracks, ditch tracks, Bagged rear suspension, F/R anytime camera, intermittent wiper switch...
    I use these as fill valves connected to a manifold supplied by either compressor & tank or HP paintball cylinder & low pressure regulator. They allow air flow in either direction when open but because of how they are made only seal against pressure in one direction(a very light spring closes unless the solenoid pulls it open) so they would not be good for articulation unless used in tandem with the pressure side towards each bag. I get about a week before I need to add air running ~45 psi.
    Any pressure differential greater than the spring on the non spring side will push them open. Excess pressure on the spring side leaks very slowly.
    To hold air in the bags install with the flow arrow pointing to the supply rather than the air bags.
    If you want truly airtight electric valving you need to go to motorized ball valves which are 4x as big and 8x more costly. I use one but only to supply the manifold so the tank doesn’t leak.
    RyanDCLB[QUOTED] likes this.
  5. Jul 29, 2021 at 7:01 AM
    #825
    corprin
    corprin
    No tank, no compressor, no electric wizardry in mine. Just a ball check valve, two Schraders, and a small bike pump. I just have to get out and flip the valve open/closed.
    Although, my laziness wants a tank, compressor, and electric wizardry. :D
    TRP likes this.
  6. Jul 29, 2021 at 7:13 AM
    #826
    bagleboy
    Scott
    Norcal, Santa Rosa
    I have other uses for the air besides the bags so it made sense to include more control. The wizardry was for fun.
  7. Jul 29, 2021 at 7:28 AM
    #827
    buckhuntin-tacoma
    buckhuntin-tacoma Shed hunter
    Dennis
    Quincy IL
    2014 Spruce Mica Tacoma DCLB
    SocalTaco15 and dave.h like this.
  8. Jul 30, 2021 at 12:18 PM
    #828
    dave.h
    dave.h Well-Known Member
    SLC Utah
    2020 TRD Off Road DCLB
  9. Jul 30, 2021 at 3:39 PM
    #829
    bagleboy
    Scott
    Norcal, Santa Rosa
    I don’t need someone hacking my suspension.
  10. Aug 1, 2021 at 12:03 PM
    #830
    gnardoggie
    gnardoggie Well-Known Member
    anyone break a daystar cradle? because I did :)
  11. Aug 1, 2021 at 1:13 PM
    #831
    dk_crew
    dk_crew Well-Known Member
    Dave
    Austin, TX
    2005 Tacoma 4x4
    Not me. Cracked on impact? What happened?
  12. Aug 1, 2021 at 1:40 PM
    #832
    gnardoggie
    i had a slow leak on the passenger bag, went flat without me knowing/ripped, then i noticed the cradle was busted so id assume the top mount hit it hard on something. it looks like there's a cheaper knockoff version of daystars now on Amazon so it's a 20$ fix for one, thankfully.
    i just wish the bags were that cheap, ha!
    dk_crew[QUOTED] likes this.
  13. Aug 1, 2021 at 3:03 PM
    #833
    79CHKCHK
    SoCal no mo
    Can you cut open the Firestone airbag and confirm they are not internal bump stops? I assume not since you broke the Daystar cradle. I know some Firestones are internally bumped as well as some Air Ride bags.
    Hot Taco sauce likes this.
  14. Aug 15, 2021 at 7:25 AM
    #834
    Hot Taco sauce
    Hot Taco sauce Well-Known Member
    WI
    Dclb lover
    Just starting out, give me time
    :popcorn:
  15. Aug 15, 2021 at 9:18 AM
    #835
    Pigpen
    Dan
    Northwest Montana
    Firestone recommends keeping at least 5 psi in the bags because they do not have internal bump stops.
    since I'm here, I'll post this:
    OME HD Dakar leaf pack, Firestone Ride Rite bags, Daystar Cradles, and a Four Wheel Campers Granby 8 foot camper - modified to fit in a Tacoma.
  16. Aug 19, 2021 at 4:00 PM
    #836
    boxxed
    boxxed Well-Known Member
    Denver, CO
    09 Off Road
    I hate to ask this question BUT...... I have read through most of the threads, even the 1st 2 pages. What is the purpose of the cradles? Is just for off roading? Or is there something I am missing? I dont get it. Please dont flame me to bad, help a guy out...
    Thanks
    I found this
    Product description
    Did you know you lose up to 20 percent of your suspension travel when installing a set of convoluted airbags on the rear of your truck? Daystar has the answer to this problem: The KU09140BK Universal Air Bag Cradle. This unique product will recover your lost suspension travel while keeping all the benefits you want in a set of air bags!
  17. Aug 19, 2021 at 4:36 PM
    #837
    Butt Ugly Chuck
    Butt Ugly Chuck Member
    In a Taco DOWN BY THE RIVER!
    2005 White Access Cab 6sp
    Do floor mats count? ;)
    Bags installed without cradles per Firestone's directions are attached to the frame on one end and the axle on the other. That's OK for on-road or low-suspension-flex. Off-road may experience more flex (extension) than the bags are built for and damage them. With the cradle, the bag is attached only to the frame, and rests in the cradle on the axle side. High flex doesn't result in over-stretched bags.
    Butt
    Coopsdaddy likes this.
  18. Aug 19, 2021 at 5:46 PM
    #838
    boxxed
    Denver, CO
    09 Off Road
    Thank you for that great explanation. I do not really off road so I didn't get the purpose of them.
  19. Aug 19, 2021 at 7:17 PM
    #839
    Matt_DCSB
    Matt_DCSB Well-Known Member
    NM
    What's the solution for those who have u-bolt flip kits?
  20. Aug 19, 2021 at 9:04 PM
    #840
    corprin
    corprin
    Mount cradle to the bump pad, bag to frame.
