Old Man Emu: Questions, Answers & Pictures
Discussion in 'Suspension' started by 4Wheelin4Banger, Jan 15, 2013.
  1. Apr 24, 2017 at 10:15 AM
    MadRiverTaco
    MadRiverTaco Join TW, they said. It's free, they said.
    Brenden
    Waterbury, VT
    2012 Black DCSB TRD OR "Caroline"
    King 2.5 Ext. w/ Compression Adjusters (Front & Rear), Dakars w/ D29XL, TC UCA's & LCA's, ARE CX, 17" SEMA Pro's, 265/70/17 Falken Wildpeaks, BORA spacers, Rigid Side shooter ditch lights, ATHF bedside reinforcements, OME carrier bearing drop bracket, extended rear brake lines, Northstar 27F battery, Yakima Jetsream crossbars, OEM roof rack, OEM skid plate, TRD Pro grill, URD TCAI, 5.7L Throttle Body, BensonX bedside tool mounts, fire extinguisher bedside mount, AMP research bed step, Redline Tuning hood struts, ECGS needle bearing mod, CV Boot slide mod, Differential breather mod, U-Bolt Flip Kit w/ Timbren Bumpstops, A-pillar RAM mount w/ cell phone holder, ProFX tow mirrors with turn signals and heat, "Raptor" lights, DEPO taillights, motorized Pop n' Lock
  2. Apr 24, 2017 at 11:15 AM
    yodatoyota
    yodatoyota Scrub
    tim
    Barrie Ont. Can
    2021 TRD OR 4x4 sb
    Empty wallet mod
    So keep current AAL and stack it with dakars? Longer brake lines probably eh?
  3. Apr 24, 2017 at 11:24 AM
    MadRiverTaco
    Brenden
    Waterbury, VT
    yodatoyota[QUOTED] likes this.
  4. Apr 24, 2017 at 5:53 PM
    dgb1179
    dgb1179 Member
    Raleigh, NC
    2008 TRD Sport 4x4 DCLB
    Honestly I'm not sure if they did that or not. I take it back it at 100 miles and then 500 miles for them to retorque everything, so I'll find out. I don't really do any offroading, though it would be fun to give it a try.
    la0d0g[QUOTED] likes this.
  5. Apr 24, 2017 at 6:05 PM
    la0d0g
    running for the hills
    For crawling not hauling
    :thumbsup:
  6. Apr 25, 2017 at 5:08 AM
    CamShaft033
    CamShaft033 Well-Known Member
    Cameron
    Chattanooga TN
    2012 DCSB TRD Sport
    OME 887s, JBA uca, Dakars, Fox Shocks, 285/70/17 Nittos, Dual Flowmaster, ARE Camper Shell w Yakima Rack, CVT Tent, AVID Rear Bumper Guard w LED Pods, 52" Lightbar, Sportsman Seat Covers, WeatherTech Floor mats
    Installed the dakars and ome shocks this weekend. Took about 4 hours by myself. Very straight forward and every bolt came out with no problem! It rides like a caddy now! Im very impressed with how tight the leafs are, but yet it rides and takes bumps super smooth. :yay:
    hunter357mag, bigfella13 and la0d0g like this.
  7. Apr 25, 2017 at 6:22 AM
    MadRiverTaco
    Brenden
    Waterbury, VT
    Welcome to the club. The difference truly is night and day
  8. Apr 25, 2017 at 10:48 AM
    raggedphoto
    raggedphoto Well-Known Member
    Oregon
    DCSB 07 Desert Sand Mica
    For long haul vs short crawl
    One of the first trips I took post lift I finally got to some fun curvy roads and woke my girlfriend up from her nap to tell her "It tracks like a race car now!!!" to which she just smiled and went back to sleep.
  9. Apr 25, 2017 at 3:33 PM
    upTOPOverland_Drew
    upTOPOverland_Drew upTOP Overland Technical Design and Application
    Drew
    Littleton, CO
    2017 TRD OR DCSB SUPER WHITE
    All the things...click the link in sig
    I have a 2017 DCSB and I will be adding a Leer 100XR, Prinsu Cabrac and Awning along with a DIY Drawer system. I am expecting around 300ish lbs sitting over just the bed as a constant load. If i do 887 coild and the standard leaf pack do y'all think I will maintain close to that 1" of stock rake? I prefer to have that 1" of rake.
    baileybrandon likes this.
  10. Apr 25, 2017 at 3:36 PM
    T4RFTMFW
    T4RFTMFW Well-Known Member
    No.
    Go with an 885 instead.
  11. Apr 25, 2017 at 3:52 PM
    upTOPOverland_Drew
    Drew
    Littleton, CO
    Marie from headstrong is saying ill get 2.75-3" lift in the rear over stock and 2" with the 887 over stock pushing me to 2" of rake? maybe i misunderstood her as i am new to all this suspension stuff
  12. Apr 25, 2017 at 3:53 PM
    T4RFTMFW
    2.75" is average height for a full Dakar pack.
    You're adding 300 lbs or more and wanting 1" of rake.
    What are you current measurements, hub to fender, front and rear?
  13. Apr 25, 2017 at 3:55 PM
    upTOPOverland_Drew
    Drew
    Littleton, CO
    LF: 20 3/4
    RF: 21
    LR: 22
    RR: 22
    Cap goes on this saturday and drawers/prinsu/awning next month
  14. Apr 25, 2017 at 3:59 PM
    T4RFTMFW
    Just realized you have a third gen.
    With Dakars you'll be sitting at approx. 24.75" in the rear, and the 887s will only yield you a 2" lift or so, right? So you'd have maybe 23" up front, which is almost 2" of rake unloaded.
  15. Apr 25, 2017 at 4:00 PM
    upTOPOverland_Drew
    Drew
    Littleton, CO
    Do you think 300lbs will push it down 3/4 - 1 "?
  16. Apr 25, 2017 at 4:02 PM
    T4RFTMFW
    No way.
    300 lbs is just about where Dakars start to move.
    I had 250 lbs in mine and it was 2.75" of lift. To get down another inch from there I was closer to 700 lbs if not more.
  17. Apr 25, 2017 at 4:03 PM
    upTOPOverland_Drew
    Drew
    Littleton, CO
    well hmmmmmmm, should i consider AAL instead?
  18. Apr 25, 2017 at 4:05 PM
    T4RFTMFW
    Could.
    Marie sells one of those, it'll drop you down to the height you want to be, but you could also remove a leaf from the Dakars and lose some height. Not sure how much that changes.
    I found a 3 leaf AAL to be too weak, so I'd recommend a single leaf, myself.
  19. Apr 25, 2017 at 4:23 PM
    la0d0g
    Besides cost
    Dakar - leaf > AAL
    T4RFTMFW and upTOPOverland_Drew like this.
  20. Apr 25, 2017 at 4:54 PM
    Juforrest
    Juforrest Dumb!
    Justin
    Seattle
    Reformed Taco driver in a GX460
    Dakars and 888 springs
