Old Man Emu setups on 1st gens
Discussion in '1st Gen. Tacomas (1995-2004)' started by kyle39, Feb 19, 2011.
  1. Apr 23, 2014 at 3:43 PM
    #921
    hossmaster
    hossmaster Well-Known Member
    League City, Tx
    2002 Converted / 2017 OR
    Was a PreRunner, now it isn't
    Where in the spring pack does the AAL go? Do you get instructions with them?
  2. Apr 23, 2014 at 3:53 PM
    #922
    Madjik_Man
    Colorado Front Range
    3rd down I believe
  3. Apr 23, 2014 at 4:00 PM
    #923
    johnboyTRD
    johnboyTRD Well-Known Member
    South SF bay
    2003 Tacoma Double Cab TRD
    Full ome lift, nitro charger sports all 4 corners (rear shocks relocated), Dakar pack w/ AAL, 882 coils, diff drop, toytec 1" shackles, trail gear low profile front bumper, Tuff Stuff winch, bamf sliders, RAT skids, BAMF Bed Rack, Tepui Kukenam RTT, RAT rear bumper,
    Roger, 3rd down.
  4. Apr 23, 2014 at 5:19 PM
    #924
    Scenekyd
    Scenekyd Not much of a member
    Jay
    Hendersonville, NC
    2015 Ford F-250, 2016 4runner Trail
    Yeah I have that same feeling also. But hopefully when I get everything in the bed it'll settle. I went with 883s.
    And as for the parts numbers, those are correct :D that's what my leaf has stamped on the top lol
    Edit: any recommended grease for the shackles and bushings before I press them?
  5. Apr 23, 2014 at 5:36 PM
    #925
    lotsoftoys
    lotsoftoys pavement is boring....
    Jace
    Denver
    98 lifted panda taco
    bunch of crap
    I got 2 inches when I put it in. hopefully it settles an inch would be nice
  6. Apr 23, 2014 at 5:51 PM
    #926
    Madjik_Man
    Yeah I saw the pic of your AAL in your leaf pack... and then saw Adam's which has settled obviously. Pretty large difference IMO.
    I'll definitely like to hear what measurements are after you drive it around for awhile, hit Moab, etc.
    As of now I'm pretty set on adding the AAL right off the bat because I'm running my topper 99% of the time.
  7. Apr 23, 2014 at 6:01 PM
    #927
    johnboyTRD
    South SF bay
    I used some kind of moly based susp grease. Seems to work alright. Pretty sure it was mobile 1.
  8. Apr 23, 2014 at 7:52 PM
    #928
    Scenekyd
    Jay
    Hendersonville, NC
    Alright, thanks. Anything else I may need for install?
  9. Apr 23, 2014 at 10:14 PM
    #929
    johnboyTRD
    South SF bay
    For the rear, make sure you have stands to secure axle and frame. So they don't shift on you. Also, you can use the factory bottle jack placed between the frame and spring to push the spring down into alignment with shackle.
    I can't remember exactly how but I ended up using the bottle jack for the front too...
  10. Apr 23, 2014 at 10:26 PM
    #930
    ffirg
    ffirg Well-Known Member
    mike
    Anchorage, Alaska
    2002 Tacoma SR5 TRD 4X4
    The bottle jack can be placed on the top of the UCA with a 2x4 between the fender and the top of the jack to force the suspension low enough to align with the longer struts.
  11. Apr 23, 2014 at 10:31 PM
    #931
    95 taco
    95 taco Battle Born
    2003 4x4 TRD SR5 auto
    OME 883 front, OMD 3.5" rear, Relentless front bumper, smittybilt 9.5K winch
    I wish i'd've known this when i did my 5100's, I ended up taking a long pry bar and standing on it to force the LCA down enough to put the bolt in.
  12. Apr 23, 2014 at 10:33 PM
    #932
    NoTown98Yota
    NoTown98Yota Whiskey Throttle FTW!
    Scott
    Reno, NV
    '98 Tacoma 3.4L V6 W/E-Locker
    -Leer shell with Yakima MegaWarrior -K&N FIPK -18" Magnaflow dumped after axle -Clear headlights -Blacked out bumpers, wheels, badges, mirrors, fuel door, door handles, tail lights, corner markers and turn signals -White LED gauge lights -SpiderTrax 1.5" Spacers -Pinch Weld Mod -Ultra Gauge -6 Switch Plate under single din stereo -Custom Battle Born bedside decals -Eibach 620# coils -Bilstein 5100's -Dakars -Toytec 1" Lift Shackles
    Hahaha I used a 2X4
  13. Apr 23, 2014 at 10:44 PM
    #933
    Matic
    Matic The "OFG" Baby!!!
    Tricky Dick
    Easley, SC
    1 owner 2002 TRD, SR5, DC, 2.7. Full OME suspension, STT pro's.
    OME 881 coils with OME nitrochargers shocks up front. TC UCA's OME Dakars with extra leaf in the rear. Warn 8000 winch with 80ft custom braided synth line. Custom 60ft synth extension. All pro tube bumper, Hi-lift jack, Safari Snorkel, Wilco tiregate. 2019 Jeep JLUR.
    You are going to need.some big c clamps for the aal. If someone hasn't mentioned that allready.
    When are you going to put it on. I think I'm only 45 mins from you if you're needing some help.
    I've done a few.
    Did they give you an extr length center pin for the rear springs?
  14. Apr 23, 2014 at 10:45 PM
    #934
    Matic
    Tricky Dick
    Easley, SC
    This.
  15. Apr 23, 2014 at 10:47 PM
    #935
    Matic
    Tricky Dick
    Easley, SC
    Do you have air and air tools or are you going to do it with hand tools?
  16. Apr 23, 2014 at 10:51 PM
    #936
    ffirg
    mike
    Anchorage, Alaska
    Haha yeah. It took me probably 20 minutes with a pry bar to figure it out. At one point I even moved the bottle jack over so I could put more weight on the pry bar...:anonymous:
  17. Apr 24, 2014 at 6:39 AM
    #937
    StAndrew
    StAndrew Wait for it...
    Hampton Roads, Va
    SR5 4x4TRD
    Intake, exhaust, lift. Typical stuff.
  18. Apr 24, 2014 at 7:26 AM
    #938
    MadMtnMikey
    MadMtnMikey Well-Known Member
    Richmond/VaBeach
    03 DC 4x4 SR5 TRD
  19. Apr 24, 2014 at 7:29 AM
    #939
    johnboyTRD
    South SF bay
    Haven't heard anything about collars before, so you should be g2g. Also, I did not shim the axle, or cb drop. However I will be ordering a bpv bracket from bamf soon...
  20. Apr 24, 2014 at 8:14 AM
    #940
    Jiveydude
    Jiveydude Well-Known Member
    Micah
    OH
    04Taco
    Stuff and things that make it better.
    You will need longer collar pins if you plan on putting shims in, the stock Dakar ones will be too short. Most people don't add the shims until they have driven around for a bit and found they have/don't have vibrations. Adding the longer pins now just saves you a little headache down the road if you decide to add the shims. But with a couple C-clamps the pins come out pretty easy, with no leaf movement.
