Oil Catch Can Install Guide
Discussion in '2nd Gen. Tacomas (2005-2015)' started by CayucosTacoma, Jul 25, 2012.
  1. Jun 15, 2013 at 4:50 AM
    #421
    DolphinJohn
    DolphinJohn Well-Known Member
    Nature Coast, FL
    '13 Access Cab 4x4 SR5
    Drained my can for the first time after 2816 miles of use.
  2. Jun 15, 2013 at 11:53 AM
    #422
    Justus
    Justus fucks not given
    Nabisco the kid
    In ur toolbox
    stockish
    Yummmmy
  3. Jun 15, 2013 at 1:07 PM
    #423
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    That would have been all over your intake runners, cylinders, valves, and cats..... You engine loves you. :D
  4. Jun 20, 2013 at 7:59 AM
    #424
    KenpachiZaraki
    KenpachiZaraki Its Wicked Flow BITCHES!!
    Alex •﹏•
    Lubbock
    05 TRD. 325/275/365 SBD
    ALL POSER- Afe Pro Dry S drop in filter, 3" AP leaf pack, Eibach w/5100's up front, 5100's rear, Fog Light Mod, ABS off mod, Dash Light MOD, Doug Thorley Long Tube Headers, Wicked Flow Bitches MAX Muffler, 4" floods, 20", 43" light bars, 265/75/16 Hankook Dynapro ATm, oil catch can, rear diff breather relocate, Custome Sliders, SOS concepts Front bumper, Demon Eye Mod, backlit TRD emblem on bumper, Morimoto D2S projectors,
    So you just toss that oil, or recycle it back into the engine? I actually need to do this mod since last night I replaced my injectors and I saw the intake had oil residue on it. What about the passenger side? Is that thing that sticks out of the valve cover also a pcv valve?
  5. Jun 20, 2013 at 8:06 AM
    #425
    SconnieHailer
    SconnieHailer PutterClutch
    Marc
    West Central Wisconsin
    2012 TRD Off Road Double Cab V6 6Speed
    Don't recycle it into your engine, it's garbage.
  6. Jun 20, 2013 at 10:17 PM
    #426
    kh7nm
    kh7nm Stay Boosted
    Miles
    Ewa Beach, Hawaii
    2011 MGM DC 4x4 TX PRO Off Road
    What have you done to your truck lately
    Anybody got the oil catch can installed with the TRD Supercharger? If so can you post pictures were to tie in.
    Thanks
    Norton likes this.
  7. Jun 22, 2013 at 1:25 PM
    #427
    Justus
    Nabisco the kid
    In ur toolbox
    stockish
    Pretty sure theres some on xru.
  8. Jun 30, 2013 at 9:38 AM
    #428
    lembowski
    lembowski Well-Known Member
    Rolando, CA
    Jeeper Creeper
  9. Jun 30, 2013 at 9:51 AM
    #429
    CayucosTacoma
    CayucosTacoma [OP] Just think outside the Yota
    San Luis Obispo/San Jose
    2004 Double Cab 4x4
    Specs in the Build Thread
    QUALITY, QUALITY, QUALITY
    I Have the one from eBay... I mean sure it works, but if youre going to do it might as well do it right. When I first got my can, it was basically free, it had such a giant air leak that my truck would also die at idle! :eek:
    And the quality isn't there either. Bottom of the can has a small oil leak, and if you hold one you wouldn't be to impressed either.
  10. Jun 30, 2013 at 10:24 AM
    #430
    Nixinus
    Nixinus Well-Known Member
    Oregon
    2010 4x4
    I have the SM catch can and it has held up very well. Quality is A+ and no problems in 15k miles. I have it mounted to the back of the front bumper support, accessible from the wheel well. As stated above, if you are going to do it then do it right.
  11. Jun 30, 2013 at 11:14 AM
    #431
    Justus
    Nabisco the kid
    In ur toolbox
    stockish
    I have an eBay 1 on my desk..... Connected fittings.... Put hose to mY mouth, blew on it, air leaks from the sight tube.... Debris inside the can, loose parts, just piss poor construction.
    Look at the mounting options, filtering media, machining...... Well speaking from the stealth and ultimates in my hand..... The quality is so much better than the eBay's.
    Having both types in ur hands...... EBay and the 42 DD makes it obvious. But once the buy is over u can others words and reviews into consideration also.
  12. Jun 30, 2013 at 11:33 AM
    #432
    lembowski
    Rolando, CA
    Jeeper Creeper
    Ok, taking ebay out of the equation. Compare the $145 (pre-GB cost) Stealth to the $60 price of this one?
    http://www.saikoumichi.com/micro_oil_catch_can_tank.htm
  13. Jun 30, 2013 at 11:43 AM
    #433
    Justus
    Nabisco the kid
    In ur toolbox
    stockish
    Hard to be thorough with out 1 in my hand and limited info on the site.
    What kinda media in the micro?
    And since ur choosing the more expensive of the stealths.... They have female npt bungs you can use many diff reducers right at the bung.....
    The other one u have to use certain size of line and an inline reducer for some applications and this not only looks poor, I've seen someone here post about the reducers causing a problem.....its also noted in the 42 DD website.
    U rally need to have em both in ur hands..... The 42dd is an awesome piece.
    After 4grand in the blower, I just couldn't skimp on this and feel right about it.
    The filtering media on the 42dd will not degrade and end up being recycled into ur intake manifold either. I dunno bout the scotch brite or sos pad ideas. But I'm not chancing it.
    42dd has clients with these cans on airplanes even..... Build quality has to be top notch.
  14. Jun 30, 2013 at 3:21 PM
    #434
    Nixinus
    Oregon
    2010 4x4
    I would go with stage 1. A little bit more but much better of a price than $145. I don't see any difference considering the SM is welded air tight and I'm running enough hosing (and well below the level of the bypass) to negate any difference in filtering media.
  15. Jun 30, 2013 at 3:56 PM
    #435
    92LandCruiser
    92LandCruiser Well-Known Member
    Nevada
    80 series Land Cruiser
    Cummins, tons, 40s
    I've gone through hell to make this ebay catch can of mine worth a shit. No baffles either, I jb welded one in.
  16. Jul 5, 2013 at 7:03 AM
    #436
    KenpachiZaraki
    Alex •﹏•
    Lubbock
    I was thinking of making my own, what about using an old propane bottle? Like either the fatman or the regular blue longer bottle? I was thinking of having my friend shoot it to relieve any gas in there, then drilling and tapping that hole. What sayeth all knowledgeable TW?
  17. Aug 10, 2013 at 8:20 AM
    #437
    DesertRatliff
    DesertRatliff Well-Known Member
    Mt. Hood, OR
    Mas Tacos Por Favor
    Hope you 2nd gen fellas don't feel this is a hijack, but I can't find any info on this for first gens.
    I'd like to put in a PCV catch can, but on the 3.4L, there's also a vent on the rear driver's side valve cover that's routed to the intake tube just in front of the throttle body. I noticed lots of oil in the intake plenum when I intalled my supercharger the other day and figure the catch can I install needs to have two fittings or I need to go with a dual set-up. Note: although I'm supercharged now, the vac routing doesn't change.
    Can anyone steer me to some info on this for first gen's?
    Thanks
  18. Aug 29, 2013 at 11:30 AM
    #438
    Tacozilla
    Tacozilla Well-Known Member
    So Cal
    2013 DCLB TRD 4X4 MGM
    Curses to you CayucosTacoma and to TW. Just finished saving money for the suspension. I come across this thread you have started. Now I have to save money for this too. J/K
    Wanted to know I do oil changes every 5k, as some of you check the can at 500 then at 1000. Do you ever check your oil level in the engine to see what you are capturing and getting rid of is causing your oil level to go down. So you have to add oil between changes.
    I thought that when these vapors pass through to PVC and then back into the engine that its kinda of like recirculating and some oil become deposites (which I know is the bad gunk) but some work their way back into lubracation.
    OR am I just way off. I can understand these cans in race and off road hi-performance vehicles.
    Just a thought. Some input would be appreciated before I open another coffee can bank account to save for this project.
  19. Aug 29, 2013 at 3:27 PM
    #439
    WATacoRider
    WATacoRider Well-Known Member
    TRD Sport 4x4
    Is there an oil catch can that rules them all for the Tacoma yet or not?
  20. Aug 29, 2013 at 3:36 PM
    #440
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
