Old Man Emu: Questions, Answers & Pictures
Discussion in 'Suspension' started by 4Wheelin4Banger, Jan 15, 2013.
  1. Dec 2, 2013 at 6:03 PM
    #3081
    elclem21
    elclem21 Quebeker
    Clément
    Alberta, Canada
    2009 Tacoma TRD DCLB
    OME 885x front, TC UCAs, OME Dakars rear, 4.30 gears, Eaton Detroit Truetrac (rear diff), HomerTaco Raptor Style satoshi grill
    My bad, I looked too fast, I skipped a word :rolleyes:.
  2. Dec 2, 2013 at 6:27 PM
    #3082
    nj636
    nj636 Hub Master General
    Kev
    Jersey
    OME lift 4x sliders 4x skids
    longer center pins
    and like OZ said.. put the center pin collars in while your there in-case you have to put shims under the leaf pack
  3. Dec 2, 2013 at 6:32 PM
    #3083
    TRD6Speed
    TRD6Speed senior member
    Bill
    East Hartford, CT
    08 TRD Sport Access Cab
    885x with 5100s and top plate spacer for full 3", RCD extended 5100s in rear, dakars, flip kit, LR UCAs, tint, shorty antenna, in channel rain guards,BHLM, blacked out emblem, OEM side steps, weathertechs, debadged, rear diff breather
  4. Dec 2, 2013 at 6:34 PM
    #3084
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
  5. Dec 2, 2013 at 6:35 PM
    #3085
    elclem21
    elclem21 Quebeker
    Clément
    Alberta, Canada
  6. Dec 2, 2013 at 7:15 PM
    #3086
    TRD6Speed
    Bill
    East Hartford, CT
    I got that too ;) 12 bux didn't break the bank.
    Got the shims, cb drop, and flip kit while I was at it.
  7. Dec 2, 2013 at 7:44 PM
    #3087
    elclem21
    elclem21 Quebeker
    Clément
    Alberta, Canada
    Comming this spring, for now I will run my 265/70-17 winter tires.
  8. Dec 3, 2013 at 2:48 PM
    #3088
    TRD6Speed
    Bill
    East Hartford, CT
    Im in the same boat............will have to rock the 265's for a bit until my wallet can recuperate from its beating this weekend. Prob a spring purchase for me as well.:eek: Not a huge deal as I don't feel like tackling the CB chop and trimming right now which I will prob need to do unless I find that magic combo of wheels and tires some guys seem to find.
  9. Dec 7, 2013 at 4:12 PM
    #3089
    Hunter.V.White
    Hunter.V.White Well-Known Member
    Hunter
    Fairbanks, AK
    2013 DC 4WD TRD-Off Road
    Pelfreybilt Steel Armor, Famous Fabrication Sliders, OME 3" Lift, 886x coils, Dakar Leaf Packs, TC UCA's, Fuel D551 Wheels, 285/70/R17 Toyo Tech RTs, Warn Zeon 10s Winch, Rigid Industries 20" E2 Flood, RI 20" SR Spot/flood, RI Duallys, SwitchPro SP8100, Uniden Bearcat 680 CB Radio.
    I just ordered the full kit from ToyTec!
    886x coils
    Complete Dakar leaf pack
    TC UCA's
    Extended Brake Lines
    U-Bolt Flip Kit
    Sway Bar Relocate Kit
    The plan is to put on 285/75/R16 Duratracs for the winter driving here. I also plan to add more armor and a winch in the spring after I rebound from this expenditure (thus the 886x coils).
    I'm hoping to do the install myself with some help from some guys I work with. I can't wait to get it on my truck!
  10. Dec 7, 2013 at 6:33 PM
    #3090
    machineman89
    machineman89 Well-Known Member
    Matthew
    San Leandro
    overlanding limo in progress :-P
    Weather tech floor mats, fog light any time mod, derped front embelem, Pelfretbilt 3 hoop plate bumper, 10k warn xeon winch-s some leds, pelfreybilt roof rack, scs stealth series rims, wrangler authority tires, BAMF 96" bolt on sliders, BAMF dif skid, some dirt....
    I envy you... lol Congrats, iam holding off right now n considering goin LT n keep around the same level of lift
  11. Dec 8, 2013 at 2:05 PM
    #3091
    YOTA LOVER
    YOTA LOVER Stay Calm, and Fire For Effect
    NH
    2011 MGM Tacoma DCLB SR5
    A slew of pricey stuff my wife hates me for.
    That's how I built mine up. You'll like the 886s without the armor in pavement around corners, not so much flex though. I added armor and deleted the sway. Had to install the 1/2" top plate spacer to reduce rake then. Just finally got in the LR UCAs.
  12. Dec 9, 2013 at 10:47 AM
    #3092
    stitch
    stitch PreRunner
    Erick
    Georgia
    04 prerunner sr5 v6 double cab
    none yet
    I have read a lot of threads here and the OME sounds great except for one thing, the Dakar curse. I, as most people I assume, cant stand squeaking. Has any body been able to permanently rid this problem? One more thing, I know the lift settles after awhile. After it settles at around 2in, is it still recommended to get a upgraded UCA?
  13. Dec 9, 2013 at 11:16 AM
    #3093
    la0d0g
    running for the hills
    For crawling not hauling
    Squeak fix: http://www.tacomaworld.com/forum/su...s-any-advice-others-dakars-2.html#post3371352
  14. Dec 9, 2013 at 11:37 AM
    #3094
    stitch
    stitch PreRunner
    Erick
    Georgia
    none yet
    Thx la0d0g for the sight, from what I read there it that there really is not perma fix. I assume due to the quality of the leafs that the squeak is worth it. All I want is a stronger leaf pack, I don't care about lift, actually 2 in would be max I would want. im only replacing my factory leafs cause they are rain bowing with no weight in the bed and the factory replacements are really expensive with the tendency to break. Any suggestions would be very helpful.
  15. Dec 9, 2013 at 11:37 AM
    #3095
    stitch
    stitch PreRunner
    Erick
    Georgia
    none yet
    By the way, la0d0g, I love your truck.
  16. Dec 9, 2013 at 11:42 AM
    #3096
    OZ-T
    Peter North
    British Columbia
    It's permanent until you wear through the rubber strips , in my case that's about 6 months
  17. Dec 9, 2013 at 11:52 AM
    #3097
    stitch
    stitch PreRunner
    Erick
    Georgia
    none yet
    I guess every 6 months isn't to bad. Thx OZ-T. Does any body know why Dakars squeak more than other leafs like say allpro?
  18. Dec 9, 2013 at 11:56 AM
    #3098
    OZ-T
    Peter North
    British Columbia
    I don't know if the actually do , but the squeak with the Dakars tends to come from the front where the second leaf wraps the front eye , there is no leaf isolator in this location so it's metal on metal , perhaps other leaf packs have a slightly different geometry
    Having said that , the minor annoyance of the occasional squeak is outweighed by the improved load handling characteristics as far as I'm concerned
  19. Dec 9, 2013 at 12:03 PM
    #3099
    YOTA LOVER
    NH
    ^^^This. Also, some get lucky and don't develop a squeak.
  20. Dec 9, 2013 at 12:04 PM
    #3100
    stitch
    stitch PreRunner
    Erick
    Georgia
    none yet
    Do you know if the first gens have the same issue, im assuming they do but just a question. I would love to wrap my truck in a full OME kit and for $1,200 you cant beat it. I drive about 90% paved road with the back full of three bicycles, tools and camper topper with various out door or beach gear. Im not sure if the dakars would be over kill or not with that little weight in back. I also do the ocational moving a friend, or some furniture delivery and the every once in a while bed full of fire wood.
