Old Man Emu: Questions, Answers & Pictures
Discussion in 'Suspension' started by 4Wheelin4Banger, Jan 15, 2013.
  1. Jan 23, 2013 at 5:39 PM
    #241
    evanmb31
    evanmb31 Well-Known Member
    evan
    connecticut
    09 trd off road
    Satoshi'd grill. blacked out badges. aftermarket sound system. De-chromed and color matched. OME 885s + Dakars with 3rd leaf removed. LR UCAs. Scs stealth 6 with 285 duratracs. BAMF sliders
    I think i know how you know
    BandanaBerg likes this.
  2. Jan 23, 2013 at 5:43 PM
    #242
    evanmb31
    evan
    connecticut
    09 trd off road
    Thanks for the advice guys. Added to the to-do list
  3. Jan 23, 2013 at 7:13 PM
    #243
    Tacoma414
    Tacoma414 Well-Known Member
    Cody
    Agua Dulce
    06 PreRunner SR5 4.0L
    Flowmaster Exhaust 2" spacer lift 09 Tails blacked out Black headlight mod 6000k HIDs/Foglight mod Fog Light Mod 20" LED Light Bar Behind Grille Billet Grille Color matched mirros, doorhandles and bumper 5% tint all around Pioneer 4300dvd 2 10" kicker CVRs Alpine speakers Dome light: Blue LED Map light: White LED
    Evanmb31 what were you saying I should measure?
  4. Jan 23, 2013 at 7:41 PM
    #244
    evanmb31
    evan
    connecticut
    09 trd off road
    From the center of your hub to the bottom of the fender flare. Up front stock is around 20.5", measure the rear also. Try to find a level spot for accurate measurments
  5. Jan 23, 2013 at 9:34 PM
    #245
    AllMountainToy
    AllMountainToy Well-Known Member
    Northern California
    2011 Tacoma Double Cab 4X4 TRDOR
    2 3/4 OME Suspension Lift with 885, with trim packer, 1/4" top plate spacer, swaybar relo bracket. Dakar leaf pack with 3rd leaf removed. 285/70/17" BFG AT. XD Wheels with 4.5 BS, Best Top Soft Top, Undercover winch mount with Warn 8k winch (with synthetic line), Pioneer touchscreen double din head unit. 4X innovations welded sliders. roof mounted DVD system.ATO dual battery tray with dual yellow tops. Rugged ridge isolator kit.
    Couldn't agree more.
  6. Jan 23, 2013 at 9:38 PM
    #246
    AllMountainToy
    Northern California
    1. Get them preassembled.
    2. The spacer will come on it already but can easily be removed without messing the spring
    3. If you do get the spacer and decide to leave it on, make sure to tighten the the nuts that hold the spacer on mine were just spun on by hand
    I originally ordered the .5" spacers and it lifted my front way too much. I ordered the .25" spacers and live it.
  7. Jan 23, 2013 at 9:43 PM
    #247
    AllMountainToy
    Northern California
    I used to have 3" Pro comp coils and shocks on the font and left rear stock with tsb pack. I had a very slight bro lean but not much at all
  8. Jan 23, 2013 at 9:48 PM
    #248
    AllMountainToy
    Northern California
    From experience recently...the .5 is way too much. It does sit level IF you are running the full Dakar pack. All in all too much lift. I then went with .25" spacers and trim packer and removed 3rd leaf from pack. Ride is really amazing and the difference between front and rear is 1/16th of an inch
  9. Jan 23, 2013 at 9:50 PM
    #249
    AllMountainToy
    Northern California
    Listen to OZ. he totally steered me right
  10. Jan 23, 2013 at 9:52 PM
    #250
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    If he gets OME coils the trim packer goes under the coil
  11. Jan 23, 2013 at 9:56 PM
    #251
    AllMountainToy
    Northern California
    Correct. Trim packer at the bottom. Spacer on top. sorry if I said something different
  12. Jan 23, 2013 at 9:58 PM
    #252
    OZ-T
    Peter North
    British Columbia
    Just making sure everybody is on the same page , no worries
  13. Jan 23, 2013 at 10:19 PM
    #253
    jimbo808
    jimbo808 Well-Known Member
    Kapolei, Hawaii
    05 TRD Sport 4x4
    Debadged, Mbrp cat back turn down, Afe drop in filter, Icon extended travel, Light Racing ucas, Dakars, Icon 2.0 vs monotubes, 285/70r17 goodyear kevlar Mtrs, Morimoto Minis D2S' bhlm with blacked out bowls, Bamf Sliders, pelfrey single hoop front bumper, smittybilt X20 10k, pelfrey ifs skid, pelfrey trans skid, all pro rear with side plates, sway bar removed, front superbumps, Avec 20 inch light bar, rigid flood fogs
  14. Jan 23, 2013 at 10:32 PM
    #254
    OZ-T
    Peter North
    British Columbia
  15. Jan 23, 2013 at 11:00 PM
    #255
    jimbo808
    Kapolei, Hawaii
    05 TRD Sport 4x4
    thanks, what would you recommend for a 3 inch lift?
    5mm trim packers on each side or 10mm?
    or should i go to the top plate route?
  16. Jan 23, 2013 at 11:04 PM
    #256
    OZ-T
    Peter North
    British Columbia
    The 5mm OME trim packer goes on the driver's side only , below the coil , to correct for taco lean
    You will most likely get around 2 3/4" lift on an AC with 885's , if you want a bit more lift you can add 1/4" top plate spacers on both sides
  17. Jan 24, 2013 at 3:56 AM
    #257
    evanmb31
    evan
    connecticut
    09 trd off road
    Another one, this guy has 5100s though
    http://www.tacomaworld.com/forum/suspension/259759-banging-noise-w-885x-coils.html
  18. Jan 24, 2013 at 4:01 AM
    #258
    samsung
    samsung Well-Known Member
    George
    Sugar Land, Texas
    2011 PreRunner doublecab TRD Offroad
    undercover lid/Ipod integration kit/Pop n lock/bed rug, fumoto drain valve, full piping Wet Okole covers, Blacked out badges, Lamin-X fog light cover yellow, window tint, ARB deluxe bumper with fog light kit,DSM UCA'S,3 support shrockworks sliders,complete OME lift with 886X coil and dakar leaf spring with 3 degree axle shims and center pin lenghtener,warn VR10000 winch,amsteele blue synthetic rope, daystar winch isolator, daystar delrin rollers, IPF 900xs Extreme Driving H9 Kit 900XSD (900XSD),Horn on fire with shot Penning,
  19. Jan 24, 2013 at 4:04 AM
    #259
    evanmb31
    evan
    connecticut
    09 trd off road
    This one could be something different, he didnt go into much detail
  20. Jan 24, 2013 at 4:34 AM
    #260
    samsung
    George
    Sugar Land, Texas
    he just posted, it's when going over speed bump.
