Old Man Emu: Questions, Answers & Pictures
Discussion in 'Suspension' started by 4Wheelin4Banger, Jan 15, 2013.
  1. Apr 29, 2013 at 6:19 PM
    #1321
    OZ-T
    OZ-T You chose ... poorly
    Peter North
    British Columbia
    In your case I would go with the progressive 3 leaf AAL too
  2. Apr 29, 2013 at 7:34 PM
    #1322
    Grieby54
    Grieby54 Horsebit
    Sam
    Castle Rock, CO
    '13 TRD Off Road 4x4 DCSB MGM JBL/Entune/Nav
    WeatherTech Digital Liners, ImMrYo rear view mirror bracket, color matched grille, Tacoma door sill protectors, OEM hood protector, clear bra, tint, OEM roof rack, trimmed front mud flaps to match rear clearance, debadged, color matched grille, Plasti Dipped front Toyota emblem, OME 884X coils with trim packer on driver's side, OME Nitro Sport 9000 shocks, Deaver/ToyTec AAL with OME N182 shocks, 265/75/16 Duratracs, ProComp 7032 16" wheels
    Thanks for the advice!
  3. Apr 29, 2013 at 7:53 PM
    #1323
    TRD6Speed
    TRD6Speed senior member
    Bill
    East Hartford, CT
    08 TRD Sport Access Cab
    885x with 5100s and top plate spacer for full 3", RCD extended 5100s in rear, dakars, flip kit, LR UCAs, tint, shorty antenna, in channel rain guards,BHLM, blacked out emblem, OEM side steps, weathertechs, debadged, rear diff breather
    Also if you want a level look but a new leaf pack.....to avoid the sagging and shitty load capacity of the stockers.......Look at the IRONMAN lift leaf packs. Sierra Expeditions sells them. 2" lift over stock and I believe they sell different leaf packs of varying load capacity and stiffness. I toyed with that idea for awhile.
  4. May 1, 2013 at 11:20 AM
    #1324
    TicoTRD
    TicoTRD Well-Known Member
    Tico
    410
    '11 MGM SR5 AC
    ok i have two questions....one, what are the 885x? is tht the same as the 885? and two, this is for a majority of people out there including myself but, what are the pros and cons of ome lift and toytec lift with 5100s? what are the big differences of the two? thanks
  5. May 1, 2013 at 12:46 PM
    #1325
    4Wheelin4Banger
    4Wheelin4Banger [OP] Longtime Toyman
    Randy
    Ferntucky, NV Halfway between Reno & Falabama
    2011 4x4 Access Cab Silver State Edition
    3" OME lift 885s & Dakars riding on 33" KM2s Click the sig pic to see the build thread .
    885x replaced the 885 & fixed the sag problem.
    OME Pros:
    Shocks & springs were designed, tested & refined to work well together.
    Lift achieved without preloading the coils.
    Great lift for a reasonable price.
    Great ride on & off road.
    OME Cons:
    None that I can think of.
    5100 Pros:
    Cost a little less.
    5100 Cons:
    Preload coils to achieve more than 1.6" of lift.
    Ride quality due to preloaded coils.
  6. May 1, 2013 at 12:57 PM
    #1326
    YOTA LOVER
    YOTA LOVER Stay Calm, and Fire For Effect
    NH
    2011 MGM Tacoma DCLB SR5
    A slew of pricey stuff my wife hates me for.
    ^^^ What he said [​IMG]
  7. May 2, 2013 at 8:16 AM
    #1327
    ndcmack
    ndcmack Well-Known Member
    NICK
    Western Washington
    BSP 4x4 TRD Sport DCSB
    Not enough
    Took my truck in for alignment after installing dakar leaf springs w/aal and the guy said I installed my toytec 3deg shim backwards. I swear I researched the correct direction before install but I need confirmation. Should the skinny side of the wedge face toward the front of the truck or toward the back of the truck?
  8. May 2, 2013 at 8:21 AM
    #1328
    jhodge83
    jhodge83 They all float down here... Moderator
    SC
    17 XLT Sport
    3rd gen forum caused me to get a Ford
    skinny towards the front.
  9. May 2, 2013 at 8:33 AM
    #1329
    fbj913
    fbj913 Member
    KC MO
    08 TRD
    1. vibes are getting less and less predominate. i'm going to give it some time to see if the suspension settles just enough to eliminate the vibes completely. it goes away on the highway so that's a plus.
    2. popping noise was the wheels weights hitting the sway bar at full steer. so nothing to worry about there... :rolleyes:
    3. i'm pretty sure the idiots that did my alignment didn't get the passenger side done correctly. i think its pulling in because the angle is still out of spec. i'm going to take it to another shop and see if they do a better job. i also think a front bumper would help keep the springs a little compressed. with no weight they are pretty stiff!
  10. May 2, 2013 at 8:37 AM
    #1330
    YOTA LOVER
    NH
    Good to hear some of the issues are ironing themselves out. The springs will break in some as they wear in, even before you put the bumper on. I'm considering pulling the sway bar completely to see how the truck corners and handles bumps without it.
  11. May 2, 2013 at 8:41 AM
    #1331
    jhodge83
    SC
    17 XLT Sport
    been running my truck w/o a sway bar for years. only added it back for a spell to reduce the travel w/ 35s.
  12. May 2, 2013 at 8:51 AM
    #1332
    ndcmack
    NICK
    Western Washington
    Not enough
    Great! Thanks! That's the way I installed them
  13. May 2, 2013 at 8:51 AM
    #1333
    YOTA LOVER
    NH
    Doesn't lean to much while cornering? Added flex over rocks and offroad?
  14. May 2, 2013 at 9:03 AM
    #1334
    jhodge83
    SC
    17 XLT Sport
    added flex for sure. depends on how aggressive you take turns as to how much body roll you get. normal driving you cant tell. test it out and see. doesnt take long to put it back on if you dont like it.
  15. May 2, 2013 at 9:05 AM
    #1335
    YOTA LOVER
    NH
    Awesome! Can't wait to try it out :D
  16. May 2, 2013 at 9:31 AM
    #1336
    TicoTRD
    Tico
    410
    '11 MGM SR5 AC
    so where do i get the 885x?
  17. May 2, 2013 at 9:36 AM
    #1337
    TicoTRD
    Tico
    410
    '11 MGM SR5 AC
  18. May 2, 2013 at 9:37 AM
    #1338
    jhodge83
    SC
    17 XLT Sport
    ordered mine from DSM, but toytec says they have them. others got them from wheelers too, IIRC.
  19. May 2, 2013 at 9:38 AM
    #1339
    TicoTRD
    Tico
    410
    '11 MGM SR5 AC
  20. May 2, 2013 at 9:39 AM
    #1340
    jhodge83
    SC
    17 XLT Sport
