Old Man Emu: Questions, Answers & Pictures
Discussion in 'Suspension' started by 4Wheelin4Banger, Jan 15, 2013.
  1. Mar 25, 2013 at 11:59 AM
    #941
    luka
    luka Well-Known Member
    Kailua, HI
    Prerunner -> 4WD Converted
    Pelfreybilt, Warn, BAMF, DTRL toggle on/off, FJ OEM Fog/Aux Light switches, 2012 lower center console swap, wired in auto-dimming rear view mirror, Wet-Okole inside, Weathertech , Rigid, Tint, Roto-Pax, Bestop, OME, Extended SS brake lines, TRD TX Pro/Baja Graphite 16" Rims
    That's what i'm hoping for.
    Even during the installation, I had to use the LCA with a floor jack to compress the spring and it started lifting the whole truck off the jackstands.
    OME has some seriously beefy products.
  2. Mar 25, 2013 at 12:36 PM
    #942
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    4 degrees from what ?
  3. Mar 25, 2013 at 4:58 PM
    #943
    fbj913
    fbj913 Member
    KC MO
    08 TRD
    Damn! I just can't decide if I want the full OME lift or the ultimate lift kit from Toytec. I'm sure its been hashed out other places... can anyone shed some light on this? Has anyone experienced both?
    I will not do any serious constant rock crawling
    I just want more clearance and better overall suspension performance for back country adventure trips...
    No desert runs at high speeds
    It is my daily driver
    Price isn't the deciding factor
  4. Mar 25, 2013 at 5:01 PM
    #944
    evanmb31
    evanmb31 Well-Known Member
    evan
    connecticut
    09 trd off road
    Satoshi'd grill. blacked out badges. aftermarket sound system. De-chromed and color matched. OME 885s + Dakars with 3rd leaf removed. LR UCAs. Scs stealth 6 with 285 duratracs. BAMF sliders
  5. Mar 25, 2013 at 6:30 PM
    #945
    fbj913
    fbj913 Member
    KC MO
    08 TRD
  6. Mar 25, 2013 at 6:37 PM
    #946
    nj636
    nj636 Hub Master General
    Kev
    Jersey
    OME lift 4x sliders 4x skids
    pinion angle.. 4 degrees down
  7. Mar 25, 2013 at 6:38 PM
    #947
    evanmb31
    evan
    connecticut
    09 trd off road
    No problem. I don't see a huge difference in the kits. One benefit of going with 5100s over OME is the extended length of the front shocks is over 1" longer. A benefit of OME is you can use the trim packer to adjust for taco lean. Without the trim packer you can use top plate spacers to adjust for the lean which is fine. Only problem with that is if you want a full 3" lift you will need a 1/4" spacer on the passanger and a 1/2" top plate spacer on the drivers side which will require longet top plate studs.
  8. Mar 25, 2013 at 7:41 PM
    #948
    OZ-T
    Peter North
    British Columbia
    So zero and 4 ?
    Shouldn't they be zero / zero ?
  9. Mar 25, 2013 at 8:43 PM
    #949
    nj636
    Kev
    Jersey
    not sure how you do it by the way I do is driveshaft angle subtracted from pinion angle @ pinion flange. this was four degrees negative stock.
    with dakars in it brought me to 7 degrees negative. adding a 3 degree shim brought me to 4 degrees and ... no vibes.
    if you set it to zero you'd have positive angle which would wreak havoc & destruction.
  10. Mar 25, 2013 at 8:45 PM
    #950
    OZ-T
    Peter North
    British Columbia
    Zero at the tranny , zero at the pumpkin is what I was saying
  11. Mar 26, 2013 at 4:17 AM
    #951
    nj636
    Kev
    Jersey
    objective is to adjust the pinion angle. if your at zero with the truck at rest, then you have positive pinion angle while under acceleration, cruising down the road which will create vibration & excessive u-joint wear.
    *how did you obtain zero @ the trans?
  12. Mar 26, 2013 at 7:31 AM
    #952
    OZ-T
    Peter North
    British Columbia
    I think you might be missing the point I'm making , the output flanges at the tranny and pumpkin should be aligned ( same angle , zeroed ) to one another
  13. Mar 26, 2013 at 8:32 AM
    #953
    YOTA LOVER
    YOTA LOVER Stay Calm, and Fire For Effect
    NH
    2011 MGM Tacoma DCLB SR5
    A slew of pricey stuff my wife hates me for.
    Found an informative link-
    http://www.hotrodhotline.com/md/html/drive_shaft_harmonics.php
    It's common to "clock" the transfer case down to alleviate extreme driveline angles for rigs that have a lot of lift. In my old rig I had 6" of lift, with 3" from the Drakar springs and the other three from extended shackles. The shackles helped nose up the rear diff, but I needed to clock the transfer down (to zero out the angles). For example, I might have been at 2 degrees up on the rear, but I was 3 or 4 down off the transfer. I was poor, so I didn't. The result was excessive wear and tear on the front u-joint at the transfer. Over time the yoke started to show signs of fatigue and needed to be replaced. I only noticed the yoke going to hell when I replaced the u-joint because it was getting thrashed.
  14. Mar 26, 2013 at 9:02 AM
    #954
    nj636
    Kev
    Jersey
    your talking drive line angle, yes that should be zero under acceleration/load (drive line angle = trans angle - pinion angle). that doesn't exactly mean zero at the trans & zero at the pinion flange. to obtain that, like i said, i added shims (easiest & most common way to obtain proper drive line angle).
    your saying your angle's are zero @ the trans & zero @ the pinion?
  15. Mar 26, 2013 at 9:04 AM
    #955
    nj636
    Kev
    Jersey
    you've got the right idea :thumbsup: :woot:
  16. Mar 26, 2013 at 9:23 AM
    #956
    fbj913
    fbj913 Member
    KC MO
    08 TRD
    Anyone running the HD OME kit with no steel bumper? I know a few of you here installed the HD but then almost immediately installed the front bumper. I'm talking 5,000 miles later, how does it feel? I'm sure its rough at first but does it calm down at all? I really want the HD kit but my front bumper purchase is a ways out...
  17. Mar 26, 2013 at 11:50 AM
    #957
    OZ-T
    Peter North
    British Columbia
    That is what I am trying to obtain ( 0,0)
    Right now I have (0 , 4 )
  18. Mar 26, 2013 at 11:56 AM
    #958
    Large
    Large Red
    If by the HD kit you are referring to the 886s, mine didn't settle much of any without weight on the front.
  19. Mar 26, 2013 at 12:11 PM
    #959
    fbj913
    fbj913 Member
    KC MO
    08 TRD
    Thanks. But not worried about settling. I'm wondering about ride quality.
  20. Mar 26, 2013 at 1:11 PM
    #960
    nj636
    Kev
    Jersey
    -4 at the pinion?
    driving down the road the -4 pinion is damn close if not 0.
    I think a go pro shot of the pinion is needed as a visual aid for this lesson :rolleyes:
