Old Man Emu: Questions, Answers & Pictures
Discussion in 'Suspension' started by 4Wheelin4Banger, Jan 15, 2013.
  1. Jan 23, 2013 at 5:12 PM
    #221
    evanmb31
    evanmb31 Well-Known Member
    evan
    connecticut
    09 trd off road
    Satoshi'd grill. blacked out badges. aftermarket sound system. De-chromed and color matched. OME 885s + Dakars with 3rd leaf removed. LR UCAs. Scs stealth 6 with 285 duratracs. BAMF sliders
    Yes it probably would. I removed my UCA to install the shocks because i installed LR UCAs, so i decided not to mess with the LCAs. It didn't take much force at all to get the shock/spring in place. If i felt like i was prying to hard i would have loosened the bolts. Thats good advice though
  2. Jan 23, 2013 at 5:13 PM
    #222
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    The x models resist sagging more than the previous versions.
  3. Jan 23, 2013 at 5:13 PM
    #223
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    They won't sag
  4. Jan 23, 2013 at 5:17 PM
    #224
    evanmb31
    evan
    connecticut
    09 trd off road
    I would be more worried about the leaf springs sagging than the 885s. I say skip the spacer. Or get a 2" AAL if you want the spacers for a little more height.
  5. Jan 23, 2013 at 5:19 PM
    #225
    Burgess65
    Burgess65 Active Member
    So without the spacer, I should be at 3 inches of lift with the 885s? Sorry if these seem like dumb questions. I don't want to have to get it all installed and regret not installing the spacers.
  6. Jan 23, 2013 at 5:20 PM
    #226
    OZ-T
    Peter North
    British Columbia
    With an AC you should be close , another option is to use 1/4" spacers
  7. Jan 23, 2013 at 5:23 PM
    #227
    evanmb31
    evan
    connecticut
    09 trd off road
    I got about 2.5 inches of lift on my access cab from 885s (pics on first page :cool:) but most access cabs seem to get a little more from what i have read.
  8. Jan 23, 2013 at 5:24 PM
    #228
    JonnyBb
    JonnyBb I have to return some videotapes
    Arkansas
    2021 TRD Pro (upgrade from my 2nd gen)
    Work in progress, but mods so far; OTT 7.0 tune, 255/85/16 Falken WildPeak M/Ts
    You can actually install toytecs tp14 spacers with the stock studs so at least you won't have to breakdown the strut again.
  9. Jan 23, 2013 at 5:24 PM
    #229
    Burgess65
    Lol. I wish that would have been an option from toytec when i bought it.
  10. Jan 23, 2013 at 5:24 PM
    #230
    evanmb31
    evan
    connecticut
    09 trd off road
    Got an alignment with no issues a month or two ago. What do you mean my 2009? Yes i bought it used from a dealer in CT
  11. Jan 23, 2013 at 5:25 PM
    #231
    OZ-T
    Peter North
    British Columbia
    It is
  12. Jan 23, 2013 at 5:26 PM
    #232
    Pugga
    Massachusetts
    He means the LCA bolts and inner bushing sleeve are probably just a big ball of rust by now. Ask me how I know... :rolleyes:
  13. Jan 23, 2013 at 5:26 PM
    #233
    OZ-T
    Peter North
    British Columbia
    Yep
  14. Jan 23, 2013 at 5:27 PM
    #234
    evanmb31
    evan
    connecticut
    09 trd off road
    Lol right over my head. Mine arnt bad. Thanks to tacomaworld i keep an eye on them and make sure salt doesnt stay on my truck.
  15. Jan 23, 2013 at 5:27 PM
    #235
    Burgess65
    Gotcha. I love your truck by the way. The MGM is a sweet color. Part of me says throw them on there and just hope for the best. If all else fails, i could either take them off or bite the bullet and improve the rear leaf by getting some dakars.
  16. Jan 23, 2013 at 5:28 PM
    #236
    Pugga
    Massachusetts
    Toyota doesn't lube the bolts when the put them through the LCA bushing so they rust together over time. If you can get yours out, lube them up and reinsert them so they can't seize up later on. Mine were rusted solid. Rob and John helped me replace them, it was a PITA and required some torch work.
  17. Jan 23, 2013 at 5:29 PM
    #237
    OZ-T
    Peter North
    British Columbia
    That doesn't matter , it gets in the bushing and seizes the bolt to the bushing sleeve
  18. Jan 23, 2013 at 5:31 PM
    #238
    evanmb31
    evan
    connecticut
    09 trd off road
    So what you guys are saying is, its about time to do some preventative maintenance. Knew i should have went to firestone and got the lifetime alignment. :frusty:
  19. Jan 23, 2013 at 5:34 PM
    #239
    evanmb31
    evan
    connecticut
    09 trd off road
    Thank you :thumbsup: someone brought up that you can add a 1/4 spacer with disassembling the shock/spring and pressing in longer studs. So if you are not happy with it right away add the 1/4" spacers before you get an alignment.
  20. Jan 23, 2013 at 5:35 PM
    #240
    OZ-T
    Peter North
    British Columbia
    You can put a wrench on them and they seem free , but what is actually happening is it is just twisting in the bushing and it's actually seized to the sleeze
    Ask me how I know
    BandanaBerg likes this.
