Old Man Emu: Questions, Answers & Pictures
Discussion in 'Suspension' started by 4Wheelin4Banger, Jan 15, 2013.
  1. Aug 31, 2013 at 9:55 PM
    #2541
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    Did you keep your Dakars ?
  2. Aug 31, 2013 at 9:56 PM
    #2542
    pbcolt
    pbcolt Well-Known Member
    Colton
    San Diego
    2024 F250 Tremor
    FWC Hawk
    Unfortunately not.
  3. Aug 31, 2013 at 9:58 PM
    #2543
    OZ-T
    Peter North
    British Columbia
  4. Aug 31, 2013 at 10:01 PM
    #2544
    pbcolt
    Colton
    San Diego
    2024 F250 Tremor
    FWC Hawk
    Haha. More power to ya. They make it for a reason.
  5. Sep 1, 2013 at 9:56 AM
    #2545
    Jaren
    Jaren Member
    Jaren
    Park City Utah---Durango Colorado
    2013 Super White TRD
    2013 White DCSB All Pro Armor Rigid Industries LED Lighting WARN Zeon 10-S Factor 55 Pro Link Method Race Wheels
    I think the 886s are why your UCAs are angled down more than others, its not the UCA. Im guessing you have more than 3" of lift right? Also your tire clearance to your stock UCA has to do with both tire width + wheel offset/backspace. You probably need an aftermarket UCA to get your caster to spec with the truck as is ... unless you get your bumper and winch and drop the front down.
  6. Sep 1, 2013 at 10:07 AM
    #2546
    Jaren
    Jaren Member
    Jaren
    Your tires are likely rubbing because the stock rim has a lot of +offset and your tires are almost 32" tall (taller than stock), nothing to do with your UCAs. You need wheel spacers or a wheel with less + offset. You will definitely need more like a 0mm offset wheel with a 285 tire.
  7. Sep 1, 2013 at 10:12 AM
    #2547
    aw10tacoma
    aw10tacoma backyard mechanic
    Andrew
    Northern New Jersey
    2011 AC Mgm
    -HomerTaco Grille -Aftermarket Headlights Halo Projectors -rear doors now have pioneer speakers -Kenwood DNX690HD -LED speedo gauge swap and faceplate along with painted needles - auto start and alarm from compustar -TRD painted on grille -Strobe lights in reverse lights -All bulbs are led -XD rims -arb bumper -S.O.S. Concept SLIDERS -OME 3inch suspension lift nitrocharger sport shocks dakar leafs -light racing ucas -toughtlight 22''dual led bar behind my homertaco grille -wet okale seat covers -trailer lights connection moved into bumper -tints -trd cold air intake -trd catback exhuast -total chaos lca skids -Budbuilt Skids -DT Long tubes -URD MAF SENSOR
    anybody have an issues with the traction control wire possibly breaking after you finished with the 3inch ome lift... i didnt have a problem until thursday night after i was driving home from getting my truck alignment done... the traction control light is on the whole time driving... not the traction control off light its the light that would turn on when the wheels were sliding... took it back to the guy and they have no idea i checked the wires and plugs and everything looked fine... im going to be meeting up with someone who has a newer scanner to check it out but i wanted to see if anyone else encountered this problem before i drive an hr to meet up with the guy with the scanner
  8. Sep 1, 2013 at 11:21 AM
    #2548
    CanadianTRDOffRd
    CanadianTRDOffRd Well-Known Member
    British Columbia
    07 Black TRD Off Road
    Painted black rear bumper Painted front grill Maxpider digital fit floor mats Black Tail Lights Black Depot headlights Full OME lift LR UCA's Relentless front Bumper Thule Rack System 285/70/17 KO2’s
  9. Sep 1, 2013 at 11:36 AM
    #2549
    OZ-T
    Peter North
    British Columbia
    Wut
    You can run 265/70/17 on factory wheels without rubbing , his caster needs to be adjusted most likely
  10. Sep 1, 2013 at 11:37 AM
    #2550
    OZ-T
    Peter North
    British Columbia
  11. Sep 1, 2013 at 12:13 PM
    #2551
    OZ-T
    Peter North
    British Columbia
    The VSC light will come on and stay on if there is a code , the VSC goes into a safe ( off ) mode
  12. Sep 1, 2013 at 12:18 PM
    #2552
    aw10tacoma
    Andrew
    Northern New Jersey
    2011 AC Mgm
    i went threw those posts but i didnt see anything my truck is showing... my braking seems fine.. my truck is showing the symbol that it should only show when im losing traction... it goes away by turing the truck off and on and once i start driving again it will turn back on...
  13. Sep 1, 2013 at 12:30 PM
    #2553
    aw10tacoma
    Andrew
    Northern New Jersey
    2011 AC Mgm
    its pretty centered... but i did ride the truck for about a month before getting the alignment done after the lift and i never had a problem with that light until the ride home from them doing whatever they did...
  14. Sep 1, 2013 at 2:26 PM
    #2554
    YOTA LOVER
    YOTA LOVER Stay Calm, and Fire For Effect
    NH
    2011 MGM Tacoma DCLB SR5
    A slew of pricey stuff my wife hates me for.
    I've had intermittent vsc issues, but only when cornering hard (no wheel slip). I have 5 tires I rotate, so I think one is always a hair larger than the rest, thus causing the issue.
  15. Sep 1, 2013 at 2:29 PM
    #2555
    m.reed.1
    m.reed.1 Well-Known Member
    Adam
    Sacramento, CA
    2015 MGM TACOMA TRD OFFROAD 4WD
    A few
    how can I get more travel out of an ome 885 kit.. or should i just look at another brand. I have a '13 prerunner DC and only wanting about 2.5-3 inch of lift but more down travel and not a ride that will knock your teeth out
  16. Sep 1, 2013 at 2:48 PM
    #2556
    YOTA LOVER
    NH
    1. You don't need more down travel.
    2. If you do you need to go LT or SAS.
  17. Sep 1, 2013 at 3:18 PM
    #2557
    usmcmax
    usmcmax Well-Known Member
    Andrew
    Okinawa/Virginia
    None yet.
    Someone help me out here. I have been putting a lot of planning into my build for when I get back from Afghanistan. Right now I'm planning a full OME lift, 886's no top plate spacer, total chaos UCA's, 285/75/16 tires. Relentless bumpers front and back and sliders. Can anyone address my concerns for weird vibrations I might get after install. I know some people get them, some don't; most everyone suggests the carrier bearing drop kit. How likely is it that I'm going to have weird vibrations from the get go. Also with the 6 speed 4.0 I realize I am going to take a hit on mpg but am more concerned with sluggishness, basically if anyone has a similar build can you give me some input on whether or not you're dogging the engine out just getting around town. I know this is pretty vague but I'm looking for some insight or someone to tell me that its not that bad, but after reading through the whole thread I am starting to worry that its more trouble than it may be worth. Thanks.
    Andrew
  18. Sep 1, 2013 at 4:31 PM
    #2558
    YOTA LOVER
    NH
    ^^^ if you've got the 4.0 you'll be fine. Stay safe.
  19. Sep 2, 2013 at 4:50 AM
    #2559
    m.reed.1
    Adam
    Sacramento, CA
    A few
    anyone with a prerunnerDC and doesnt like the ome 885'S?
  20. Sep 2, 2013 at 11:39 AM
    #2560
    jetta.the.hut
    jetta.the.hut B4nn3d
    Aren
    Aberdeen,NC
    2013 Access Cab Long Bed 4x4
    i got some 885's and read in another thread, average without weight on the front is 2" to 2.5" i was looking for closer to 3" should i buy a small strut spacer for the top to achieve the 3". im waiting on the rear to show up before i install anything so now is the time to buy it instead of later.
