Oil Filter Change
Discussion in '2nd Gen. Tacomas (2005-2015)' started by cfw4x4, Jun 27, 2017.
  1. Jun 27, 2017 at 10:49 AM
    coopcooper
    coopcooper certified youtube mechanic
    alberta canada
    black on black on black 05 trd off road
    stickers and sticker accessory's
    the mobil 1 filter got me to almost 20k with Pennzoil platinum
  2. Jun 27, 2017 at 11:07 AM
    127.0.0.1
    127.0.0.1 AKA ::1
    /etc/hosts
    2013 NBM AC 4.0 4x4 Auto OR
    your mpg loss is in your head
    the only way to measure this, as you are saying it, mpg loss due to 'dirty oil'
    is
    a) the tacoma is set up on a dyno bench in controlled atmosphere chamber
    b) you refine your own gasoline and provide it as laboratory grade and exact measurements
    c) run computerized and controlled engine operating patterns on that dyno
    d) compare results
    no way no how is 5000 miles of dirty oil affecting your MPG. unless it has sand in it.
  3. Jun 27, 2017 at 11:08 AM
    127.0.0.1
    127.0.0.1 AKA ::1
    /etc/hosts
    no. unless this guy is running this in an engine lab, nope.
    scottalot likes this.
  4. Jun 27, 2017 at 11:39 AM
    80schild
    80schild Well-Known Member
    Chad
    Flori-Bama
    2007 TRD Sport Access Cab
    I don't care what anyone says, I go by how the oil looks, synthetic or not. After about 4k miles, if the oil stills looks fairly clean on the dipstick I'll keep running it, but as soon as it turns very dark, it's getting changed. Of course this varies by the engine, some are just naturally harder on oil than others.
  5. Jun 27, 2017 at 12:40 PM
    Blockhead
    Blockhead Well-Known Member
    Pittsburgh, Pa.
    2024 Silver SR5 DCLB
    Yes OEM...there's not a better filter for your truck.
    R0dzilla75 and Krazie Sj like this.
  6. Jun 27, 2017 at 3:21 PM
    PackCon
    PackCon Well-Known Member
    Connor
    2017 Subaru Forester Limited
    All full synthetics last 10k. If you see otherwise on manuals (like the Toyota Manual for the 2015 Tacoma) that recommends 5k changes it's just to make $$$. Hence why I don't blindly follow manuals. They tend to arbitrary and aren't based on science.
  7. Jun 27, 2017 at 4:15 PM
    wheeliest
    wheeliest ///////////////////
    Json
    TMPE AZ
    05-SWB-DCSB-4X4-V6-SR5-SPORT
    NO SWAYBAR, Spacer lift with dirty4's
    Just FYI, Filter bypass OPENS all the time, specifically on start-up, I work in Aerospace MFG QC and AIAG world, ASTM, SAE, JIS, MIL ISO, AS9100 etc.. The reason I run over sized filters is due to the bypass valve..
    Torspd, Norton and JoefromPTC like this.
  8. Jun 27, 2017 at 6:58 PM
    Crosis
    Crosis Tertiary adjunct to unimatrix 01
    Dunedin Fl
    09 Tacoma 4x4 TRD Off Road
    OEM is fine. There is no valid reason to use anything else.
  9. Jun 27, 2017 at 7:48 PM
    winkel
    winkel Well-Known Member
    Corydon, IN
    2014 Spruce Mica, TRD Off-Road, 6 Spd Manual
    Sliders, Tailgate Liner
    I'm running the Fram 3600. It's taller than the 3614 and have read other posts where guys have been running them for some time.
    I run the XG which is the top of the line for Fram. On the Fram filter specification page, they have the exact same specs and dimensions with the exception of the height or length of the filter.
    Do this at your own risk and bring on the flames!
  10. Jun 28, 2017 at 12:45 AM
    Norton
    Norton Senior Member
    Colorado Springs, CO
    2013 Access Cab 4x4 V6 6MT, TRD OR & Tow Packages
    Magnuson S/C w/12TRDTacoma's Qwikchange Hub & 2.5" RIP-Modded Pulley, Roostfactor's Pulley Wrap Mod; FPR Mod; JustDSM Tune via HPT MPVI2; mightytacoman Intercooler Tank; aFe POWER Magnum FLOW Pro DRY S Air Filter; OME Suspension Lift (885 Coils, Dakar Leafs, NitroCharger Sports); TRD Quickshifter w/TRD 6-Spd Knob; TRD Exhaust; NSB-AGM27F Battery w/HKB Adjustable Voltage Booster & Coupe's TRD Battery Hold Down; Goodridge SS Brake Lines; Trident904's MT ADM; BFG All-Terrain T/A KO2s on FJ SE Anthracite Rims; N-Fab 6-Step Nerf Bars; BPF TRD Skid, Tow Hook, & Cooling Panel; jsi's Locker Anytime, Up2NoGood's 2Lo Module; ramonortiz55's Always on Power Outlet Relay, ND4's Fog Light Anytime, & Crom's Speed Bleeder Mods; crashnburn80's Ultimate Headlight & Fog Light Upgrades; ThreatLevelMidnight's Wireless Charger; 4Runner 4X4 & FJ Fog Light Switches; redtaco2007-inspired LED License Plate Lights; AudioControl LC2i LOC, JL Audio XD200/2v2 Amp, Focal PS165V1 Spkrs, Sound Ordnance B-8PTD Sub, Hushmat & Noico Sound Insulation; loginfailed-inspired Speedhut Boost & AFR Gauges in a Lotek Pillar Pod; Ltd Auto-Dim/Compass/Temp/Backup Camera/Homelink mirror on ImMrYo's Mirror Lift Bracket; TacomaBeast Glove Box & Console Organizers; Husky Floor Liners; UltraGauge EM; mesojdm's Ultimate LED Dome & Map Lights & GASSHOLE; Redline Tuning QuickLIFT Elite; Mobtown Offroad Locking Bed Storage Doors; Toyota Bed Mat; Cali Raised Led Bed Stiffeners; Pop & Lock Power Tailgate Lock w/TacomaTruckParts Support Bracket; ARE Z-Series Cap, SolarGard Tint; BlendMounted & MirrorTapped Uniden R3; CravenSpeed Stubby Antenna; Amsoil Lubricants; Adam's Detailing Supplies
  11. Jun 28, 2017 at 12:54 AM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    The trucks go 500k on Walmart filters. Use what you like.
    Lester Lugnut likes this.
  12. Jun 28, 2017 at 3:25 AM
    3coma
    3coma my kid says my truck is "Boss"
    rob
    19 dcsb sport cement 4x4
    Put bigger tires on and forget about how bad your mileage is.:D
    westtexasbaja likes this.
  13. Jun 28, 2017 at 6:16 AM
    bgdv1
    bgdv1 Well-Known Member
    dave
    butler,pa
    '24 TRD Sport
    I run Mobil 1 filters in all our vehicles and Amsoil oils. I still change at 5K do to our short daily commutes. When I was young I used Fram until I had a filter fail and after switching to Mobil1 filters and seeing how the oil stayed cleaner longer id NEVER put a fram on a vehicle. Now that's my personal opinion and experience others will vary.
  14. Jun 30, 2017 at 4:57 PM
    winkel
    Corydon, IN
    I've run Fram filters my entire life and have two Toyotas now with over 265,000 miles on them with no problems. My wife's Sienna has about 180,000 miles on it and is like a brand new van.
    BUT, I may give the Mobil 1 filter a try on my Taco next time and see if this is true! I have 277,000 on my Corolla and the oil NEVER gets really black. Of course, that's probably because I have to add a quart every 1,500 miles.....
  15. Jun 30, 2017 at 5:30 PM
    #35
    TexasWhiteIce
    TexasWhiteIce Well-Known Member
    Texas
    2022 White DCLB SR5 - Blackout
    The mobil synthetic oil in my truck goes black every 6 months even though I only put about 2,000-3,000 miles on it, granted I make lots of short trips (5-6miles)
  16. Jun 30, 2017 at 11:51 PM
    #36
    Chuy
    Chuy Well-Known Member
    Lakeside, CA
    07 V6 DCLB 4X4 Sport
    Silver Taco
    Bigger oil filter means more oil capacity for the engine, which rarely is a bad thing. Yes, the PH8A and equivalent will fit. The gasket is a little larger diameter than OEM, but it fits fine. The PH3600 and equivalent is longer than OEM with same diameter gasket.
    Unless you are going by the severe duty schedule (racing, off-roading, etc...) stick to the PH3600's. And if you are using synthetic oil, get a synthetic oil filter. I've tested my oil at 10K with Mobil 1 Extended Performance syn oil, and results (TBN value) indicated I could have gone another 3K+.
    Cross-referencing
    Fram PH8A
    Mobil M1-301
    Wix 51515
    Purolator L30001
    Fram PH3600
    Mobil M1-201
    Wix 51516
    Purolator L20195
    fla_sun likes this.
  17. Jul 1, 2017 at 4:32 AM
    #37
    ARB1977
    ARB1977 It’s a beaut Clark
    North Texas
    15 DCSB Prerunner 4.0L Blue Ribbon Metallic
    Black TRD Fj Cruiser wheels, TRD catback exhaust.
    95 Ford Taurus V6 filter will work. About an inch taller than the D3.
  18. Jul 1, 2017 at 4:38 AM
    #38
    Clearwater Bill
    Billy
    Largo Florida
    I do the same with my bloodwork. When the nurse draws it, I look it over before it goes off to the lab.
    Regardless of what the stupid Dr. says, I tell him it was red, and I don't need any of his faux pills for cholesterol, diabetes, etc that you learn about from blood 'tests'.
    Looking at it is good enough for me too!
    Maticuno, Norton, JdevTac and 2 others like this.
  19. Jul 1, 2017 at 11:40 AM
    #39
    Hugh Morron
    Hugh Morron Manic Mechanic
    Bill
    Schuylkill County, PA
    12 DCLB SR5 4X4 Barcelona Red Metallic
    ARE Cap, AVS Bugdeflector II, AVS Ventshades, DTRL delete, ABS/VSC/TRAC disable, Toyota LSD with clutchpacks, N-Fab Lightbar, Hella 700ff lights
    I have been using the Wix 51515 filter for years now. I have the tow package with the oil cooler and it fits fine.
  20. Jul 1, 2017 at 11:45 AM
    #40
    TheCookieMonster
    TheCookieMonster cookies!!!!!!!!!!!
    North East
    1995 Hi Lux 22re 4x4 5speed
    Michelin MS2 K&N drop in filter
    yzzd3 Toyota OEM
    Norton likes this.
