oil filter 2011 V6 surprise
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Bullperry, Dec 17, 2015.
  1. Dec 18, 2015 at 5:18 AM
    #41
    TacomaMike37
    TacomaMike37 Well-Known Member
    13' DCLB MGM
    3k oil changes are at the very least a complete waste of your hard earned money.
    Justn868 and Torspd like this.
  2. Dec 18, 2015 at 5:50 AM
    #42
    jmaack
    jmaack Well-Known Member
    Justin
    Helena Alabama
    Skewped hood silver 4runner
    Ome, Sqeak free dakars, arms, skids, sliders.
    I get what you are saying, but just saying it has twice is assuming filter media is the same material. Idk if it is or not. Curious here but how thick is each material, what are the sizes particles that can be filtered by each. Again just saying the toyota has twice the square inches means nothing. I'm not backing k and n I'm just curious.
    I wonder who makes the toyota filters?
    My truck will use the toyota filters no matter what as they are cheap.
  3. Dec 18, 2015 at 6:42 AM
    #43
    TacoTaco15
    TacoTaco15 Well-Known Member
    Jake
    VA
    2015 MGM DCSB PreRunner 2.7
    I think the Toyotas are made in Thailand? Not sure on thickness - does he address that in his videos?
    On something such as an oil filter, I'm always going to go with the guys who designed my motor, and definitely not the guy next to the dealership yelling "Buy my product - the gainnzzzz!" Snake oil through and through.
  4. Dec 18, 2015 at 6:49 AM
    #44
    hetkind
    hetkind Well-Known Member
    Howard
    Johnson City
    2011 SR5 Access Cab, white with Leer Cap
    bilstein set at 1.75, Racho 5000 rear with 4 leaf kit, floor mats, high lift jack, pull hook in hitch, bed rail corner braces, severe duty brake pads and devil horns on the grill....
    I buy wix filters by the case, and don't worry about filter failure. Whatever makes you happy in filter and oil selection. While there a many brands of filters and oil, very few are truly awful and some are better than others. Mobil one is reasonable in cost and makes me happy.
    Howard
    TacoTaco15 likes this.
  5. Dec 18, 2015 at 7:35 AM
    #45
    TacomaMike37
    13' DCLB MGM
    $ 80 = super high brother. That would be almost 2.5 oil changes for me.
    Do yourself a favor if you want to continue with the ludicrious 3K oil changes and go to mobil 1 and save yourself $50 each change.
    bigfoote13 and R0dzilla75 like this.
  6. Dec 18, 2015 at 11:13 AM
    #46
    JeffreyB
    JeffreyB Well-Known Member
    Jeff
    2015 Access Cab 2.7 5 Speed 4X4
    Let me preface this by saying your truck your money, but here is some math. Lets say you drive your truck for 200,000 miles. That is 67 oil changes every 3k or 40 every 5k. Royal purple oil change every 3k $80x67=$5360. Mobil 1 or similar every 5k $35x40=$1400 and it is still overkill according to black-stone analysis. Once again to each their own, but IMO that is $3960 id rather spend on something else.
    As for the OP, I am not going to use my free oil changes for that exact reason. Those guys don't care about my truck, but I do.
  7. Dec 18, 2015 at 11:29 AM
    #47
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    I love mine too. ^_^
  8. Dec 18, 2015 at 11:34 AM
    #48
    TacomaMike37
    13' DCLB MGM
    You need to stop making sense, like right now.
    JeffreyB[QUOTED] likes this.
  9. Dec 18, 2015 at 12:01 PM
    #49
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    When the new oil and filter start to get dirty I change just the filter, again. IDK about 10k oil changes but I let engine debris and/or the look of the oil and/or the smell of raw fuel tell me when it needs to be changed.
  10. Dec 18, 2015 at 12:54 PM
    #50
    TacomaMike37
    13' DCLB MGM
  11. Dec 20, 2015 at 2:51 PM
    #51
    Bullperry
    Bullperry [OP] Member
    Emerald Coast NW FL
    Caucasion Tacoma 2011 SR5
    Exterior decor: red-clay mud splatter.
    Sorry to take so long to reply to all of these responses to my questions (May lady Luck Bless you all and keep you — but but beware, she is a hot but bitchy divine redhead and you do not want to wake her up from her long afternoon naps with anything trivial, LOL). There is another factor, however, re all the replies regarding too-frequent oil changes and the waste of money. That has to do with the idea that the more you fuck with your vehicle, the more mistakes you can make, or, the off-chance you are using an accidentally bad product which escaped the oil or filter manufacturer's quality control. Toyota's are tough (which was recently proven to me by having to use double-low 4WD on my 2011 Tacoma for the first time in a rough situation. Never had another pickup deal so well without a grunt)! The replies regarding no oil draining from my oil filter after it sat for 3 days, was the most re-assuring of your replies. I was worried about something wrong with my oil pressure system since the warranty has run out. Thank you all for being so helpful and being part of this forum. Put my thanks under your Christmas tree. It's free, and no receipt required to keep and turn in if you want to dispute the quality of it. And "Happy new year" to everyone. May the following months bless you with happy moments of pulling Ford or GMCs out of the ditch. The frosting on the cake? Pulling one of those self-contained, behemoth, self-propelled tourist RVs out of the ditch.
  12. Dec 20, 2015 at 2:56 PM
    #52
    T4RFTMFW
    T4RFTMFW Well-Known Member
    I tried pulling out a domestic brand truck, but my frame snapped on my Tacoma.
  13. Dec 21, 2015 at 12:03 AM
    #53
    TacoTaco15
    Jake
    VA
    Don't be a stranger - loiter around a little! Some great threads going on here lately... and tons of info!
    Cheers! :cheers:
  14. Dec 21, 2015 at 4:47 AM
    #54
    ecoterragaia
    ecoterragaia Everyone lives downstream.
    Central Virginia
    2006 RC 4X4 5 speed & 2021 4Runner SR5
    Seems like 3 oil changes in 4 years is a kinda low, might want to change it every 6 months regardless of mileage. I have no experience with this so I may be wrong.
  15. Dec 21, 2015 at 6:29 AM
    #55
    JeffreyB
    Jeff
    What he said, unless you run synthetic, then annually is probably fine.
  16. Dec 21, 2015 at 3:41 PM
    #56
    Blockhead
    Blockhead Well-Known Member
    Pittsburgh, Pa.
    2024 Silver SR5 DCLB
    Oil is oil and filters are filters...just use what your owners manual calls for and be done with it. Those Japanese engineers know more than guys on forums. Toyota doesn't want any engine warranty claims.
  17. Dec 22, 2015 at 2:06 PM
    #57
    Bullperry
    Emerald Coast NW FL
    Don't be a stranger - loiter around a little! Some great threads going on here lately... and tons of info! (TacoTaco15)
    I can't. I am self employed and my boss is an asshole. PS: "Bullperry" is a character in one of my crime novels. He bad. He lets his girlfriends run around public beaches naked.
    PS: Info in "tons"... ? Love it, but you ever try to hook a chain to some? Even if you could, info is punishable by death in some countries. And chicks naked on the beach? splat!
    -- John Aalborg, AKA Bullperry.
  18. Jan 1, 2016 at 12:26 PM
    #58
    awebber3
    awebber3 TacoTacoTaco
    Andrew
    Charlotte, NC
    '07 DCSB Prerunner 3" lift
    Exterior: MBRP catback dual exhaust Smittybilt N-fab nerf bars Bilstein 5100 shocks & struts OME 885 & add-a-leaf Ballistic Jester 17" 265/70r/17 Nitto Terrra Grappler 5500K Retrofit Headlights (Mini D2S Stage III) Black badges, Black bull bar w/ LED Pods Satoshi Grill mod K&N air filter Tri-Fold bed cover Rearview camera EGR in-channel rain guards 10% tint rear, 10% tint front, 70% tint on windshield Pop-a-Lock tailgate handle Spidertrax wheel spacers Cab mount chop BIG 3 upgrade LED Running Board lights Black LED tail lights (’09 and up style) Black LED 3rd brake WOLO Air Horn Interior: Kenwood excelon DDX9703S 2 JL 10W1V3-4 10'' subs Alpine type-R component speakers in front Alpine type-S component speakers in rear Kenwood Excelon XR900-5 amp Weather Tech laser cut floor mats Cobra radar wired in Viper 5704 alarm w/ auto start & added glass break sensor and tilt sensor
    there is also no reason to take a shower everyday but people do that too. if i want to waste my money ill continue to do that. and im pretty sure everyone is aware that synthetic oil last a lot longer than 3k miles. K&N filters are double the price of purolator because the wall thickness is double that of the purolator (makes sense)
    Lab results from mobil 1 vs royal purple:
    "The Mobil 1 5w-30 had a TBN of 3.9 at 4000 miles and Royal Purple had a TBN number of 2.6 after 4000 miles.. So what does this mean?? The Mobil 1 had more life left in it.. I could go to around 7000 miles on a change.. The DIC read 30% oil life remaining when I changed the oil at 4000 miles on both samples which is right on Par with the TBN number.. The Royal Purple had a lower TBN number than the Mobil 1.. So I suspect maybe 5000-6000 miles of total life from Royal Purple, before it goes under the 2.0 TBN number."
    mobil 1 is great oil... but as science has proved royal purple is superior in longevity.
    and go ahead and stick a foot in your mouth because i only pay $40 for my 6 quarts of royal purple AND the K&N filter. thats pretty much the same a Mobil 1. I only drive the truck less than 100 miles a week. so thats only a few changes a year. so why not change it every 3k miles.
    so now that the facts are laid out lets hear from the ones who like to try and disprove facts with their opinions. starting.........NOW
  19. Jan 1, 2016 at 12:55 PM
    #59
    libagui
    libagui Well-Known Member
    Dominican Republic
    05 tacoma prerunner
    Bilsteins 5100 set at .085 Rear custom 1" add a leaf 265/70 R17 tires. Custom made aluminum tonneau cover with bike rack. 4x4 conversion with 4Runner transfer case.
    So, the fact is you justify why you waste your money..!
  20. Jan 1, 2016 at 2:02 PM
    #60
    jbrnigan
    jbrnigan Well-Known Member
    Midwest
    2015 TRD Sport, 4X4, 4.0L, Auto - Access Cab
    Shit pal, TW members line up to throw themselves on the swords of their opinions, oil, filters (oil and air) lifts, shocks, tires, wheels, seat covers, floor mats, mud flaps, ad nauseum. - LOL
    Torspd likes this.
