Old Man Emu: Questions, Answers & Pictures
Discussion in 'Suspension' started by 4Wheelin4Banger, Jan 15, 2013.
  1. Sep 1, 2015 at 12:59 PM
    #7741
    mach1man001
    mach1man001 eh whatever
    Rob
    Bellingham, MA
    2024 Tundra Limited
    I love my new truck but miss my Tacoma
    I could be wrong but don't you want to go heavier spring rate and not just longer? Wouldn't longer springs w/non-adjustable struts would be the same as preloading your existing adjustable ones if the spring rate is the same?
  2. Sep 1, 2015 at 5:07 PM
    #7742
    mahaloTaco
    mahaloTaco TcBob's BFFL
    Max
    Los Angeles
    13 RC 4x4 S/C'd lockers 4.88's Airflow Snorkel McNeil Glass
  3. Sep 1, 2015 at 5:08 PM
    #7743
    SixthSnail
    SixthSnail I have no idea what I'm doing
    Los Angeles
    '14 Tacoma Sport
    See Build in Sig
  4. Sep 1, 2015 at 5:36 PM
    #7744
    mahaloTaco
    Max
    Los Angeles
    which 886 gives 2.5 " of lift?
  5. Sep 1, 2015 at 5:36 PM
    #7745
    SixthSnail
    Los Angeles
    '14 Tacoma Sport
    See Build in Sig
    There is only 1
    Arailt and mahaloTaco[QUOTED] like this.
  6. Sep 1, 2015 at 6:50 PM
    #7746
    Fifthwind
    Fifthwind Master of None
    Murph
    Lehigh Valley, PA
    Scully
    Barcelona Red 09 DCOR- Icon 2.5" ECOs w/CDC - 14" 700lb, ICON 2.0 RR Ext rears, AP EXPO pack, Diff Wedge, Diff and Skid Drop, Discoverer S/T 255/85/16, Ride-Rite Bags w/ Daystars, ARB Bull/winch Bumper, Warn 8k, ARB CMK12, Budbuilt skids, BAMF bolt on sliders BAMF diff diaper, bedlights, hoodlights, BAMF CB, etc.
    Those are 620lb/in eibach springs, the shortest solution would be to get 700lb/in eibach springs of the same length. Chances are that Toytec or some other vendor like Downsouth can get you the springs, just get the number off the side of the spring or at least measure the circumference of the springs.
  7. Sep 1, 2015 at 7:12 PM
    #7747
    mahaloTaco
    Max
    Los Angeles
    I'm looking for 2.5" to 3" of lift. I was going to go with 886's but now I am uncertain.
  8. Sep 1, 2015 at 10:57 PM
    #7748
    YOTA LOVER
    YOTA LOVER Stay Calm, and Fire For Effect
    NH
    2011 MGM Tacoma DCLB SR5
    A slew of pricey stuff my wife hates me for.
    Y
    You have armor, you want 886's. You'll eventually install a winch and possibly full skids... 886s.
  9. Sep 1, 2015 at 11:05 PM
    #7749
    SixthSnail
    Los Angeles
    '14 Tacoma Sport
    See Build in Sig
    What @YOTA LOVER said
    vrod671 likes this.
  10. Sep 2, 2015 at 7:16 AM
    #7750
    mAtTyG04
    mAtTyG04 Well-Known Member
    Edmonton
    2019 Quick Sand OR
    6112 Front Suspension, Fox 2.0 Rear Shocks, Nitto Ridge Grappler - LT285/75R17 C, Rear Blackout Tacoma Badge, De-badged, Icon Rebound Wheels, TRD Grill Gights, CBI Ditch Light Brackets w/ Baja Design Lights, Husky Liners, JBA UCAs, Geenlane Off-road Sliders, Tacotrooper Decal, DuraBump Rear Bump Stops, Pro-clip USA Phone Mount
    I don't think they make a 700 lbs spring. I contacted Toytec. They recommended their longer coil. Still 620lbs but will require less pre-load to achieve 2.5"
  11. Sep 2, 2015 at 8:19 AM
    #7751
    Fifthwind
    Murph
    Lehigh Valley, PA
    Scully
  12. Sep 2, 2015 at 8:37 AM
    #7752
    mAtTyG04
    Edmonton
    2019 Quick Sand OR
  13. Sep 2, 2015 at 9:29 AM
    #7753
    raggedphoto
    raggedphoto Well-Known Member
    Oregon
    DCSB 07 Desert Sand Mica
    For long haul vs short crawl
    So this maybe a question for another thread but I have this rattling/clunking coming from the driver side front end whenever I hit bumps or washboards. It's bad enough that I can feel it on the floor boards so something is certainly bumping around. It
    definitely started after I installed the new coils, shocks and upper control arms but because I didn't drive it much before the alignment I am not sure if started before or after taking it to be aligned. For reference I have Light racing control arms, 886 coils with nitrochargers (assembled by Toytec), steel bumper and winch.
    I have checked and torqued;
    - All front parts (control arms, sway bar, struts, bumper..)
    - cab mounts
    - Sway bar does not seem to be hitting the coil
    - there is not any play in the wheels
    The passenger side seems fine so I am bit lost on where to go from here, might just take into a shop. Any ideas on what else to check? Maybe the coil isnt seated properly?
    Thanks guys
  14. Sep 2, 2015 at 9:40 AM
    #7754
    la0d0g
    running for the hills
    For crawling not hauling
  15. Sep 2, 2015 at 10:29 AM
    #7755
    raggedphoto
    Oregon
  16. Sep 2, 2015 at 10:31 AM
    #7756
    la0d0g
  17. Sep 2, 2015 at 11:55 AM
    #7757
    mahaloTaco
    Max
    Los Angeles
    Kyitty likes this.
  18. Sep 2, 2015 at 12:02 PM
    #7758
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
  19. Sep 2, 2015 at 12:02 PM
    #7759
    SixthSnail
    Los Angeles
    '14 Tacoma Sport
    See Build in Sig
  20. Sep 2, 2015 at 12:04 PM
    #7760
    mahaloTaco
    Max
    Los Angeles
    maybe like 2.5?
