OME 2.5" lift with 285/70/17 and 4.5" backspace
Discussion in 'Suspension' started by AllMountainToy, Jan 16, 2013.
  1. Jan 16, 2013 at 1:27 PM
    AllMountainToy
    AllMountainToy [OP] Well-Known Member
    Northern California
    2011 Tacoma Double Cab 4X4 TRDOR
    2 3/4 OME Suspension Lift with 885, with trim packer, 1/4" top plate spacer, swaybar relo bracket. Dakar leaf pack with 3rd leaf removed. 285/70/17" BFG AT. XD Wheels with 4.5 BS, Best Top Soft Top, Undercover winch mount with Warn 8k winch (with synthetic line), Pioneer touchscreen double din head unit. 4X innovations welded sliders. roof mounted DVD system.ATO dual battery tray with dual yellow tops. Rugged ridge isolator kit.
    If you are running 285/70/75s with 4.5" backspace on the OME 2.5" lift (no toytec top spacer) AND have the Cab mount chop and trimming done...
    Are you rubbing your fender flares when compressing the front suspension while wheeling or even going in and out of driveways?
    Bottom line, I want to know if it is worth taken the lift off to remove the spacers or not. I originally had 2.25" pro comp spacers when I bought the truck new and the tires rubbed the fenders bad. I wondering if 2.5 would rub of if I have to go stay with the full 3".
  2. Jan 16, 2013 at 1:37 PM
    evanmb31
    evanmb31 Well-Known Member
    evan
    connecticut
    09 trd off road
    Satoshi'd grill. blacked out badges. aftermarket sound system. De-chromed and color matched. OME 885s + Dakars with 3rd leaf removed. LR UCAs. Scs stealth 6 with 285 duratracs. BAMF sliders
    I meet all your criteria except i have 4.3 backspacing but they are 8.5 inch wheels. I had to trim the very bottoms of the fender flare to avoid rubbing
  3. Jan 16, 2013 at 1:58 PM
    evanmb31
    evan
    connecticut
    09 trd off road
    Just to make sure i understand, you have OME suspension in the front right now with top plate spacers, and your thinking about taking them off for roughly 1/2" less lift?
  4. Jan 16, 2013 at 2:39 PM
    AllMountainToy
    Northern California
    correct! thanks
  5. Jan 16, 2013 at 2:46 PM
    evanmb31
    evan
    connecticut
    09 trd off road
    I think you should be fine taking them out if you dont rub now then. Stuff the front suspension with the wheel turned as much as you can, see how close you are to the bumpstops. Better yet take off your sway bar temporarily so you can get the wheels stuffed as much as possible. Taking off the spacers shouldnt change how much up travel you have, so if you dont rub now with the tires fully stuffed then you wont rub after you take off the spacers. Why do you want to take them off?
  6. Jan 16, 2013 at 2:46 PM
    AllMountainToy
    Northern California
    how was the fender trimming? I noticed right where the flare is, there is a bolt to secure it the wheel well.
    All good and sturdy?
  7. Jan 16, 2013 at 3:27 PM
    evanmb31
    evan
    connecticut
    09 trd off road
    Im not sure where exactly you are talking about. But ya everything is sturdy, trimming didnt change anything with the fender flare as far as sturdyness. The inner wheel well liner is a little floppy from cutting it.
  8. Jan 16, 2013 at 10:53 PM
    AllMountainToy
    Northern California
    I am worried it is a bit too much lift.
  9. Jan 16, 2013 at 10:55 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    OP , didn't you say you settled to a front hub to fender measurement of 24" ?
  10. Jan 17, 2013 at 7:53 AM
    AllMountainToy
    Northern California
    Correct. It is now just shy have 24. Like 23 7/8
  11. Jan 17, 2013 at 8:19 AM
    OZ-T
    Peter North
    British Columbia
    So you essentially have 3 1/2 - 3 3/4" if lift , that's a lot for a 4x4
    You could remove your 1/2" spacers and replace them with 1/4" spacers , that would drop you about 1/2"
  12. Jan 17, 2013 at 8:28 AM
    xaqori
    xaqori Grammer knotsy
    Zac
    Marietta, Georgia
    '06 4x4 Limo
    ARB lockers and 4.88s front and rear, OME 886s, Dakars, etc., Safari Snorkel, 17"Fuel Revolvers w/ 35x12.50r17 KM2s, fenders cut 3" all around, Pioneer AVH-P4400BH w/ Backup cam, CB/PA (PA Installed), Weathertech Digis, Foglight anytime, AP: front bumper, skids, and pack rack, custom sliders, Warn 9.5XP, dual VIAIR 480Cs with a 2.5gal tank, OTRATTW switches galore, URD y-pipe, RCI skids, LF 240s, etc.
    Did you have to do the CMC to fit them?
  13. Jan 17, 2013 at 10:50 AM
    AllMountainToy
    Northern California
    Yes. Not only did I have to do the CMC and wheel well trimming, It needed over 2.25" lift.
    When I bought the truck from the dealership, it had a 2.25" spacer in the front with this tire and wheel set up. They did have the CMC and proper trimming done but I nearly tore my fender flares off even driving on road going into driveways. They did fix this by installing the Pro Comp 3" lift kit at no cost.
    This all brings me to the past week where I installed the OME 2.5" along with the .5" top spacers. This yielded too much lift as noted by OZ-T's reply in this thread. This weekend I am now removing the .5" spacers, installing the .25" spacers and removing the 3rd leaf on the Dakar pack.
    So...2.25 was not enough but hoping 2.75 will be just enough. Sorry long reply but wanted you to have the background
  14. Jan 17, 2013 at 10:50 AM
    AllMountainToy
    Northern California
    good suggestion..Just ordered will arrive tomorrow. We shall see! Thanks again
  15. Jan 17, 2013 at 11:56 AM
    xaqori
    Zac
    Marietta, Georgia
    '06 4x4 Limo
    Thanks. Just wondering before I get the OME setup
  16. Jan 17, 2013 at 12:05 PM
    4Wheelin4Banger
    4Wheelin4Banger Supercharged Toyman
    Randy
    Ferntucky, NV Halfway between Reno & Falabama
    2011 4x4 Access Cab Supercharged Silver State Edition 245WHP
    3" OME lift 885s & Dakars riding on 33" KM2s
