Oil Catch Can Install Guide
Discussion in '2nd Gen. Tacomas (2005-2015)' started by CayucosTacoma, Jul 25, 2012.
  1. Nov 11, 2017 at 1:23 AM
    #901
    DaveB.inVa
    DaveB.inVa Well-Known Member
    SWVa
    2015 AC SR5 4x4 V6 AT MGM
    Oil Catch Can, OIl Pressure and Temp Gauges, Falken Wildpeak A/T3W 265/70R16
    Another thing to think of, check where the mass air flow sensor will be in relation to the crankcase vent intake. It will be upstream of the MAF sensor and can potentially foul it if you put a port in the metal tube in your pictures.
    You may be able to find a silicone coupler with a port in it and put it after the MAF tube you have.
    http://www.siliconeintakes.com/holset-turbocharger/-p-500.html
    You may be able to find something like that above, its just a 1/2" port in a tube. That may be all you need though, I can't remember the size, it's close though!
  2. Nov 11, 2017 at 2:31 AM
    #902
    Key-Rei
    Key-Rei Well-Known Member
    Key
    Florida
    I was actually looking at similar fittings, and after how you explained how the system is supposed to work I knew the inlet had to be south of the MAF for the fouking reason, just like how people get issues with the fouled MAF from oiled air filters. :tinfoilhat:
    I was thinking about tapping it directly behind the MAF sensor so that the flow wouldn't be interrupted anymore. Than it already is by the MAF stalk itself. I'll have to scooch my couplers around some but I have the room to do it.
    (Red dot future bung location, blue line maf tube end, green line TB begins.)
    If you're interested, check out my thread over here that explains just whatndaheck is going on with my intake and why.
    https://www.tacomaworld.com/threads/dual-vvt-i-fj-intake-mod-for-tacoma-single-vvt-i-engines.510565/
    DaveB.inVa[QUOTED] likes this.
  3. Nov 11, 2017 at 9:39 AM
    #903
    TireFire
    TireFire Superunknown Member
    Olympic Peninsula
    I've passed visual in CA with a catch can on a BMW. It was all black and looked factory tho
    Drainbung likes this.
  4. Nov 11, 2017 at 10:21 AM
    #904
    TRlPPlN
    TRlPPlN Pavement Cruiser
    Bay Area, CA South SF to be precise
    MGM DCSB 09 DC TRD Sport 4x4 - Family Hauler
    That’s the way I passed with my previous car with an an IM and intake. Painted both flat black so there’s no bling in the engine compartment . I’ll probably do the same with a catch can when the time comes
  5. Nov 11, 2017 at 10:57 AM
    #905
    Drainbung
    Drainbung Somedays you are the show....
    Bob
    Fallabama, NV
    10 DCLB
    TRD Fleshlight
    The genius that just did my smog check was questioning the front axle and transmission breathers...he had to get his boss.
    RickTRDSport likes this.
  6. Nov 11, 2017 at 4:16 PM
    #906
    ThomasMore66
    Dallas/Fort Worth & Durango
    So glad I don’t live there. Too many rules.
  7. Nov 11, 2017 at 7:42 PM
    #907
    TRlPPlN
    :rofl: Out of all things .
    Drainbung[QUOTED] likes this.
  8. Nov 13, 2017 at 3:54 PM
    #908
    WorldWar546
    WorldWar546 Baja Member
    Anthon
    Utah
    TRD Charged '14 Black TX Baja
    TRD Supercharger And a lot of rice n chrome
    How did you guys with supercharger install a Catch Can? I’m so close but yet so far :( I can easily get to the intake side of the PCV but can get the crank case. I have no room to even see let alone to attatch the new hose. I know I got to start pulling parts off like the supercharger colant tank but I want to make sure I’m not missing anything that could make this easier.
    Thanks!
    Norton likes this.
  9. Nov 14, 2017 at 11:02 AM
    #909
    ThomasMore66
  10. Nov 14, 2017 at 6:18 PM
    #910
    Richie Rich
    Richie Rich Toyota Hoarder
    760 (San Diego)
    2010 X-Runner 2011 TRD Sport DC 4x4
    More than I can afford
    So I went to install my catch can today and ran into something.
    Catch can fittings have a 1/2" nipple, PCV and return fittings on the truck are about 50% smaller.
    Not really a fan of the idea of smashing the hose with clamps to try to seal it. Even if it worked, I am far too OCD for hackery like that.
    Should I try to find fittings for the catch can with smaller ports and run a smaller diameter hose?
    Any other suggestions are welcome.
  11. Nov 14, 2017 at 7:02 PM
    #911
    Drainbung
    Bob
    Fallabama, NV
    10 DCLB
    TRD Fleshlight
    The ADD W1 came with two different size fittings. Not sure which one you have but I have to agree with using adapters and clamps looks rough.
  12. Nov 14, 2017 at 7:03 PM
    #912
    Scott B.
    Scott B. Well-Known Member
    Scott
    Georgia
    2015 ACLB SR5 4x4 Expo
    Find smaller fittings for the catch can.
    You might be able to find a hose barb with 2 different sized ends, to convert the hose size, as an alternative.
  13. Nov 14, 2017 at 7:18 PM
    #913
    Richie Rich
    760 (San Diego)
    I have the small Mishimoto one. Only came with one size fittings.
  14. Nov 14, 2017 at 7:21 PM
    #914
    Richie Rich
    760 (San Diego)
    Dude! This might be the solution.
    I was checking through my shed to see if I had any 90 degree fittings that would fit in the catch can and came across a bunch of various sized barbed fittings, some that couple together.
    Going to have to look at that in the AM and see what I have to work with. Thankfully the catch can has NPT threads so I can probably find something.
    Anybody know the inner diameter of the stock PCV hose?
  15. Nov 14, 2017 at 7:21 PM
    #915
    Drainbung
    Bob
    Fallabama, NV
    10 DCLB
    TRD Fleshlight
    That sucks unless you can source the right size fittings.
  16. Nov 14, 2017 at 7:22 PM
    #916
    Drainbung
    Bob
    Fallabama, NV
    10 DCLB
    TRD Fleshlight
    I believe it's 3/8.
  17. Nov 15, 2017 at 6:29 AM
    #917
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    You are correct.
  18. Nov 15, 2017 at 8:29 AM
    #918
    StOrMyThEtAcO
    StOrMyThEtAcO @stormythetaco
    Cody
    CO
    18 TRD Sport mom bus
    All of them
    I took my blower off for an unrelated issue and got it hooked up before I put it back on.
    Not that that answers your question but... Removing the blower isn't to chananging of a task.
    WorldWar546[QUOTED] likes this.
  19. Nov 15, 2017 at 10:02 AM
    #919
    ThomasMore66
    I don’t remember the hoses being an issue. Getting your hand to the PCV, now that was an issue. Blood sacrifice was required.
    WorldWar546, TireFire and Drainbung like this.
  20. Nov 15, 2017 at 11:58 AM
    #920
    WorldWar546
    Anthon
    Utah
    I’ll admit taking off the blower scares me a bit, I’ll try removing the coolant tank first if that doesn’t help I’ll get my big boy pants on and take the blower off, will give me an excuse to paint the valve covers too lol!
    StOrMyThEtAcO likes this.
