Old Man Emu: Questions, Answers & Pictures
Discussion in 'Suspension' started by 4Wheelin4Banger, Jan 15, 2013.
  1. Mar 28, 2013 at 11:37 AM
    #981
    The_Hodge
    The_Hodge Volunteer Moderator
    SC
    15 Lariat Sport 5.0L
  2. Mar 28, 2013 at 12:01 PM
    #982
    nj636
    nj636 Hub Master General
    Kev
    Jersey
    OME lift 4x sliders 4x skids
    it's this easy:
    1) measure transmission output shaft angle (@ bearing cup, yoke ect.)
    2) measure drive shaft angle near output shaft
    3) subtract smaller # from greater #, this is your angle. 1 degree is optimal.
    Do the same at the pinion (rear). easiest way to adjust this angle is using shims.
  3. Mar 28, 2013 at 12:02 PM
    #983
    nj636
    Kev
    Jersey
    now measure your drive shaft angle like i said above ^^^
  4. Mar 28, 2013 at 12:05 PM
    #984
    testedone
    testedone Speak English..it's America
    Rick
    U.S.A.
    2010 Tacoma TRD Sport
    Weathertec Mats, Pioneer AVIC-X930BT, Pioneer GEX-P920XM (SAT), Pioneer Premier TS-D602P 6.2, Blaupunkt THb 200A Sub, Trimmed Mud Flaps, BF Goodrich AT/KO 285/70/17 ... Toytec Ultimate Lift, Tuffy Bed Box, A.R.E. Cover, Pop-n-Lock, TRD Exhaust
    ok... I have the AAL with my Toytec Ultimate lift (2 years old) and thinking of putting a complete leaf pack in.... I sag just a tiny, tiny bit now, is it going to jack the rear up to much to where I like like I am starsky and hutch in a torino?
  5. Mar 28, 2013 at 12:12 PM
    #985
    evanmb31
    evanmb31 Well-Known Member
    evan
    connecticut
    09 trd off road
    Satoshi'd grill. blacked out badges. aftermarket sound system. De-chromed and color matched. OME 885s + Dakars with 3rd leaf removed. LR UCAs. Scs stealth 6 with 285 duratracs. BAMF sliders
    Lol, whats you hub to fender measurement now? Compare that measurement to the ones in OZ's dakar thread and there ya go. You can remove leafs from the dakars also if you don't want to much lift
  6. Mar 28, 2013 at 12:26 PM
    #986
    OZ-T
    OZ-T You are going backwards
    Peter North
    British Columbia
    :wave:
  7. Mar 28, 2013 at 12:28 PM
    #987
    evanmb31
    evan
    connecticut
    09 trd off road
    What does MYA mean!
  8. Mar 28, 2013 at 12:52 PM
    #988
    testedone
    Rick
    U.S.A.
    23.5 on passenger side
    24 on Drivers side
  9. Mar 28, 2013 at 12:55 PM
    #989
    OZ-T
    Peter North
    British Columbia
    How does that system insure the tranny output and pumpkin output are aligned ?
  10. Mar 28, 2013 at 12:56 PM
    #990
    evanmb31
    evan
    connecticut
    09 trd off road
  11. Mar 28, 2013 at 1:03 PM
    #991
    testedone
    Rick
    U.S.A.
  12. Mar 28, 2013 at 1:45 PM
    #992
    evanmb31
    evan
    connecticut
    09 trd off road
    Depends on what you consider significant really. Your at 24, 23 1/2 so lets say 23 3/4 average. So according to other averages you can expect 7/8" more lift give or take. If you want to see what it will look like find a spot on your frame to jack up one side of the rear end up a little
  13. Mar 28, 2013 at 1:50 PM
    #993
    testedone
    Rick
    U.S.A.
    ok, I was thinking you would see a rise of 1.5 or so... 3/4 to 1 inch is fine... Thanks
  14. Mar 28, 2013 at 1:59 PM
    #994
    testedone
    Rick
    U.S.A.
    oh yeah that is with a shell on...
  15. Mar 28, 2013 at 4:58 PM
    #995
    offroadwonder
    offroadwonder Well-Known Member
    Jared
    Aurora, CO
    '10 Tacoma DCSB 4x4 TRD Off-Road
    Chopped mud-flaps (yup, I'm hardcore)
    For pinion angle, I have read in a number of different articles that there is no magic number. The best angle for your truck is found by matching the opposite angles. I.e. for a one-piece drive shaft the pinion angle should be the same as the output shaft angle, or match the angle at the carrier if you have a two piece.
    Can anyone lend any credibility to this?
  16. Mar 28, 2013 at 5:22 PM
    #996
    OZ-T
    Peter North
    British Columbia
    Exactly what I was getting at
    Front : mya |
    Rear : mya |
  17. Mar 28, 2013 at 5:50 PM
    #997
    nj636
    Kev
    Jersey
    Alright here we go..
    this was done in my driveway so it's on an slight angle. That doesn't make any difference since the procedure is just subtracting one angle from the other.
    We'll start at the pointy end of the truck...
    angle finder on the output flange of the transfer case like mya
    436D8682-BE25-4EED-BD57-B4A070901440_zps_fa71eeea8696c9b177afe4d10198466ddc3a6e3f.jpg
    angle is 2 degree's, record that #
    58AA6ECF-5EFE-4CA8-91D5-36969F60930D_zps_9aae0b171f2a42d6184ce8cb2358838be652f01e.jpg
    now put the angle finder on the driveshaft, close to the output flange of the t-case
    F14DF027-A93B-4332-8E88-4AFE860A65B6_zps_45d21216f2df777e3d7606d11c5ebda7d8bcb0a6.jpg
    0 degree's record that # and/or do the math now. You want to subtract the smaller # from the larger # so that puts me @ 2 degree's. Optimal # here is 0 degree's (t-case flange to driveshaft)
    5FA522DA-69B2-48E8-9F40-745132588CD0_zps_cfa602e85babaa41302eb99ebb6ac40d2ed2e5fd.jpg
    now at the rear of the truck, angle finder goes on the pinion flange like mya
    9BB27132-7403-484A-8281-7EE468DF6E86_zps_d4c145240ee94568b4887feed019de27c8fa98fe.jpg
    0 degree's, record that #
    9E02F510-816B-4EE4-803A-D58117E1700C_zps_9a5fc026d8db440b1d66bb782d0229c7487296ea.jpg
    now put the angle finder on the driveshaft close to the pinion flange
    05627B06-AA53-4B33-93EE-EC34490A47C1_zps_125ca144b816657f45fa3ad5add583717bc3b803.jpg
    4 degree's. Do the same as you did at the t-case, subtract the small # from the large # puts me @ 4 degree's.
    Here's how this measurement differs from the t-case measurement. Since the pinion goes "positive" under acceleration (pinion flange points up) you want the pinion flange to point about 3-4 degrees "negative" (down). Under acceleration the pinion will move those 3-4 degree's, putting the rear drive line angle @ the optimal 0 degree's. :thumbsup:
    The u-joints live the happiest when the total drive line angle is 0 degree's. That is the difference between the t-case measurement & pinion measurement. My total drive line angle (t-case to pinion) is 2 degree's. Again, subtract the smaller # from the larger #.. 2 @ the t-case from the 4 @ the pinion put's my total drive line angle @ 2 degree's. If I installed the carrier bearing drop I could probably obtain the magic 0. At 2 degree's I have no vibrations at all so I'm fairly happy with it.
    :broccoli::taco::burnrubber::mudding::kona::cheers::bananadance::woot::thumbsup::dancingbacon:
  18. Mar 28, 2013 at 5:50 PM
    #998
    testedone
    Rick
    U.S.A.
    yeah and this got me thinking since I did not measure the rear either
    23.5 on passenger side (front) 24+- a tad on the rear
    24 on Drivers side (front) 24.5 +_ a tad on the rear
    So I actually am/are level....
  19. Mar 28, 2013 at 5:53 PM
    #999
    OZ-T
    Peter North
    British Columbia
    Thanks
    Different approach than I was talking about , I'll try it your way too
    Not much surface area to measure across on the underside face of the pinions , no ?
  20. Mar 28, 2013 at 5:55 PM
    #1000
    OZ-T
    Peter North
    British Columbia
    Also , I appreciated the correct use of mya in your post , well done
