OME advice
Discussion in '2nd Gen. Tacomas (2005-2015)' started by NateB, Dec 30, 2014.
  1. Dec 30, 2014 at 10:47 AM
    NateB
    NateB [OP] Active Member
    Nate
    MidMo
    2019 TRD Sport
    I've read alot of threads, but I'm still uncertain about my plan, so I decided to risk the flamin and hope to hear some good advice.
    My truck gets about 1000 miles per month on the highway. I only occasionally take it offroad to play, so a couple of inches of lift adequately provides the clearance I want. So, first I put on Bilstein 5100's front and back with the front set at 1.75 with stock coils. Then I added an Icon 1.5 AAL on the rear, they seemed to settle some. Then I added a camper shell, and I'm not satisfied with my rear height. So I'm thinking about replacing my springs with OME Dakars. If I do the OME springs and remove a leaf, should that give me about the right amount(2 in?) of lift and allow my truckbed to carry about 1000 pounds without sagging?
    Thanks in advance for input.
  2. Dec 30, 2014 at 10:50 AM
    OZ-T
    OZ-T You are going backwards
    Peter North
    British Columbia
  3. Dec 30, 2014 at 10:55 AM
    NateB
    Nate
    MidMo
    2019 TRD Sport
    Hey Oz-T
    Those averages make me think maybe I should NOT remove 3rd leaf?
  4. Dec 30, 2014 at 10:58 AM
    OZ-T
    Peter North
    British Columbia
    I carry a Leer 100RCC cap and about 200-250lbs of tools , so about 400-450lbd total and I am planning on adding the d29xl OME AAL
  5. Dec 30, 2014 at 11:11 AM
    OZ-T
    Peter North
    British Columbia
    If you want to carry heavy loads but retain close to 2" lift I would suggest removing the top overload rather than the 3rd leaf
  6. Dec 30, 2014 at 11:26 AM
    NateB
    Nate
    MidMo
    2019 TRD Sport
    Curious, why are you going with the AAL instead of new leaf packs.
  7. Dec 30, 2014 at 12:13 PM
    OZ-T
    Peter North
    British Columbia
    The d29xl is an OME AAL that is designed to be added to the regular Dakar pack to add another leaf to the pack
  8. Dec 30, 2014 at 2:18 PM
    NateB
    Nate
    MidMo
    2019 TRD Sport
    Thanks for the help!
  9. Dec 30, 2014 at 2:42 PM
    Fahrenheit
    Fahrenheit Well-Hung Member
    Garth
    NS
    06 DCSB TRD OR
    Just curious, does the D29XL add much to the lift? Or does it allow you to maintain consistent height when under heavier load? Am debating this or a shackle flip kit to get a little more from my Dakars.
  10. Dec 30, 2014 at 3:01 PM
    OZ-T
    Peter North
    British Columbia
    Both adds lift , 3/4 - 1" , and adds spring rate
