Oil Cooler
Discussion in '2nd Gen. Tacomas (2005-2015)' started by kevdog0710, Apr 26, 2018.
  1. Apr 26, 2018 at 9:14 AM
    kevdog0710
    kevdog0710 [OP] Active Member
    Kevin
    Philly area
    Prerunner
    All stock
    I have a '13 Prerunner, no tow package. I am having the trans cooler installed as we speak, it is the B&M supercooler. I just purchased a 3900lb trailer. How important is an oil cooler like the tow package equipped Tacoma's come with?
    I already have a 5500lb receiver and trailer break control.
    Thanks
  2. Apr 26, 2018 at 9:54 AM
    phsycle
    phsycle Well-Known Member
    CA
    How much will you actually be towing? 3,900 lb trailer, but I'm guessing that is empty? Trans/oil cooler would be very beneficial. And hopefully, your trailer has brakes. In which case, you'd need a brake controller as well.
  3. Apr 26, 2018 at 10:04 AM
    StuckinOhio
    StuckinOhio Well-Known Member
    Mark
    Ohio
    12' v6 AC 4x4 SR5
    Having a trans cooler is important.
    Towing in 4 not in H is more important.
    I had a factory oil cooler and upgraded to a B&M to tow a 4,000 enclosed.
    The B&M is much larger than factory.
    It is night and day on how much faster the temps drop after getting up to speed.
    I am running a scangauge to monitor trans temps but it is not req.
    kevdog0710 [OP] likes this.
  4. Apr 26, 2018 at 10:43 AM
    kevdog0710
    Kevin
    Philly area
    Prerunner
    All stock
    The B&M is what is being installed. The reviews were great and it is at least twice the size of the factory trans cooler. I found several engine oil coolers with mixed reviews.
    I have been towing a smaller camper for several years, still got decent MPG's, even though the trans is in 4th gear. I'm sure the mpg's will take a big hit with this camper though.
    Thanks
  5. Apr 27, 2018 at 4:27 AM
    kevdog0710
    Kevin
    Philly area
    Prerunner
    All stock
    Yes empty. I have he break controller, as my post states. Trans cooler was installed yesterday. My questions is regarding the importance of an engine oil cooler, which the 2nd gen Tacoma’s have included with the tow package. My mechanic that installed my trans cooler said I don’t need to worry about the engine oil cooler. That’s for your input.
  6. Apr 27, 2018 at 7:27 AM
    badger
    badger Well-Known Member
    07 SR5
    Install an oil temp gauge and see. No substitute for real data. Coolers generally become needed at the extremes, like crossing Texas in the summer for mountain climbing in heat. A thermostatically controlled oil cooler is a good idea on any truck that works IMO.
  7. Apr 27, 2018 at 7:32 AM
    knottyrope
    knottyrope Well-Known Member
    Knotty
    Bahstun
    09 Taco CCLB 4x4 SR5 4.0
    Pads, rotors, ujoints, 5900K Super White Xenon HID Halogen Bulb Fog Light
  8. Apr 27, 2018 at 9:09 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
  9. Apr 27, 2018 at 9:09 AM
    knottyrope
    Knotty
    Bahstun
    I would like to buy a vowel
