Old Man Emu: Questions, Answers & Pictures
Discussion in 'Suspension' started by 4Wheelin4Banger, Jan 15, 2013.
  1. Feb 14, 2013 at 6:39 PM
    #681
    Ds2199
    Ds2199 Active Member
    Golden, CO
    2013 TRD Sport
    OME 885 Coils, OME 9000 Nitrocharger struts, OME N182 Rear Shocks, Dakar Leaf springs, N-Fab steps, Katskins Leather seats, Weathertech floor liners
    I meant UCA. Edited post
  2. Feb 14, 2013 at 6:48 PM
    #682
    Ds2199
    Golden, CO
    2013 TRD Sport
    So I edited my post for the record. Gen 2 kit from toytech and clarified my errors in attempting to describe Upper Control Arms (UCA).
    I guess I'll try to get back on track. Is the major price difference due to the difference in price for an AAL vs. complete leaf pack? If I'm not towing, are the Dakars overkill?
    Consensus seems to be replace UCA.
  3. Feb 14, 2013 at 6:50 PM
    #683
    evanmb31
    evanmb31 Well-Known Member
    evan
    connecticut
    09 trd off road
    Satoshi'd grill. blacked out badges. aftermarket sound system. De-chromed and color matched. OME 885s + Dakars with 3rd leaf removed. LR UCAs. Scs stealth 6 with 285 duratracs. BAMF sliders
    Email headstrong offroad, see if they will do another one. Last one they did i think there was like 70 buyers, $355 shipped.
  4. Feb 14, 2013 at 6:51 PM
    #684
    skygear
    skygear                    
  5. Feb 14, 2013 at 6:53 PM
    #685
    evanmb31
    evan
    connecticut
    09 trd off road
    Yea price difference is for the leaf pack, if you add dakars to your order from toytec it is like $400 more. Best price i have seen on a full OME kit is from down south motorsports, $1149 shipped to your door. Shipping get expensive with the heavy leaf springs
  6. Feb 14, 2013 at 6:53 PM
    #686
    JonnyBb
    JonnyBb I have to return some videotapes
    Arkansas
    2021 TRD Pro (upgrade from my 2nd gen)
    Work in progress, but mods so far; OTT 7.0 tune, 255/85/16 Falken WildPeak M/Ts
    Yeah, that accounts for the difference in price. Daks versus AAL is tough. Daks can ride rough without a load on them. I sold the Daks from my kit to a buddy and his DCSB does ride a little stiff (like a truck should though). A lot of guys are pulling a leaf out of the Daks. Not sure if that is to improve ride or to decrease the height. Wheelers sells a heavy duty 3 leaf AAL now too. Maybe that is a way to comprise between the Daks and AAL.
  7. Feb 14, 2013 at 6:58 PM
    #687
    evanmb31
    evan
    connecticut
    09 trd off road
    I did this, mainly to reduce the height so my truck sits closer to level. But it probably softened up the ride a little also. I am really happy with the daks, not to stiff at all for me.
  8. Feb 14, 2013 at 7:03 PM
    #688
    JonnyBb
    Arkansas
    Another thing to consider. I bet the stock leaf pack will wear out long before those Daks do....even with an AAL on the stock pack. Especially if you have a non-TSB pack. Just my two cents.
  9. Feb 14, 2013 at 10:32 PM
    #689
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    You could take out an overload too
  10. Feb 14, 2013 at 10:37 PM
    #690
    AllMountainToy
    AllMountainToy Well-Known Member
    Northern California
    2011 Tacoma Double Cab 4X4 TRDOR
    2 3/4 OME Suspension Lift with 885, with trim packer, 1/4" top plate spacer, swaybar relo bracket. Dakar leaf pack with 3rd leaf removed. 285/70/17" BFG AT. XD Wheels with 4.5 BS, Best Top Soft Top, Undercover winch mount with Warn 8k winch (with synthetic line), Pioneer touchscreen double din head unit. 4X innovations welded sliders. roof mounted DVD system.ATO dual battery tray with dual yellow tops. Rugged ridge isolator kit.
    .5" spacers are way way too much. Use the .25" spacers, remove 3rd leaf if you are running dakars and you will be within 1/16" from level.
  11. Feb 15, 2013 at 1:55 AM
    #691
    evanmb31
    evan
    connecticut
    09 trd off road
    Ya i removed the third leaf from the bottom. Hub to fender i am at about 23 3/8"
  12. Feb 15, 2013 at 5:53 AM
    #692
    nj636
    nj636 Hub Master General
    Kev
    Jersey
    OME lift 4x sliders 4x skids
    Toytec's ?
  13. Feb 15, 2013 at 6:18 AM
    #693
    northern cal
    northern cal Active Member
    bay area
    tacoma TRD
    I'm wanting to do the same thing. Your 23-3/8" measurement and a more compliant ride is what I'm shooting for.
    How hard is to remove that third from the bottom leaf?
  14. Feb 15, 2013 at 6:44 AM
    #694
    evanmb31
    evan
    connecticut
    09 trd off road
    Its very simple just use a big c-clamp or two to clamp the leafs together. Remove the nuts and bolts i think 3 of them. Pay attention to which way they go together, do one leaf pack at a time and you wont have any problem. Release the clamps and they come right apart, there really isnt much tension. Only advice would be do it somewhere clean so you dont get debris in between the leafs which will lead to squeking. Oh ya and dont use a impact on the centering pin bolt, i stripped a nut when i did lol, the centering pin nut doesnt even have to be very tight because your u-bolts will help clamp everything together. Either one will be the same process wether you remove the third leaf down or the top overload. I would assume removing the 3rd leaf will reduce the lift more than removing the 2nd overload. OME says -3/4 but i think removing the 3rd leaf reduced my lift by 1-1 1/2 inches.
  15. Feb 15, 2013 at 12:13 PM
    #695
    4Wheelin4Banger
    4Wheelin4Banger [OP] Supercharged Toyman
    Randy
    Ferntucky, NV Halfway between Reno & Falabama
    2011 4x4 Access Cab Supercharged Silver State Edition 245WHP
    3" OME lift 885s & Dakars riding on 33" KM2s
    Do you like rake? If so get the Dakars. If not get the Dakars and pull a leaf.
    885s will give you over 2.5" and Dakars will give somewhere around 3".
    I got a full 3" from 885s on my 4Banger AC & run stock UCAs.
    With a good alignment guy he will get you close to spec if not in spec on caster (I'm close but not in spec & it has no driving problems i.e. high speed wander or bump steer).
    A good alternative from what I've heard.
    I don't tow & love the Dakars.
  16. Feb 17, 2013 at 2:20 PM
    #696
    Sandman614
    Tim
    Garner, NC/Boone, NC
    '06 SR5 Off Road
  17. Feb 17, 2013 at 11:00 PM
    #697
    luka
    luka Well-Known Member
    Kailua, HI
    Prerunner -> 4WD Converted
    Pelfreybilt, Warn, BAMF, DTRL toggle on/off, FJ OEM Fog/Aux Light switches, 2012 lower center console swap, wired in auto-dimming rear view mirror, Wet-Okole inside, Weathertech , Rigid, Tint, Roto-Pax, Bestop, OME, Extended SS brake lines, TRD TX Pro/Baja Graphite 16" Rims
    ordered my kit yesterday;
    886 coils with 90000 fronts
    dakars+aal with 60091 rears
    should have my LR UCA's ready when it comes in probably within a month.
  18. Feb 17, 2013 at 11:02 PM
    #698
    OZ-T
    Peter North
    British Columbia
    Centre pin collars and trim packer ?
  19. Feb 17, 2013 at 11:04 PM
    #699
    luka
    Kailua, HI
    i'll have to order those seperately, 4wheelparts doesn't carry those in their kits. 100$ freight shipping here was the reason for going with them.
    good looking out Oz :p
  20. Feb 17, 2013 at 11:11 PM
    #700
    OZ-T
    Peter North
    British Columbia
