Old Man Emu: Questions, Answers & Pictures
Discussion in 'Suspension' started by 4Wheelin4Banger, Jan 15, 2013.
  1. Feb 27, 2023 at 12:17 AM
    Raijin822
    Raijin822 Well-Known Member
    Canada
    2021 TRD OR
    886 if your going to be 200+ lb up front with all that
  2. Feb 27, 2023 at 5:05 AM
    Thergood
    Thergood Active Member
    Pennsylvania
    2015 Access Cab TRD Off Road
    Yea, bumper and winch are ~150lbs . Skids are aluminum ~70lbs. I don't know what the sliders weigh but they're steel. The truck is an access cab though, so that's something. I've got the 885's on order, I'll probably give them a try at least. I've got about a month before the install so I'll probably change my mind 6 times before then.
  3. Jun 19, 2023 at 11:27 AM
    JBRAS2022OR
    JBRAS2022OR Member
    MONROE NC
    GONNA BUMP THIS THREAD im having a hard time debating between the 5100 series shocks with 885 springs or going OME, i dont want the ride to be too stiff i ride 75 miles a day and rarely go offorad except for a few trails and only during deer season. i want a good ride! better than stock and something that dosent feel like a wagon. 2022 trd offroad double cab long bed!
  4. Jun 19, 2023 at 11:48 AM
    Thergood
    Pennsylvania
    What else do you have on your truck? If it's just stock - no armor, bed rack, camper shell, winch, etc. and all you care about is some lift and good ride on road then I'd get the 5100's w/ 885's, maybe an add-a-leaf in back.
  5. Jun 19, 2023 at 11:54 AM
    JBRAS2022OR
    JBRAS2022OR Member
    MONROE NC
    its a stock truck, ive got air bags in the rear for when i haul a trailer or fire wood other than that i dont plan on adding any bumpers or rock sliders or a tent or anything for that matter! just want a lift so and 265-75-16 tires witha good ride quality
  6. Jun 19, 2023 at 11:58 AM
    dangeroso
    dangeroso Just float along and fill your lungs
    Jon
    Dallas, TX
    2018 Tacoma TRD Sport 4x4
    I went OME, complete package. If you do the light duty setup, it will be a nice soft ride. I went medium duty, and it's about perfect for me, although I like a tighter suspension.
  7. Jun 19, 2023 at 12:12 PM
    JBRAS2022OR
    JBRAS2022OR Member
    MONROE NC
    light duty? what shocks do you have the 90021 or the other ones? from waht ive read the 90021 are the "softer" of the two
    dangeroso likes this.
  8. Jun 19, 2023 at 1:34 PM
    AJC84
    AJC84 Well-Known Member
    Andy
    2011 DC LB V6 4X4 MAG GREY
    I’ve got 90021s I believe and 885 coils and it’s a great ride. Have toytec 3/4in (I think) top plate spacers up front and have aluminum front bumper weighs 60lbs. Tear bumper is steel 85lbs. Got Dakar full leaf packs. Whole setup rides amazing. Running 285/75/16s. Rear doesn’t even squat when I tow my 6k boat a few miles to the ramp. Before adding Dakars I did a yard of loam bed of truck and it was doing the Carolina squat lmao . Not anymore I he Dakars are sturdy af
    Taco22trdor likes this.
  9. Jun 19, 2023 at 1:39 PM
    dangeroso
    Jon
    Dallas, TX
    Sorry, I think that medium duty terminology came from the vendor, not from OME. I have 2888 springs, and 90000 front struts with 60091 in the rear. And the EL111R leaf packs.
    JBRAS2022OR[QUOTED] likes this.
  10. Jun 20, 2023 at 6:23 AM
    JBRAS2022OR
    JBRAS2022OR Member
    MONROE NC
    thanks for the information guys im really leaning towards the OME stuff vs the bisltein for the simple fact of ahving a twin tube design vs a mono tube that typically rides stiffer from what ive read
  11. Jun 21, 2023 at 5:02 AM
    JBRAS2022OR
    JBRAS2022OR Member
    MONROE NC
    just checking but for 2" of lift would i need the 885 or 887 coils, no winch no bumper and no plans for one in the future
  12. Apr 5, 2024 at 5:55 PM
    ltdpilot
    ltdpilot Well-Known Member
    04 Tacoma TRD SR5
    Hey all, bumping this thread, I've seen many refer to the standard "OME clunk". Something to do with the shock internal valving? I discovered a clunk in the rear suspension when I push down on the rear bumper, or bounce on the rear bumper, of my 1st Gen. I think it's the shock, the sound appears to come from one of them, but don't know what this OME clunk is exactly...
  13. Apr 5, 2024 at 6:09 PM
    520Toyota
    520Toyota Well-Known Member
    C.V.
    Nor Cal
    dcsb 6spd 4x4 offroad
    Ome lift
    I’ve had a bad brand new ome rear shock that clunked. It was on the passenger rear. I switched it to the driver side rear and that side clunked. It was replaced under warranty.
    ltdpilot[QUOTED] likes this.
  14. Apr 14, 2024 at 1:27 PM
    Thergood
    Pennsylvania
    For folks with similar setup in the future - The firmer valved shocks with the 886 springs were way too stiff on this setup. Maybe if I had a full plate bumper. The access cab seems to be exceptionally light up front. I was afraid I was going to kill my wheel bearings, ball joints, etc. Also the EL112R pack sagged on me within about a year. It sat ooook with around 600lbs of static weight in the back, but began to sag noticeably with any more. I ended up upgrading the whole setup - Dobinsons MRRs with the 354 spring. It's still firm, but not as bad as the OME, and the adjustability means I can soften it up a little bit on trail. I could even sacrifice a little lift to reduce the pre-load, which I may do. In the back I went with Archive's Heavy Duty setup and they have been fantastic. Maintaining a great lift and arch with 600+lbs of static weight. No concerns about loading it up.
  15. Apr 14, 2024 at 2:03 PM
    LarryDangerfield
    LarryDangerfield One Larry a day keeps the money away ™ Moderator
    Tyler
    Northern Wisconsin
    Cement 2020 Trail Limo off-road
    Tuxmat floor mats, Bilstein 6112s and 5160s
  16. May 7, 2024 at 7:13 PM
    ETAV8R
    ETAV8R Out DERP'n
    Republik of Commiefornia
    MGM 09 AC 4WD V6 TRD-OR w/ Tradesman Shell
    Just the basics
    A broken leaf...on an old pack.
    Probably replace with a new HD pack but confused about the part number, where to buy from, and how to ensure +, 0, - for the proper drivers and passenger side.
    Any information about this? Other threads aren't very current.
  17. May 8, 2024 at 9:27 AM
    mistrchow
    mistrchow Well-Known Member
    Somewhere in Nature.
    11 SWB Tacoma TRD OD
    Bone Stock
    The "Heavy Duty" leaf pack (EL112R)
    https://www.headstrongoffroad.com/store/p123/Old_Man_Emu_Dakar_Leaf_Packs_(PAIR)_-_ONLY_LEAF_PACKS_for_2005__Toyota_Tacoma.html
    "+" slightly higher spring rate
    "-" is for slightly lower spring rate
    "o" exactly at spec
    As the drivers side of a vehicle often has more weight, its common to use a "+" on the drivers side and a "o" or a "-" on the passenger side. Or, a "o" on the drivers side and a "-" on the passenger.
    You can read this thread for more info as well
    https://www.tacomaworld.com/threads/the-newest-ome-dakar-leaf-packs.671911/
    4WDTrout likes this.
